Front-end HA
OpenNebula provides a built-in mechanism to ensure high availability (HA) of the core Front-end daemon, oned. Services need to be deployed and configured across several hosts, and a distributed consensus protocol enforced to provide fault-tolerance and state consistency across them. Such deployment is resilient to the failure of at least a single host, depending on the total number of hosts.
In this section, you learn the basics of how to bootstrap a distributed highly available OpenNebula Front-end.
Raft Overview
This section covers some internals on how OpenNebula implements Raft. You do not need to know these details to effectively operate OpenNebula on HA. These details are provided for those who wish to learn about them to fine-tune their deployments.
A consensus algorithm is built around two concepts:
- System State - OpenNebula data stored in the database tables (users, ACLs, or the VMs in the system).
- Log - sequence of SQL statements that are consistently applied to the OpenNebula DB in all servers to evolve the system state.
To preserve a consistent view of the system across servers, modifications to the system state are performed through a special node, the leader. The servers in the OpenNebula cluster elect a single node to be the leader. The leader periodically sends heartbeats to the other servers, the followers, to keep its leadership. If a leader fails to send the heartbeat, followers are promoted to candidates and start a new election.
Whenever the system is modified (e.g. a new VM is added to the system), the leader updates the log and replicates the entry in a majority of followers before actually writing it to the database. The latency of DB operations is thus increased, but the system state is safely replicated and the cluster can continue its operation in case of node failure.
In OpenNebula, read-only operations can be performed through any oned server in the cluster and write operations issued to the follower nodes are forwarded to the leader node. This means that reads can be arbitrarily stale but generally within the round-trip time of the network.
Requirements and Architecture
The recommended deployment size is either three or five servers, which provides a fault-tolerance for one or two server failures, respectively. You can add, replace or remove servers once the cluster is up and running.
Every HA cluster requires:
- An odd number of servers (three is recommended).
- (Recommended) identical server capacities.
- The same software configuration of the servers. (The sole difference would be the
SERVER_IDfield in/etc/one/oned.conf.) - A working database connection of the same type. MySQL is recommended.
- All the servers must share the credentials.
- Floating IP which will be assigned to the leader.
- A shared filesystem.
The servers should be configured in the following way:
- Shared datastores must be mounted on all the nodes.
Bootstrapping the HA cluster
This section shows examples of all the steps required to deploy the HA Cluster.
Configuration of the initial leader
We start with the first server, to perform the initial system bootstrapping.
- Leader: Start OpenNebula
- Leader: Add the server itself to the zone:
$ onezone list
C ID NAME ENDPOINT
* 0 OpenNebula http://localhost:2633/RPC2
# We are working on Zone 0
$ onezone server-add 0 --name server-0 --rpc http://192.168.150.1:2633/RPC2
# It's now available in the zone:
$ onezone show 0
ZONE 0 INFORMATION
STATE : ENABLED
ZONE SERVERS
ID NAME ENDPOINT
0 server-0 http://192.168.150.1:2633/RPC2
HA & FEDERATION SYNC STATUS
ID NAME STATE TERM INDEX COMMIT VOTE FED_INDEX
0 server-0 solo 0 -1 0 -1 -1
ZONE TEMPLATE
ENDPOINT="http://localhost:2633/RPC2"
- Leader: Stop OpenNebula service and update
SERVER_IDin/etc/one/oned.conf
FEDERATION = [
MODE = "STANDALONE",
ZONE_ID = 0,
SERVER_ID = 0, # changed from -1 to 0 (as 0 is the server id)
MASTER_ONED = ""
- Leader: [Optional] Enable the RAFT Hooks in
/etc/one/oned.conf. This will add a floating IP to the system.
MONITOR_ADDRESS in /etc/one/monitord.conf# Executed when a server transits from follower->leader
RAFT_LEADER_HOOK = [
COMMAND = "raft/vip.sh",
ARGUMENTS = "leader eth0 10.3.3.2/24"
# Executed when a server transits from leader->follower
RAFT_FOLLOWER_HOOK = [
ARGUMENTS = "follower eth0 10.3.3.2/24"
- Leader: Start OpenNebula.
- Leader: Check the zone. The server is now the leader and has the floating IP:
$ onezone show 0
ZONE 0 INFORMATION
STATE : ENABLED
ZONE SERVERS
ID NAME ENDPOINT
0 server-0 leader 1 3 3 -1 -1
ZONE TEMPLATE
$ ip -o a sh eth0|grep 10.3.3.2/24
2: eth0 inet 10.3.3.2/24 scope global secondary eth0\ valid_lft forever preferred_lft forever
Adding more servers
- Leader: Create a DB backup in the initial leader and distribute it to the new server, along with the files in
/var/lib/one/.one/:
$ onedb backup -u oneadmin -p oneadmin -d opennebula
MySQL dump stored in /var/lib/one/mysql_localhost_opennebula_2017-6-1_11:52:47.sql
Use 'onedb restore' or restore the DB using the mysql command:
# Copy it to the other servers
$ scp /var/lib/one/mysql_localhost_opennebula_2017-6-1_11:52:47.sql <ip>:/tmp
# Copy the .one directory (make sure you preseve the owner: oneadmin)
$ ssh <ip> rm -rf /var/lib/one/.one
$ scp -r /var/lib/one/.one/ <ip>:/var/lib/one/
- Follower: Stop OpenNebula on the new server if it is running.
- Follower: Restore the database backup on the new server.
$ onedb restore -f -u oneadmin -p oneadmin -d opennebula /tmp/mysql_localhost_opennebula_2017-6-1_11:52:47.sql
- Leader: Add the new server to OpenNebula (in the initial leader) and note the server id.
$ onezone server-add 0 --name server-1 --rpc http://192.168.150.2:2633/RPC2
- Leader: Check the zone. The new server is in the error state, since OpenNebula on the new server is still not running. Make a note of the server id, in this case 1.
$ onezone show 0
ZONE 0 INFORMATION
STATE : ENABLED
ZONE SERVERS
ID NAME ENDPOINT
1 server-1 http://192.168.150.2:2633/RPC2
0 server-0 leader 1 19 19 -1 -1
1 server-1 error - - - -
ZONE TEMPLATE
- Follower: Edit
/etc/one/oned.confon the new server to set theSERVER_IDfor the new server. Make sure to enable the hooks as in the initial leader’s configuration. - Follower: Start the OpenNebula service.
- Leader: Run
onezone show 0to make sure that the new server is in follower state.
$ onezone show 0
ZONE 0 INFORMATION
STATE : ENABLED
ZONE SERVERS
ID NAME ENDPOINT
0 server-0 leader 1 21 19 -1 -1
1 server-1 follower 1 16 16 -1 -1
ZONE TEMPLATE
- Follower: Ensure the new node has the exact same configuration as the Leader node. In order to do this onezone serversync can be used to fetch the configuration from the Leader node.
systemctl restart opennebula-fireedge.Repeat this section to add new servers. Make sure that you only add servers when the cluster is in a healthy state. That means there is 1 leader and the rest are in follower state. If there is one server in error state, fix it before proceeding.
Checking Cluster Health
Execute onezone show <id> to see if any of the servers are in error state. If they are in error state, check /var/log/one/oned.log in both the current leader (if any) and in the host that is in error state. All Raft messages will be logged in that file.
If there is no leader in the cluster please review /var/log/one/oned.log to make sure there are no errors taking place.
Adding and Removing Servers
In order to add servers you need to use this command:
Command server-add requires one parameter to run
## USAGE
server-add <zoneid>
Add an OpenNebula server to this zone.
valid options: server_name, server_rpc
## OPTIONS
-n, --name Zone server name
-r, --rpc Zone server RPC endpoint
-v, --verbose Verbose mode
-h, --help Show this message
-V, --version Show version and copyright information
--user name User name used to connect to OpenNebula
--password password Password to authenticate with OpenNebula
--endpoint endpoint URL of OpenNebula xmlrpc frontend
Make sure that there is one leader (by running onezone show <id>), otherwise it will not work.
To remove a server, use the command:
$ onezone server-del
Command server-del requires 2 parameters to run.
## USAGE
server-del <zoneid> <serverid>
Delete an OpenNebula server from this zone.
## OPTIONS
The whole procedure is documented above.
Recovering Servers
When a follower is down for some time it may fall out of the recovery window, i.e. the log may not include all the records needed to bring it up to date. In order to recover this server you need to:
- Leader: Create a DB backup and copy it to the failed follower. Note that you cannot reuse a previous backup.
- Follower: Stop OpenNebula if it is running.
- Follower: Restore the DB backup from the leader.
- Follower: Start OpenNebula.
- Leader: Reset the failing follower with:
$ onezone server-reset <zone_id> <server_id_of_failed_follower>
Enable/Disable a Zone
During maintenance you may use onezone disable zone_id. Disabled zone can still execute read only commands, but can’t do any modifications to VMs, Hosts, Templates, etc. Right after onezone disable zone_id, there still can be VMs in transient states, it may take some time to finish all pending operations. To enable to zone again execute onezone enable zone_id.
Shared Data Between HA Nodes
HA deployment requires the filesystem view of most datastores (by default in /var/lib/one/datastores/) to be the same on all frontends. It is necessary to set up a shared filesystem over the datastore directories. This document doesn’t cover configuration and deployment of the shared filesystem; it is left completely up to the cloud administrator.
OpenNebula stores virtual machine logs inside /var/log/one/ as files named ${VMID}.log. It is not recommended to share the whole log directory between the Front-ends as there are also other OpenNebula logs which would be randomly overwritten. It is up to the cloud administrator to periodically back-up the virtual machine logs on the cluster leader, and in case of fail-over to restore from the backup of a new leader (e.g. as part of the raft hook). You can use the USE_VMS_LOCATION option in oned.conf to generate the log files in /var/lib/one/vms/${VMID}/vm.log, this could simplify the synchronization process across servers.
FireEdge
There are several types of FireEdge deployments in an HA environment. The basic one is FireEdge running on each OpenNebula Front-end node configured with the local OpenNebula. Only one server, the leader with floating IP, is used by the clients.
It is possible to configure a load balancer (e.g. HAProxy, Pound, Apache, or Nginx) over the Front-ends to spread the load (read operations) among the nodes.
To easily scale out beyond the total number of core OpenNebula daemons, FireEdge can be running on separate machines. They should talk to the cluster floating IP (see :one_xmlprc: in fireedge-server.conf) and shared /var/tmp/ between Fireedge and Front-end nodes. Please check Configuring FireEdge for Large Deployments.
FireEdge need to share the same /var/lib/one/.one/fireedge_key. This is covered by the above procedure. Additionally, to have all provision logs available in all HA nodes (hence, available on leader change), all nodes need to share the same /var/lib/one/fireedge folder.
Raft Configuration Attributes
The Raft algorithm can be tuned by several parameters in the configuration file /etc/one/oned.conf. The following options are available:
| Raft: Algorithm Attributes | |
LIMIT_PURGE | Number of DB log records that will be deleted on each purge. |
LOG_RETENTION | Number of DB log records kept, it determines the synchronization window across servers and extra storage space needed. |
LOG_PURGE_TIMEOUT | How often applied records are purged according the log retention value. (in seconds). |
ELECTION_TIMEOUT_MS | Timeout to start an election process if no heartbeat or log is received from the leader. Can be used to prioritize servers, server with lower value has higher chance to be selected as leader. |
BROADCAST_TIMEOUT_MS | How often heartbeats are sent to followers. |
XMLRPC_TIMEOUT_MS | To timeout raft-related API calls. To set an infinite timeout set this value to 0. |
Synchronize Configuration Files Across Servers
To synchronize files, you can use the command onezone serversync. This command is designed to help administrators to sync OpenNebula’s configurations across HA nodes and fix lagging nodes in HA environments. The command first checks for inconsistencies between local and remote configuration files inside the /etc/one/ directory. If inconsistencies are found, the local version of a file will be replaced by the remote version, and only the affected service will be restarted. Whole configuration files will be replaced, with the sole exception of /etc/one/oned.conf. For this file, the local FEDERATION configuration and optionally the RAFT configuration will be maintained, but the rest of the content will be overwritten. Before replacing any file, a backup will be made inside /etc/one/.
This is the list of files that will be checked and replaced:
Individual files:
/etc/one/monitord.conf/etc/one/oneflow-server.conf/etc/one/oneform-server.conf(optional)/etc/one/onegate-server.conf/etc/one/oneks-server.conf(optional)/etc/one/fireedge-server.conf(optional)
Optional files are synchronized only when they exist on both the local and remote Front-ends. If an optional file is missing on either side, the command reports it and continues. Missing required files, connection errors, and permission or transfer errors still cause the command to fail.
Folders:
/etc/one/auth/etc/one/hm/etc/one/schedulers/etc/one/vmm_exec
Usage
root (as it modifies the configuration files) and requires passwordless SSH access to the remote OpenNebula Front-end and to remote users root or oneadmin.# onezone serversync <remote_opennebula_server> [--db] [--keep-ha]
where <remote_opennebula_server> needs to be replaced by a hostname/IP of the OpenNebula server that will be used to fetch configuration files from. If --db option is used, the local database will be synced with the one located on remote server. If --keep-ha is used, the server will keep its own RAFT configuration
You also have to adjust the configuration file of each FireEdge /etc/one/fireedge-server.conf, to know which FireEdge corresponds to which zone.
default_zone:
endpoint: 'http://localhost:2633/RPC2'
Replace failing front-end
Follow this guide as the oneadmin user. To switch the user run:
sudo -i -u oneadmin
Back up files
This command has to be executed in the failing Host.
Create the backup directory:
BAK_DIR=~/one_backup
mkdir -p $BAK_DIR
Copy configuration directory /etc/one to backup directory:
cp -rp --parents /etc/one $BAK_DIR
Copy remotes directory /var/lib/one/remotes to backup directory:
cp -rp --parents /var/lib/one/remotes $BAK_DIR
Copy keys directory /var/lib/one/.one to backup directory:
cp -rp --parents /var/lib/one/.one $BAK_DIR
Back up the database:
onedb backup -S <database_host> -u <user> -p <password> -d <database_name> -P <port>
Copy the database backup file to the backup directory:
cp -rp <onedb_backup> $BAK_DIR
Remove failing Front-end from HA
Stop all the OpenNebula services systemctl stop opennebula*. This command has to be executed in the failing Host.
Remove it from HA using the CLI command onezone onezone server-del <zone_id> <server_id>. This command has to be executed in the leader.
Add the server back to the HA
To add the a replacement server into the HA cluster, please follow this guide.
