Ceph Datastore
The Ceph Datastore driver allows the use of Ceph storage for images and disks of Virtual Machines.
Ceph Cluster Setup
This guide assumes that you already have a functional Ceph Cluster in place. Additionally you need to:
  • Create a pool for the OpenNebula Datastores. Write down the name of the pool to include it in the datastore definitions.
ceph osd pool create one 128
ceph osd pool application enable one rbd
rbd pool init -p one
ceph osd lspools
0 data,1 metadata,2 rbd,6 one,
  • Define a Ceph user to access the datastore pool; this user will also be used by libvirt to access the disk images. For example, create the user libvirt:
ceph auth get-or-create client.libvirt \
      mon 'profile rbd' osd 'profile rbd pool=one'
Ensure the selected user has the proper capabilities. For example, for the above user libvirt you can do this by running:
ceph auth caps client.libvirt \
  • Get a copy of the key of this user to distribute it later to the OpenNebula Nodes.
ceph auth get-key client.libvirt | tee client.libvirt.key
ceph auth get client.libvirt -o ceph.client.libvirt.keyring
  • Although RBD format 1 is supported it is strongly recommended to use Format 2. Check that ceph.conf includes:
[global]
rbd_default_format = 2
  • Pick a set of client nodes of the cluster to act as storage bridges. These nodes will be used to import images into the Ceph Cluster from OpenNebula. These nodes must have the qemu-img command installed.
Front-end and Hosts Setup
In order to use the Ceph Cluster the Hosts need to be configured as follows:
  • The Ceph client tools must be available in the machine.
  • The mon daemon must be defined in the ceph.conf for all the nodes, so hostname and port doesn’t need to be specified explicitly in any Ceph command.
  • Copy the Ceph user keyring (ceph.client.libvirt.keyring) to the nodes under /etc/ceph, and the user key (client.libvirt.key) to the oneadmin home.
scp ceph.client.libvirt.keyring root@node:/etc/ceph
scp client.libvirt.key oneadmin@node:
Hosts Setup
Hosts need extra steps to set up credentials in libvirt:
  • Generate a secret for the Ceph user and copy it to the nodes under oneadmin home. Write down the UUID for later use:
UUID=`uuidgen`; echo $UUID
c7bdeabf-5f2a-4094-9413-58c6a9590980
cat > secret.xml <<EOF
<secret ephemeral='no' private='no'>
  <uuid>$UUID</uuid>
  <usage type='ceph'>
          <name>client.libvirt secret</name>
  </usage>
</secret>
EOF
scp secret.xml oneadmin@node:
  • Define a libvirt secret and remove key files in the nodes:
virsh -c qemu:///system secret-define secret.xml
virsh -c qemu:///system secret-set-value --secret $UUID --base64 $(cat client.libvirt.key)
rm client.libvirt.key
  • The oneadmin account needs to access the Ceph Cluster using the libvirt Ceph user defined above. This requires access to the Ceph user keyring. Test that the Ceph client is properly configured in the node:
ssh oneadmin@node
rbd ls -p one --id libvirt
You can read more information about this in the Ceph guide Using libvirt with Ceph.
  • Ancillary Virtual Machine files like context disks, deployment, and checkpoint files are created on the nodes under /var/lib/one/datastores/. Make sure that enough storage for these files is provisioned on the nodes.
  • If you are going to use the SSH mode, you have to take into account the space needed for the System Datastore /var/lib/one/datastores/<ds_id> where ds_id is the ID of the System Datastore.
LXC Hosts
The rbd-nbd utility must be installed on LXC hosts. Check the LXC Node Installation.
OpenNebula Configuration
To use your Ceph Cluster with the OpenNebula, you need to define both System and Image Datastores. Each Image/System Datastore pair will share the following same Ceph configuration attributes:
AttributeDescriptionMandatory
NAMEName of datastoreYES
POOL_NAMEThe Ceph pool name, by default oneNO
CEPH_USERThe Ceph user name, used by libvirt and rbd commands.YES
CEPH_KEYKey file for user, if not set default locations are
used
NO
CEPH_CONFNon-default Ceph configuration file if needed.NO
RBD_FORMATBy default RBD Format 2 will be used.NO
BRIDGE_LISTList of storage bridges to access the Ceph ClusterYES
CEPH_HOSTSpace-separated list of Ceph monitors. Example: host1<br/>host2:port2 host3 host4:port4.YES
CEPH_SECRETThe UUID of the libvirt secret.YES
EC_POOL_NAMEName of Ceph erasure coded poolNO
CEPH_TRASHEnables trash feature on given datastore,
values: yes
no
Create System Datastore
System Datastore also requires these attributes:
TYPESYSTEM_DSYES
TM_MADceph to use the full Ceph mode, see Ceph mode belowYES
ssh to use local Host storage, see SSH mode below
DISK_TYPERBD (used for volatile disks)NO
Create a System Datastore in Sunstone or through the CLI, for example:
cat systemds.txt
NAME    = ceph_system
TM_MAD  = ceph
TYPE    = SYSTEM_DS
DISK_TYPE = RBD
POOL_NAME   = one
CEPH_HOST   = "host1 host2:port2"
CEPH_USER   = libvirt
CEPH_SECRET = "6f88b54b-5dae-41fe-a43e-b2763f601cfc"
BRIDGE_LIST = cephfrontend
onedatastore create systemds.txt
Create Image Datastore
Apart from the previous attributes, which need to be the same as the associated System Datastore, the following can be set for an Image Datastore:
DS_MADcephYES
TM_MADcephYES
DISK_TYPERBDYES
STAGING_DIRDefault path for image operations in the bridgesNO
An example of datastore:
> cat ds.conf
NAME = "cephds"
DS_MAD = ceph
TM_MAD = ceph
DISK_TYPE = RBD
POOL_NAME   = one
CEPH_USER   = libvirt
> onedatastore create ds.conf
Additional Configuration
Default values for the Ceph drivers can be set in /var/lib/one/remotes/etc/datastore/ceph/ceph.conf:
  • POOL_NAME: Default volume group.
  • STAGING_DIR: Default path for image operations in the storage bridges.
  • RBD_FORMAT: Default format for RBD volumes.
  • DD_BLOCK_SIZE: Block size for dd operations (default: 64kB).
  • SUPPORTED_FS: Comma-separated list with every file system supported for creating formatted datablocks. Can be set in /var/lib/one/remotes/etc/datastore/datastore.conf.
  • FS_OPTS_<FS>: Options for creating the file system for formatted datablocks. Can be set in /var/lib/one/remotes/etc/datastore/datastore.conf for each file system type.
Using different modes
When creating a VM Template you can choose to deploy the disks using the default Ceph mode or the SSH one. Note that the same mode will be used for all disks of the VM. To set the deployment mode, add the following attribute to the VM template:
  • TM_MAD_SYSTEM="ssh"
When using Sunstone, the deployment mode needs to be set in the Storage tab.
Backup Format and Retention
For backup configuration and operations, see VM Backup Operations.
Ceph full backups use qcow2 files. Incremental chains created or reset on OpenNebula 7.0.1 or later also use qcow2, with increments generated from RBD snapshot differences. Both are registered with FORMAT=raw, despite storing qcow2 files.
With Restic and Rsync, KEEP_LAST consolidates the oldest required backups into a base and removes superseded restore points, retaining the last N backups without periodic chain resets. This involves processing backup data; Restic retrieves the required backups and uploads the consolidated base.
Legacy chains with FORMAT=rbd use native Ceph exports and do not support KEEP_LAST. Upgrades do not convert them automatically: use the backup operation’s --reset option after upgrading to start a qcow2-based chain. Older backup images remain until removed separately.
Datastore Internals
Images are stored in a Ceph pool, named after its OpenNebula ID one-<IMAGE ID>. Virtual Machine disks are stored by default in the same pool (Ceph Mode). You can also choose to export the Image rbd to the hypervisor local storage using the SSH Mode.
Ceph Mode (Default)
In this mode, Virtual Machines will use the same Image rbd volumes for their disks (persistent images), or a new snapshots of the image created in the form one-<IMAGE ID>-<VM ID>-<DISK ID> (non-persistent images).
For example, consider a system using an Image and System Datastore backed by a Ceph pool named one. The pool with one Image (ID 0) and two Virtual Machines 14 and 15 using this Image as virtual disk 0 would be similar to:
rbd ls -l -p one --id libvirt
NAME         SIZE PARENT         FMT PROT LOCK
one-0      10240M                  2
one-0@snap 10240M                  2 yes
one-0-14-0 10240M one/one-0@snap   2
one-0-15-0 10240M one/one-0@snap   2
SSH Mode
In this mode, the associated rbd file for each disk is exported to a file and stored in the local file system of the hypervisor.
For instance, in the previous example, if the VM 14 is set to be deployed in an SSH System Datastore (e.g., 100), the layout of the datastore in the hypervisor would be similar to:
ls -l /var/lib/one/datastores/100/14
total 609228
-rw-rw-r-- 1 oneadmin oneadmin        1020 Dec 20 14:41 deployment.0
-rw-r--r-- 1 oneadmin oneadmin 10737418240 Dec 20 15:19 disk.0
-rw-rw-r-- 1 oneadmin oneadmin      372736 Dec 20 14:41 disk.1
