Port Mirroring
Port mirroring copies selected Virtual Machine traffic to a monitoring destination without changing the original traffic flow. It can be used for packet capture, troubleshooting, or traffic analysis.
Mirrors belong to a Virtual Network and are supported only by the ovswitch and ovswitch_vxlan network drivers. Open vSwitch must be installed on every participating Host. Create the Virtual Network first, then configure mirrors in Sunstone or with the dedicated onevnet mirror-* commands. Run the OpenNebula CLI commands on the Front-end or a workstation with the OpenNebula client configured.
Mirror Types and Requirements
| Type | Destination | Requirements |
RSPAN | A dedicated output VLAN. | Provision the VLAN transport and collector on the physical network. OpenNebula does not configure external switches. |
GRE | A remote IPv4 collector, using a GRE tunnel. | Provide IP connectivity from each source Host to the collector and allow GRE traffic through intervening firewalls. |
ERSPAN | A remote IPv4 collector, using an ERSPAN type II or III tunnel. | The installed Open vSwitch and collector must support the selected ERSPAN type. Provide IP connectivity and allow GRE traffic. |
ovs-vswitchd log for maximum of 32 port mirrors reached and mirror ... configuration is invalid errors.Permissions
Mirror operations require ADMIN permission on the Virtual Network. Creating or updating a mirror also requires ADMIN permission on all selected source VMs. Adding or removing source ports requires ADMIN permission on the VMs specified in that request. Source ports must be regular VM NICs belonging to the mirror’s Virtual Network; NIC aliases, PCI NICs, and NICs of terminated VMs are not supported.
Mirror Template
Creation and update templates contain exactly one MIRROR vector. Names are mandatory, and unknown attributes are rejected. MIRROR_ID is assigned by OpenNebula and identifies the mirror within its Virtual Network.
Common Attributes
| Attribute | Description |
NAME | Required, nonempty mirror name. |
TYPE | Required: RSPAN, GRE, or ERSPAN. |
DIRECTION | IN, OUT, or BOTH; default BOTH. Direction is relative to the source VM: IN copies packets received by the VM, OUT copies packets sent by the VM, and BOTH copies both directions. |
PORTS | Optional comma-separated VM_ID:NIC_ID pairs. Duplicates are removed. After creation, change membership with mirror-addport and mirror-delport. |
VLANS | Optional comma-separated VLAN IDs from 0 to 4094. Ranges are not accepted. Duplicates are removed. |
DESCRIPTION | Optional description. |
Destination Attributes
Only include attributes applicable to the selected type.
| Type | Attribute | Mandatory | Description |
RSPAN | OUTPUT_VLAN | Yes | Output VLAN, from 1 to 4094. Use a dedicated VLAN for mirrored traffic. |
GRE, ERSPAN | REMOTE_IP | Yes | Collector IPv4 address; hostnames and IPv6 addresses are not accepted. |
GRE, ERSPAN | LOCAL_IP | Optional | Source IPv4 address on the hypervisor, or an interface reference such as interface:ovsbr0. If omitted, routing determines the source address. |
ERSPAN | ERSPAN_TYPE | Yes | II or III. |
ERSPAN | ERSPAN_KEY | Yes | Session identifier, entered in decimal, from 0 to 1023. |
ERSPAN type II | ERSPAN_INDEX | Optional | Index, entered in decimal, from 0 to 1048575; default 0. Not valid for type III. |
ERSPAN type III | ERSPAN_HWID | Optional | Hardware identifier, entered in decimal, from 0 to 63; default 0. Not valid for type II. |
An interface referenced by LOCAL_IP must exist on each participating Host and have exactly one usable IPv4 address. Resolution occurs on the hypervisor when the driver applies the mirror.
For a remote collector using ERSPAN type II, save the following template as mirror.txt. Replace the source VM and NIC IDs and collector address with values from your deployment:
MIRROR = [
NAME = "remote-capture",
TYPE = "ERSPAN",
PORTS = "210:1",
REMOTE_IP = "198.51.100.20",
ERSPAN_TYPE = "II",
ERSPAN_KEY = "10",
ERSPAN_INDEX = "0"
Selecting Traffic
A source port is identified by VM_ID:NIC_ID, for example 210:1. Obtain NIC IDs with onevm show. Source NICs must belong to the mirror’s Virtual Network.
PORTS | VLANS | Captured traffic |
| Nonempty | Empty | Traffic on the selected VM NICs, without a VLAN filter. |
| Nonempty | Nonempty | Traffic on the selected VM NICs that also matches the VLAN filter. |
| Empty | Nonempty | No traffic; the mirror is inactive. VLAN-only capture is not supported. |
| Empty | Empty | No traffic; the mirror is inactive. |
A VLAN filter restricts traffic on explicitly selected source NICs. It never selects other ports on the bridge. Removing the last source port deactivates the mirror configuration even when VLANS remains nonempty; see the RSPAN cache limitation below for traffic that may continue after removal. SPAN destinations and bridge-wide VLAN-only capture are not supported.
The VLANS filter uses VLAN IDs as seen by the OVS bridge. For an access-mode VM NIC, this is the VLAN assigned to its OVS port, even when the guest sends untagged frames. Use the Virtual Network’s VLAN_ID when filtering that traffic, or omit VLANS to capture all VLANs on the selected ports.
Managing Mirrors
The examples below use Virtual Network 5, mirror 0, and source NICs 210:1 and 212:0. Replace these IDs with your own. Creation prints the assigned mirror ID; use it in subsequent commands. Before creating or updating a mirror or changing its source ports, wait until the Virtual Network is in READY or UPDATE_FAILURE state. After each change, wait for the affected VM updates as described in Applying Changes to Running VMs before issuing the next change.
To create a mirror from mirror.txt and inspect its definition, run:
onevnet mirror-create 5 mirror.txt
onevnet show 5
You can also supply the creation template on standard input. To edit the current mirror configuration interactively, run:
onevnet mirror-update 5 0
To replace the configuration from a file, run:
onevnet mirror-update 5 0 mirror.txt
To merge attributes, use --append. For example, save MIRROR = [ DIRECTION = "OUT" ] as changes.txt, then run:
onevnet mirror-update 5 0 changes.txt --append
To add source NICs, run:
onevnet mirror-addport 5 0 210:1,212:0
To remove a source NIC, run:
onevnet mirror-delport 5 0 212:0
To delete this mirror, remove its remaining source first:
onevnet mirror-delport 5 0 210:1
Wait for Host cleanup to finish, then delete the empty definition:
onevnet mirror-delete 5 0
Mirrors cannot be introduced through onevnet create, onevntemplate create, or onevntemplate instantiate. General onevnet update cannot modify mirror definitions; use the dedicated commands. OpenNebula stores each selected mirror definition once in VM/TEMPLATE/MIRROR, including its NETWORK_ID and VNet-scoped MIRROR_ID. Participating NICs contain only MIRROR_IDS references. These values are managed by OpenNebula; onevm nic-update updates QoS attributes only and cannot change mirror configuration.
A mirror cannot be deleted while its PORTS list is nonempty. Remove all sources with mirror-delport first and wait for their updates to finish. mirror-update preserves source membership in both replacement and append mode; any supplied PORTS attribute is ignored. Use mirror-addport and mirror-delport to change membership.
Detaching a NIC or terminating its VM automatically removes that NIC from mirror source lists. Migration and temporary VM power-state changes preserve membership so that the driver can reconstruct capture when the source becomes active again. Sources on the same Host and bridge share one OVS mirror per VNet mirror definition.
Using Sunstone
In Sunstone, open Network -> Virtual Networks, select the Virtual Network, and open Port Mirroring.
- Click Create mirror. In Configuration, enter the name, mirror type, and destination settings.
- In Traffic source, select the direction, source VM interfaces, and optional VLAN filter.
- In Review, check the configuration and submit the form.
Select a mirror in the table to inspect its settings and source interfaces. Use Add source and Remove source in the mirror details to change membership; editing the configuration preserves the source list. Remove all sources and wait for their Host updates before deleting a mirror.
The available actions depend on the Sunstone view configuration and resource permissions. Sunstone operations use the same asynchronous update process as the CLI.
Mirror changes propagate asynchronously through the existing Virtual Network update action. Port membership changes update only VMs whose membership changed; adding an already selected port does not trigger another update. Inspect onevnet show for the network state and its updated, outdated, and failed VM lists. Wait for the affected VMs to be updated before checking packet capture. A successful API response alone does not mean the hypervisor has finished applying the change.
If an update fails, inspect the VM and driver logs, correct the template, connectivity, or Host configuration, then retry:
onevnet recover 5 --retry
Known Limitations
GRE and ERSPAN outputs are shared when their tunnel settings match on the same Host bridge. A tunnel with the same type, local and remote endpoints, and key but incompatible settings or a different bridge causes the Host update to fail. This also applies to conflicting tunnels configured outside OpenNebula. Use distinct ERSPAN session keys when separate outputs are needed; GRE has no configurable key in the mirror template. To change ERSPAN metadata on an output shared by other mirrors, use a distinct session key or remove the other mirror references to that output before updating it.
An Open vSwitch datapath cache issue can cause RSPAN traffic to continue reaching the collector after the last source port is removed, even though the OVSDB mirror has been removed successfully. This behavior has been reproduced on several OVS versions, including 3.3.9 and 3.6.1, and can persist for more than 30 seconds while traffic continues. No fixed minimum OVS version has been established.
A successful OpenNebula operation or an empty OVSDB Mirror table does not guarantee that mirrored traffic has stopped. Verify capture at the collector after removing sources or deleting a mirror. If traffic continues, inspect the affected Host’s OVS datapath and consult the OVS vendor for a fix. OpenNebula does not automatically purge cached datapath flows: a daemon-wide purge also affects unrelated networks. Manual cache cleanup is not a required step in the normal mirror deletion procedure.
Configuring a Linux Collector
A collector needs a capture interface and a packet capture tool such as tcpdump. GRE and ERSPAN collectors also need to decapsulate the mirrored Ethernet frames. A Linux collector can use kernel tunnel interfaces; Open vSwitch does not need to be installed on the collector.
For GRE and ERSPAN, the collector can be a host reachable from every participating hypervisor. RSPAN requires a Layer 2 path carrying the output VLAN to the collector.
Prerequisites and Addresses
Install iproute2 and tcpdump on the collector. Its kernel must support gretap for GRE or erspan for ERSPAN, including the selected ERSPAN version. These examples use the ip link options documented in iproute2 6.11 and the Linux 6.12 receive implementation. Run the interface configuration commands with root privileges.
The examples use these addresses; replace them with addresses from your deployment:
| Endpoint | Example IPv4 address |
| Collector | 192.0.2.10 |
| First hypervisor | 192.0.2.11 |
| Second hypervisor | 192.0.2.12 |
The collector address must already be assigned to its transport interface. Set REMOTE_IP = "192.0.2.10" in the mirror definition. Each receive interface’s remote address must match the outer source address used by that hypervisor: its LOCAL_IP if explicitly configured, otherwise the source selected by routing. On a hypervisor, ip -4 route get 192.0.2.10 shows the route-selected src address.
Allow GRE (IP protocol 47, not a TCP or UDP port) from the hypervisors to the collector through host and intervening firewalls. The underlay must accommodate the encapsulation overhead; use small test packets initially when checking connectivity. No address or bridge membership is needed on the capture interfaces.
GRE
Configure the mirror with TYPE = "GRE" and REMOTE_IP = "192.0.2.10", omitting all ERSPAN attributes. OVS mirrors Ethernet frames over GRE, so use a Linux gretap interface to receive them. Create a receive interface for each source hypervisor:
sudo ip link add name pm-gre1 type gretap local 192.0.2.10 remote 192.0.2.11
sudo ip link add name pm-gre2 type gretap local 192.0.2.10 remote 192.0.2.12
sudo ip link set dev pm-gre1 addrgenmode none
sudo ip link set dev pm-gre2 addrgenmode none
sudo ip link set dev pm-gre1 up promisc on
sudo ip link set dev pm-gre2 up promisc on
sudo tcpdump -ni pm-gre1 -e
Capture on pm-gre2 to observe traffic from the second hypervisor. Disabling IPv6 address generation keeps these capture interfaces unnumbered when brought up.
ERSPAN Type II
Configure the mirror with TYPE = "ERSPAN", ERSPAN_TYPE = "II", ERSPAN_KEY = "10", and, for this example, ERSPAN_INDEX = "7". Linux uses erspan_ver 1 for type II and key for the session identifier:
sudo ip link add name pm-er21 type erspan local 192.0.2.10 remote 192.0.2.11 oseq key 10 erspan_ver 1 erspan 7
sudo ip link add name pm-er22 type erspan local 192.0.2.10 remote 192.0.2.12 oseq key 10 erspan_ver 1 erspan 7
sudo ip link set dev pm-er21 addrgenmode none
sudo ip link set dev pm-er22 addrgenmode none
sudo ip link set dev pm-er21 up promisc on
sudo ip link set dev pm-er22 up promisc on
sudo tcpdump -ni pm-er21 -e
ERSPAN Type III
For type III, configure ERSPAN_TYPE = "III", ERSPAN_KEY = "20", and ERSPAN_HWID = "3". Linux uses erspan_ver 2:
sudo ip link add name pm-er31 type erspan local 192.0.2.10 remote 192.0.2.11 oseq key 20 erspan_ver 2 erspan_dir egress erspan_hwid 3
sudo ip link add name pm-er32 type erspan local 192.0.2.10 remote 192.0.2.12 oseq key 20 erspan_ver 2 erspan_dir egress erspan_hwid 3
sudo ip link set dev pm-er31 addrgenmode none
sudo ip link set dev pm-er32 addrgenmode none
sudo ip link set dev pm-er31 up promisc on
sudo ip link set dev pm-er32 up promisc on
sudo tcpdump -ni pm-er31 -e
oseq enables transmit sequencing without enforcing receive sequencing, so the collector also accepts traffic after a mirror is recreated and its sequence counter restarts.
The receiving tunnel is identified by the outer endpoint addresses and session ID. The index, hardware ID and direction are ERSPAN metadata, rather than additional receive-side filters. The Linux erspan/erspan_hwid/erspan_dir options describe metadata for packets transmitted through that interface; these examples keep the settings consistent with the sender. The collector is only used for capture. The mirror’s DIRECTION independently controls which VM traffic is copied.
See the iproute2 ERSPAN interface reference for the Linux interface options. The Linux ERSPAN receive implementation shows endpoint and session matching.
Capturing Payloads and Tunnel Headers
Capturing on a receive tunnel interface shows the decapsulated Ethernet frames. To save a capture, use sudo tcpdump -ni pm-er21 -s 0 -U -w mirror.pcap and generate recognizable traffic between the source VM and a peer. Use a separate terminal to start traffic after tcpdump reports that it is listening.
To inspect the outer GRE/ERSPAN headers, capture on the collector’s transport interface instead. Replace eth1 with the actual interface:
sudo tcpdump -ni eth1 -s 0 -vv 'ip proto 47 and dst host 192.0.2.10'
Use the outer capture to verify ERSPAN type, session ID, index or hardware ID. If outer packets arrive but the tunnel interface stays silent, check the configured endpoint addresses, session ID, kernel support, and collector firewall. Delete and recreate the receive interfaces when changing their endpoints or session ID.
RSPAN
For RSPAN, configure the mirror with TYPE = "RSPAN" and a dedicated OUTPUT_VLAN, for example OUTPUT_VLAN = "999". Arrange for that VLAN to reach the collector on a tagged trunk. The Host bridge uplink must carry the output VLAN, and intermediate switches must disable MAC learning on the RSPAN VLAN. See the OVS RSPAN requirements. If VLAN 999 arrives on eth1:
sudo ip link add link eth1 name pm-rspan type vlan id 999
sudo ip link set dev pm-rspan addrgenmode none
sudo ip link set dev pm-rspan up promisc on
sudo tcpdump -ni pm-rspan -e
RSPAN replaces the original VLAN tag with the output VLAN tag. This capture shows frames after removal of the transport VLAN tag. Capture on eth1 to inspect the tag itself. If an external switch delivers the RSPAN VLAN untagged on an access port, capture directly on that dedicated interface instead. Creating a VLAN interface alone does not provision the VLAN transport.
Cleanup
Stop capture processes, then remove only the interfaces created for the collector. For example, after the ERSPAN type II setup:
sudo ip link delete dev pm-er21
sudo ip link delete dev pm-er22
Use the corresponding names for GRE, ERSPAN type III, or RSPAN. These commands remove the collector interfaces; remove the OpenNebula mirror separately with onevnet mirror-delete when capture is no longer needed.
