Defining and Managing Virtual Networks
Commonly a Host is connected to one or more networks that are available to the VMs through bridges. OpenNebula allows the creation of Virtual Networks by mapping them on top of the physical ones.
Virtual Network Definition
A Virtual Network definition consists of three different parts:
  • The underlying physical network infrastructure that will support it, including the network driver.
  • The logical address space available. Addresses associated to a Virtual Network can be IPv4, IPv6, dual stack IPv4-IPv6, or Ethernet.
  • The guest configuration attributes to set up the Virtual Machine network, that may include for example network masks, DNS servers, or gateways.
Physical Network Attributes
To define a Virtual Network include:
  • Its name (NAME) to refer to this Virtual Network.
  • The driver (VN_MAD) to implement this Virtual Network. Depending on the driver you may need to set additional attributes, check the following to get more details:
  • QoS parameters (optional) for each NIC attached to the network, to limit the inbound/outbound average and peak bandwidths as well as the burst data size that can be transmitted at peak speed (see more details here).
For example, to define a 802.1Q Virtual Network you would add:
NAME    = "Private Network"
VN_MAD  = "802.1Q"
PHYDEV  = "eth0"
OUTBOUND_AVG_BW = "1000"
OUTBOUND_PEAK_BW = "1500"
OUTBOUND_PEAK_KB = "2048"
Address Space
The addresses available in a Virtual Network are defined by one or more Address Ranges (AR). Each AR defines a continuous address range and, optionally, configuration attributes that will override those defined in the Virtual Network. There are four types of ARs:
  • IPv4, to define a contiguous IPv4 address set (classless), see more details here
  • IPv6, to define global and ULA IPv6 networks, see full details here
  • IPv6 no-SLAAC, to define fixed 128 bits IPv6 address, see here
  • Dual stack, each NIC in the network will get both an IPv4 and an IPv6 address (SLAAC or no-SLAAC), see more here
  • Ethernet, just MAC addresses are generated for the VMs. You should use this AR when an external service is providing the IP addresses, such as a DHCP server, see more details here
Generated MAC address behavior is controlled by the MAC_PREFIX and optional MAC_GLOBAL_SPACE settings in oned.conf. MAC_GLOBAL_SPACE allocates generated MAC addresses from a global pool to prevent collisions across Virtual Networks. This does not apply to IP networks.
For example, to define the IPv4 address range 10.0.0.150 - 10.0.0.200
AR=[
    TYPE = "IP4",
    IP   = "10.0.0.150",
    SIZE = "51",
Shared Address Ranges (Shared AR) for Virtual IPs
Marking an Address Range as SHARED converts its IPs into Virtual IPs. This allows multiple VMs to use the same IP address.
To mark an Address Range as SHARED, add the SHARED attribute in the AR definition:
AR=[
    TYPE   = "IP4",
    IP     = "10.0.0.211",
    SIZE   = "3",
    SHARED = "YES"
The option to create a Shared AR is also available through a checkbox in the Sunstone UI in the Add Address Range dialog.
Shared Address Ranges behave slightly differently from regular Address Ranges:
  • Same IP, multiple VMs: The same IP address from a Shared AR can be used by more than one VM.
  • Explicit request required: Shared IPs are not assigned automatically. They must be explicitly requested in a NIC or NIC Alias (more details).
  • Attribute USED_LEASES shows how many different shared IPs are in use, not how many VMs are using them.
Guest Configuration Attributes (Context)
To set up the guest network, the Virtual Network may include additional information to be injected into the VM at boot time. These contextualization attributes may include, for example, network masks, DNS servers, or gateways. For example, to define a gateway and DNS server for the Virtual Machines in the Virtual Network, simply add:
DNS = "10.0.0.23"
GATEWAY = "10.0.0.1"
These attributes are automatically added to the VM and processed by the context packages. Virtual Machines just need to add:
CONTEXT = [
  NETWORK="yes"
See here for a full list of supported attributes
Virtual Network Definition Example
Putting all the three pieces together we get:
NAME    = "Private"
VN_MAD  = "802.1Q"
PHYDEV  = "eth0"
AR=[
    TYPE = "IP4",
    IP   = "10.0.0.150",
    SIZE = "51"
DNS     = "10.0.0.23"
DESCRIPTION = "A private network for VM inter-communication"
This file will create an IPv4 network using VLAN tagging, the VLAN ID in this case is assigned by OpenNebula. The network will lease IPs in the range 10.0.0.150 - 10.0.0.200. Virtual Machines in this network will get a lease in the range and configure DNS servers to 10.0.0.23 and 10.0.0.1 as default gateway.
See here for more examples
States and Life-cycle
The Virtual Network will be moving through different states to represent the actions you perform and their status. The following table summarizes the Virtual Network states and their meaning:
StateShort stateOpenNebula State NamesMeaning
ReadyrdyREADYVirtual Network is ready to be used
LockedlockLOCK_CREATEVirtual Network is being created/deleted. Driver operation is in progress.
LOCK_DELETE
ErrorerrERRORError state, an operation failed. See the Virtual Network information with onevnet show for an error message.
FailurefailUPDATE_FAILUREVirtual Network update fails to update some Virtual Machine NICs. ERROR_VMS contains list of failed VMs
Adding and Deleting Virtual Networks
There are three different ways for creating a network:
  • Creating the network from scratch.
  • Making a reservation from an existing network.
  • Instantiating a Virtual Network Template.
End users typically use the last two ways, instantiation and reservation. The administrator can define a network template to be instantiated later by the end user or create a Virtual Network from which the end user can make a reservation.
To create a new network from scratch, put its configuration in a file and then execute:
onevnet create priv.net
You can delete a Virtual Network using its ID or name:
onevnet delete 0
onevnet delete "Private"
To list the Virtual Networks in the system use onevnet list:
onevnet list
ID USER      GROUP       NAME        CLUSTER    BRIDGE    STATE  LEASES
 0 admin     oneadmin    Private     0,100      onebr.10  rdy         0
 1 admin     oneadmin    Public      0,101      vbr0      rdy         0
In the output above, USER is the owner of the network and LEASES the number of addresses assigned to a Virtual Machine or reserved.
You can check the details of a Virtual Network with the onevnet show command:
onevnet show 1
  VIRTUAL NETWORK 4 INFORMATION
  USER           : ruben
  GROUP          : oneadmin
  CLUSTERS       : 0
  BRIDGE         : onebr4
  STATE          : READY
  VN_MAD         : 802.1Q
  PHYSICAL DEVICE: eth0
  VLAN ID        : 6
  USED LEASES    : 0
  OWNER          : um-
  GROUP          : ---
  OTHER          : ---
  VIRTUAL NETWORK TEMPLATE
  BRIDGE="onebr4"
  DESCRIPTION="A private network for VM inter-communication"
  DNS="10.0.0.23"
  GATEWAY="10.0.0.1"
  PHYDEV="eth0"
  SECURITY_GROUPS="0"
  VN_MAD="802.1Q"
  ADDRESS RANGE POOL
  AR 0
  LEASES         : 0
  RANGE                                   FIRST                               LAST
  MAC                         02:00:0a:00:00:96                  02:00:0a:00:00:c8
  IP                                 10.0.0.150                         10.0.0.200
Check the onevnet command help or the reference guide for more options to list the Virtual Networks.
Group VLAN Rules
Group VLAN rules allow cloud administrators to delegate Virtual Network self-provisioning while restricting tenant VLAN usage within explicit ranges. Rules are defined per user group and are evaluated when a non-administrator:
  • Instantiates a Virtual Network template.
  • Updates a Virtual Network, including VLAN attributes in Address Ranges.
A group VLAN rule is defined with ID, SCOPE, and optionally VNTEMPLATE:
RULE = [
  ID         = "100-199",
  SCOPE      = "VLAN_ID",
  VNTEMPLATE = "10"
  • ID: Allowed VLAN values. Use a single value, a comma-separated list, or ranges, for example 100, 100,105, or 100-199.
  • SCOPE: VLAN attribute controlled by the rule. Supported values are VLAN_ID, OUTER_VLAN_ID, CVLAN, VLAN_TAGGED_ID, and ANY.
  • VNTEMPLATE: Virtual Network template IDs where the rule applies. Use a single ID, a comma-separated list, ranges, or -1 to apply the rule to any Virtual Network template. If omitted, OpenNebula sets it by default as -1.
For example, the following rule allows VLAN IDs 300, and 400 through 450, for any supported VLAN attribute and any Virtual Network template:
RULE = [
  ID         = "300,400-450",
  SCOPE      = "ANY",
  VNTEMPLATE = "-1"
To set the rules for a user group, create a file such as vlans.txt with the intended group VLAN rules as detailed above then run:
onegroup vlan <user_group_name> vlans.txt
If the file argument is omitted, onegroup vlan opens an editor with the current rules. Adjust this file to your preferences then save and close the editor, the onegroup vlan command will then execute upon closing the editor.
When users belong to more than one group, a requested VLAN value is accepted if any of their groups has a matching rule. A rule only authorizes values within its own scope, except for ANY, which matches all supported VLAN scopes. VLAN_ID and OUTER_VLAN_ID must be single values; CVLAN and VLAN_TAGGED_ID can use the same range syntax as rule IDs.
Virtual Network Tips
  • You may have some used IPs in a VNET so you do not want them to be assigned. You can add as many ARs as you need to implement these address gaps. Alternatively you can put address on hold to prevent them from being assigned.
  • ARs can be of SIZE = 1 to define single addresses lease scheme.
  • ARs does not need to be of the same type or belong to the same IP network. To accommodate this use case you can overwrite context attributes in the AR, for example by adding attributes like NETWORK_MASK or DNS in the AR definition.
  • Super-netting, you can even combine ARs overwriting the physical attributes, e.g., BRIDGE or VLAN_ID. This way a Virtual Network can be a logical super-net, e.g., DMZ, that can be implemented through multiple VLANs each using a different hypervisor bridge.
  • There is no need to design all your IP assignment plan beforehand, as ARs can be added and modified after the Virtual Network is created, see below.
  • Orphan Virtual Networks (i.e., Virtual Networks not referenced by any template) can be shown with onevnet orphans command.
Updating a Virtual Network
After creating a Virtual Network, you can use the onevnet update command to update its attributes. The name of the Virtual Network can be changed with onevnet rename command.
The update operation will trigger driver action to live update the network configuration for all Virtual Machines with leases in the Virtual Network. The attributes that can be live-updated depends on the driver configured for the Virtual Network, see the following table:
Network DriverLive-update Attributes
OpenvSwitch
OpenvSwitch VXLAN
- VLAN_ID
- PHYDEV
- MTU
- VLAN_TAGGED_ID
- CVLANS
- QINQ_TYPE
- INBOUND_AVG_BW
- INBOUND_PEAK_BW
- INBOUND_PEAK_KB
- OUTBOUND_AVG_BW
- OUTBOUND_PEAK_BW
bridge- PHYDEV
- VLAN_TAGGED_ID
fw- PHYDEV
- INBOUND_AVG_BW
- INBOUND_PEAK_BW
- INBOUND_PEAK_KB
- OUTBOUND_AVG_BW
- OUTBOUND_PEAK_BW
802.1Q
vxlan
- PHYDEV
- VLAN_ID
- MTU
- INBOUND_AVG_BW
- INBOUND_PEAK_BW
- INBOUND_PEAK_KB
- OUTBOUND_AVG_BW
- OUTBOUND_PEAK_BW
As the network is updated for each VM and Host, you can check the progress of the update in Virtual Network details:
  • UPDATED_VMS, list of VM IDs already updated.
  • UPDATING_VMS, list of VM IDs that are being updated (driver action in execution).
  • OUTDATED_VMS, list of VM IDs with outdated Virtual Network configuration.
  • ERROR_VMS lists of VM IDs where the update operation failed.
In case of driver action failure, the Virtual Network will switch to UPDATE_FAILURE state. In that case you can use onevnet recover --retry to re-launch the driver actions for failed VMs. Or manually fix the network and call onevnet recover --success.
Managing Address Ranges
Addresses are structured in Address Ranges (AR). Address Ranges can be dynamically added or removed from a Virtual Network. In this way, you can easily add new addresses to an existing Virtual Network if the current addresses are exhausted.
Adding and Removing Address Ranges
A new AR can be added using exactly the same definition parameters as described above. For example, the following command will add a new AR of 20 IP addresses:
onevnet addar Private --ip 10.0.0.200 --size 20
In the same way you can remove an AR:
onevnet rmar Private 2
Updating Address Ranges
You can update the following attributes of an AR:
  • SIZE, assigned addresses cannot fall outside of the range.
  • IPv6 prefix: GLOBAL_PREFIX and ULA_PREFIX
  • Any custom attribute that may override the Virtual Network defaults.
The following command shows how to update an AR using the CLI, an interactive editor session will be stated:
onevnet updatear Private 0
Hold and Release Leases
Addresses can be temporarily be marked as hold. They are still part of the network but they will not be assigned to any Virtual Machine.
To do so, use the onevnet hold and onevnet release commands. By default, the address will be put on hold in all ARs containing it; if you need to hold the IP of a specific AR you can specify it with the ‘-a <AR_ID>’ option:
#Hold IP 10.0.0.120 in all ARs
onevnet hold "Private Network" 10.0.0.120
#Hold IP 10.0.0.123 in AR 0
onevnet hold 0 10.0.0.123 -a 0
You see the list of leases on hold with the onevnet show command; they’ll show up as used by Virtual Machine -1, ‘V: -1’
Using Virtual Networks
Once the Virtual Networks are set up, they can be made available to users based on access rights and ownership. The preferred way to do so is through Virtual Data Center abstraction. By default, all Virtual Networks are automatically available to the group users.
Virtual Networks can be used by VMs in two different ways:
  • Manual selection: NICs in the VMs are attached to a specific Virtual Network.
  • Automatic selection: Virtual Networks are scheduled like other resources needed by the VM (like Hosts or datastores).
Manually Attach a Virtual Machine to a Virtual Network
To attach a Virtual Machine to a Virtual Network simply specify its name or ID in the NIC attribute. For example, to define VM with a network interface connected to the Private Virtual Network, just include in the template:
NIC = [ NETWORK = "Private" ]
Equivalently you can use the network ID as:
NIC = [ NETWORK_ID = 0 ]
The Virtual Machine will also get a free address from any of the address ranges of the network. You can also request a specific address just by adding the IP or MAC to NIC. For example, to put a Virtual Machine in the network Private and request 10.0.0.153, use:
NIC = [ NETWORK = "Network", IP = 10.0.0.153 ]
Automatic Attach a Virtual Machine to a Virtual Network
You can delay the network selection for each NIC in the VM to the deployment phase. In this case the Scheduler will pick the Virtual Network among the available networks in the Host selected to deploy the VM.
This strategy is useful to prepare generic VM templates that can be deployed in multiple OpenNebula clusters.
To set the automatic selection mode, simply add the attribute NETWORK_MODE = "auto" into the NIC attribute.
NIC = [ NETWORK_MODE = "auto" ]
Also you can add SCHED_REQUIREMENTS and SCHED_RANK when this mode is activated. This will let you specify which networks can be used for a specific NIC (SCHED_REQUIREMENTS) and what your preferences are (SCHED_RANK) to select a network among the suitable ones.
NIC = [ NETWORK_MODE = "auto",
        SCHED_REQUIREMENTS = "TRAFFIC_TYPE = \"public\" & INBOUND_AVG_BW<1500",
        SCHED_RANK = "-USED_LEASES" ]
In this case the scheduler will look for any Virtual Network in the selected cluster with a custom tag TRAFFIC_TYPE to be equal to public and INBOUND_AVG_BW less than 1500. Among all the networks that satisfy these requirements the scheduler will select the one with the most free leases.
Attach an NIC Alias to a Virtual Machine
To attach an NIC alias to a VM you need to refer to the parent NIC by its NAME attribute:
NIC = [ NETWORK = "public", NAME = "test" ]
Then you can attach an alias using an NIC_ALIAS attribute:
NIC_ALIAS = [ NETWORK = "private", PARENT = "test" ]
If the nic NAME is empty, it will be generated automatically in the form NIC${NIC_ID}. This name can be also used to create an alias, e.g., NIC_ALIAS = [ NETWORK = "private", PARENT = "NIC0" ]
Using Virtual IPs
To request a Virtual IP (VIP) from a Shared Address Range you must explicity request the IP in a NIC or NIC_ALIAS attribute. The most natural way of using Shared Address Ranges for VIPs is to define a primary NIC in the network with a regular IP and a NIC Alias with the VIP, this way you get a single network interface with two different IPs. The procedure is described below:
  1. Define the primary NIC and give it a NAME so aliases can refer to it:
NIC = [ NETWORK = "private", NAME = "main" ]
  1. Add a NIC_ALIAS that explicitly requests the shared IP from the Shared AR (you must include the IP attribute):
NIC_ALIAS = [ NETWORK = "private", PARENT = "main", IP = "10.0.0.211" ]
This will result in the VM having a single network interface (the parent NIC) with two IPs configured:
  • The IP assigned to the main NIC
  • The explicitly requested shared IP from the NIC_ALIAS
Configuring the Virtual Machine Network
Hypervisors will set the MAC address for the NIC of the Virtual Machines, but not the IP address. The IP configuration inside the guest is performed by the contextualization process, check the contextualization guide to learn how to prepare your Virtual Machines to automatically configure the network
Recovering the Virtual Network
In case the Virtual Network is not in READY state, use onevnet recover to fix the Virtual Network. The command accepts the following flags:
  • --failure Driver action wasn’t completed successfully, move the Virtual Network to ERROR state.
  • --success User manually fixed the issue, move the Virtual Network to READY state.
  • --delete The Virtual Network can’t be fixed, delete it.
  • --retry Retry the last driver action. Allowed only in UPDATE_FAILURE state.
Using Sunstone to Manage Virtual Networks
You can also manage your Virtual Networks using the Sunstone GUI. Select the Virtual Networks tab to create, enable, and operate your Virtual Networks in a user-friendly way.
Sunstone Virtual Networks listSunstone Virtual Networks list
  • Create new Virtual Networks using the + Create Virtual Network button, you can choose to create a new network fro scratch or from an existing template:
Sunstone Virtual Networks createSunstone Virtual Networks create
  • If you are creating a Virtual Network from scratch, fill in the details in each step of the creation wizard:
    • General details:
    Sunstone Virtual Networks create general stepSunstone Virtual Networks create general step
    • Advanced details:
    Sunstone Virtual Networks create advanced stepSunstone Virtual Networks create advanced step
  • If creating a Virtual Network from a template, choose your preferred template from the menu:
Sunstone Virtual Networks create from templateSunstone Virtual Networks create from template
Port Mirroring
Port mirroring copies selected Virtual Machine traffic to a monitoring destination for packet capture or traffic analysis. In Sunstone, it is available for existing Open vSwitch Virtual Networks using the ovswitch or ovswitch_vxlan driver. Mirrors are managed after the Virtual Network has been created, rather than through network creation or Virtual Network Templates.
Before creating a mirror, see the Port Mirroring guide for collector prerequisites, destination settings, traffic direction, and VLAN filtering.
Open Networks -> Virtual networks, select a network, and open its Port Mirroring tab. Click Create mirror and complete the following three steps:
  1. Configuration: Enter a name, choose RSPAN, GRE, or ERSPAN, and configure its destination. The destination fields depend on the selected type; ERSPAN supports types II and III.
  2. Traffic Source: Choose the traffic direction (Both, In, or Out), select source VM interfaces, and optionally enter source VLAN IDs. Only VMs with an interface on the current network are listed. If a VM has one matching interface, it is selected automatically; otherwise, choose an interface. Use Add source to include more interfaces.
  3. Review: Check the network, configuration, and traffic sources before confirming. Use the edit actions to return to the corresponding step.
Select a mirror in the list to open its details alongside the parent network. The details show its settings, source interfaces, and source VLANs. Use Add source or the remove action on an interface to change its source membership. The toolbar provides actions to edit the mirror settings, refresh its details, or delete it. The mirror type cannot be changed when editing, and source interfaces are managed from the details rather than the settings form.
To delete a mirror, remove all its source interfaces first and wait for their updates to finish. Then use Delete mirror and confirm the deletion. Deletion fails if any source interfaces remain selected.
Changes are applied asynchronously to the affected VMs. Wait for the Virtual Network update to complete before checking captured traffic.
The tab and its actions are controlled by info-tabs.port_mirroring in the vnet-tab.yaml file of each Sunstone view. Enabling an action does not grant permissions: mirror management requires ADMIN permission on the Virtual Network. Creating a mirror or updating its settings also requires ADMIN permission on all selected source VMs. Adding or removing source interfaces requires ADMIN permission on the VMs specified in that request.
