Monitoring and Troubleshooting
The Open OnDemand Service reports its state through OneFlow, OneGate and a Prometheus endpoint on the portal.
Metrics
The portal serves Prometheus metrics on port 9101 of its management address, at http://<portal management address>:9101/metrics:
| Metric | Meaning |
ood_worker_active_sessions | Slurm jobs running on the worker, sessions included (labels vm_id, name, address) |
ood_worker_idle_seconds | Seconds since the last job on the worker ended |
ood_worker_oldest_idle | 1 when the oldest worker of the role is drained and empty, so OneFlow may remove it |
ood_slurm_pending | Jobs waiting for a worker of this role, as seen by the worker |
ood_slurm_idle_nodes, ood_slurm_alloc_nodes | Idle nodes of the Cluster, and nodes with a job, as seen by the worker |
ood_worker_healthy | 1 when the worker passed its last check of the home mount, the software catalogue, munge and slurmd |
ood_role_cardinality | VMs in each role |
ood_portal_puns | Per-user web servers running on the portal, one per signed in user |
ood_service_state | The OneFlow state of the service, as its numeric code (2 is RUNNING) |
ood_exporter_scrape_ok | 1 when the exporter’s last read of the service through OneGate succeeded |
The same values are in the user template of each worker VM, in Sunstone or in onevm show <WORKER_ID>. The template also holds SESSION_USERS, the users with a job on the worker. SLURM_NODENAME in the same template is the name of its Slurm node. A worker whose home mount, software catalogue, munge or slurmd fails publishes HEALTHY=0 until it recovers. On the portal, sinfo lists every worker as a node with its role as a feature. squeue lists the sessions and the batch jobs.
Logs
| Location | Description |
/var/log/ood-appliance-configure.log | What each role did at boot, on every VM |
/etc/one-appliance/status | bootstrap_success when the role is ready |
/var/log/ondemand-nginx/<user>/error.log | The user’s web server, on the portal |
/var/log/apache2/ | The front Apache and the login flow, on the portal |
/var/log/slurm/slurmctld.log | The Slurm controller, on the portal |
/var/log/slurm/slurmd.log | The Slurm node daemon, on every worker |
~/ondemand/data/sys/dashboard/batch_connect/sys/<app>/output/<session id>/output.log | What a session printed, in the user’s home |
On the workers, journalctl -t ood-slurm-elastic shows what the elastic loop published and what the health check found. On the portal, journalctl -t ood-slurm-reconcile shows the nodes the reconciler removed.
A Role Does Not Reach RUNNING
oneflow show <SERVICE_ID> names the role. When a check stops the role, the VM carries the reason in its ERROR attribute. Sunstone shows it in a red banner on the VM, and onevm show <VM_ID> | grep ERROR prints it. Fix the value and instantiate the service again. When the attribute is missing, read the last lines of /var/log/ood-appliance-configure.log on the VM.
The following list presents some common causes:
- A switch enabled with its field empty:
ONEAPP_HOME_NFS_ENABLED,ONEAPP_SOFTWARE_PROXY_ENABLED,ONEAPP_SLURM_CONTROLLER_ENABLED,ONEAPP_AUTH_OIDC_ENABLEDandONEAPP_PORTAL_CERTIFICATE_ENABLEDeach require their fields, and the message names the missing one. The wizard cannot check this, because Sunstone validates a required field even while the switch hides it. - A wrong entry in the initial users: A duplicate user name or uid, a missing password, a uid under 1000 or a name with capital letters stops the portal. The message quotes the entry.
- OneGate not reachable: A role that cannot reach OneGate never declares itself ready. The appliance tries
ONEGATE_ENDPOINTfrom the VM context first, then port 5030 on the VM’s default gateway./var/log/ood-appliance-configure.logrecords which one answered. Check that one of the two is reachable from the management network. - The storage role cannot reach the EESSI servers: It needs outbound HTTP on ports 80 and 8000.
- The portal cannot mount the home: The storage role grants the portal root on the export through OneGate, within about 20 seconds of the portal VM existing. If the portal still waits after three minutes, check OneGate.
- The portal cannot mount the Slurm state: The storage role exports
/export/slurmto the portal address in the same way. A portal still waiting after three minutes stops withcould not mountand the export in the message. - A worker never receives the munge key: The portal publishes it as
SLURM_MUNGE_KEYthrough OneGate. A worker that has waited 180 seconds for it stops withthe portal has not published SLURM_MUNGE_KEY after 180s, so check the portal first. - The service stays in
DEPLOYING_NETS: OneFlow never leaves that state when the VM template of a role no longer exists, for example after the template was deleted and the service template was not updated.oneflow showreports nothing, and the exception is only injournalctl -u opennebula-flowon the Front-end. Point the service template at an existing VM template and instantiate again. - The wrong address range: The portal takes the worker range from its compute interface, the /24 around its address. A compute network larger than a /24 needs
ONEAPP_POOL_RANGEset to a /24 slice of it. A standalone portal needsONEAPP_POOL_RANGEto match the network. The range also limits the number of Slurm nodes. A range that is not written asfirst-laststops the portal withONEAPP_POOL_RANGE must be "first-last"in/var/log/ood-appliance-configure.log.
A Session Does Not Start
- Check that every role is
RUNNING. - On the portal,
squeue -u <user>shows the job of the session.PENDINGwith reasonResourcesmeans no worker has the cores or the memory free. If the pool is growing, see The Pool Does Not Scale.PartitionConfigmeans no worker of the pool could ever run it, so lower the cores or the memory in the form. sinfo -Rlists the down or drained nodes with the reason. A nodedrainedwith reasonone-ondemand scale-downis about to be removed. A nodedown*has stopped answering the controller. Refer to A Worker Is Missing from sinfo.sacct -j <job id>shows how the job ended.NODE_FAILmeans its worker died, andOUT_OF_MEMORYmeans the session used more memory than it requested.- Read
output.login the session directory.module loaderrors mean a problem with the software catalogue, andPermission deniedon the home means a problem with the export./var/log/slurm/slurmd.logon the worker records why a job could not start there. - On the worker,
runuser -u <user> -- ls /cvmfs/software.eessi.io/versionsshows whether that user can reach the catalogue.
Users Cannot Sign In
On the portal, run systemctl status slapd ondemand-dex and ldapsearch -x -H ldap://localhost -b dc=ood,dc=local uid=<user>. A user who signs in but cannot open a session has no Unix account on the worker. There, getent passwd <user> has to answer through sssd. sssd asks the portal on port 389.
Check that the workers publish their attributes with onevm show, and read /var/log/one/oneflow.log on the Front-end. OneFlow writes a [AE] Checking policies for service: <id> line for every service every autoscaler_interval seconds, 90 by default, and oneflow show <service_id> --json keeps the time of the last evaluation in last_eval of each policy.
When those lines stop, or last_eval stays empty while the workers publish SLURM_PENDING above 0 or OLDEST_IDLE at 1, the evaluation thread of OneFlow has died. systemctl restart opennebula-flow on the Front-end starts it again without touching the service or its VMs. In OpenNebula 7.4.0 the thread dies within a minute of a Front-end reboot when a service is RUNNING and its VMs are still in POWEROFF, because the monitoring pool that oned returns has no record for them and role.rb stops on the empty entry. Nothing reaches oneflow.log. The only trace is a terminated with exception line in journalctl -u opennebula-flow. After a Front-end reboot, resume the VMs and then restart opennebula-flow, and check that the [AE] line appears again.
The pool grows only while the workers publish SLURM_PENDING above 0, and only up to max_vms. SLURM_PENDING counts the jobs waiting for cores or memory that a worker of the role could give them; a job waiting with reason PartitionConfig asks for more cores than the largest worker has and never counts.
The pool shrinks only when the oldest worker publishes OLDEST_IDLE=1, plus the five-minute cooldown of the scale down policy. The worker publishes it once it has drained its node, after ONEAPP_WORKER_IDLE_SECONDS without a job and nothing pending, and the node then shows as drained with reason one-ondemand scale-down in sinfo -R. A single worker never drains, and a drain that OneFlow does not act on within ONEAPP_WORKER_DRAIN_SECONDS is undone.
A worker whose node is missing from sinfo on the portal has not registered with the controller. On the worker, munge -n | unmunge has to succeed. Success proves it holds the key the portal published as SLURM_MUNGE_KEY. Invalid credential means the worker holds another key. munged loads a reinstalled /etc/munge/munge.key only after systemctl restart munge. journalctl -u slurmd shows why slurmd did not start or did not reach the controller. ood-portal in /etc/hosts has to resolve to the compute address of the portal, and port 6817 there has to answer.
scontrol delete and the reconciler both delete a node from the controller. A deleted node never returns on its own. The elastic loop of the worker therefore restarts slurmd when its node is absent from sinfo while munge and the controller answer. It does this at most once every five minutes, and the node registers again within seconds. A worker that reboots returns to idle on its own in under a minute. A worker that starts before its portal, for example when the VMs are resumed in the wrong order after a Host outage, cannot fetch its configuration at first. Its slurmd unit retries every 20 seconds until the controller answers, and the elastic loop also restarts a slurmd that is down.
The VMs Are in POWEROFF After a Host Reboot
OpenNebula does not resume the VMs on its own, and OneFlow shows the service in WARNING. Resume the storage VM, then the portal, then the workers. The service returns to RUNNING by itself, with its users, home directories and Slurm queue intact. Then restart opennebula-flow on the Front-end, because its evaluation thread dies during the reboot. Refer to The Pool Does Not Scale. A worker resumed before the portal joins the Cluster once the portal answers, because its slurmd keeps retrying.
