Diff Formats
The configuration management tool onecfg allows us to compare the configuration files to identify user changes against the OpenNebula distributed files. The result of a comparison, the differential output, describes all the individual changes which were made and which can even be applied again later or on a different machine.
The following table shows supported formats by each subcommand:
| Format | Description | onecfg diff | onecfg patch |
text | Easy human-readable text | YES (default) | NO |
line | Single line for one change | YES | YES (default) |
yaml | Complete change structure | YES | YES |
Only line format will be described here in detail, as it’s powerful in achieving even complex changes and easy enough to read or write manually.
Line Format
Each line of change consists of the following space-separated parts:
<FILENAME> <COMMAND> <PATH> [<JSON VALUE>]
with the following meanings:
FILENAME
Filename is an absolute path to the well-known configuration file of OpenNebula that is going to be changed.
COMMAND
Command is a type of operation to be executed on the configuration file. Only the following commands are available:
ins- insert new configuration parameterset- change existing parameterrm- remove parameter
PATH
Path uniquely identifies the location of the changed parameter as a slash / separated XPath-like segments and key from document root and without leading slash (e.g., path/path/path/key). If any path element contains spaces, the whole path must be quoted with (and only with!) double quotes ("), internal double quotes must be escaped by backslash (\).
: are transformed into Ruby symbols.Examples:
- for the following
/etc/one/oned.confsnippet
PORT = 2633 # path 1
DB = [ BACKEND = "sqlite", # path 2
TIMEOUT = 2500 ]
IM_MAD = [
NAME = "monitord",
EXECUTABLE = "onemonitord",
ARGUMENTS = "-c monitord.conf",
THREADS = 8 ] # path 3
these paths are valid to address the emphasized parameters:
PORTDB/BACKENDor"DB/BACKEND"IM_MAD/"monitord"/THREADSor"IM_MAD/\"monitord\"/THREADS"
oned.conf-like configurations, some nested structures are unique (e.g., DB=[...] is just a single database connection configuration) and some can appear several times (e.g., VM_MAD=[...] configures execution of different drivers for different hypervisors, one section for each driver). In the second case, the nested structure is uniquely addressed by a value of one identifying parameter inside the structure, usually NAME. This value (including the quotes) is placed as part of the path. See path 3 above.- for the following
/etc/one/fireedge-server.confsnippet
# OpenNebula: use it if you have oned and fireedge on different servers
:one_xmlrpc: http://localhost:2633/RPC2 # path 4
these paths are valid to address the emphasized parameter(s):
:one_xmlrpcor":one_xmlrpc"
- for the following
/etc/one/cli/oneimage.yamlsnippet
:ID:
:desc: ONE identifier for the Image # path 5
:size: 4
:adjust: true
:IP/:descor":IP/:desc"
") to enclose paths that include spaces. Single quotes (') are always understood as part of the string.JSON VALUE
The value encoded in JSON is mandatory only for ins and set commands. It can contain simple values or complex structures, string values must be quoted with (and only with!) double quotes (").
Examples:
- no text is an uninitialized value
null- uninitialized value11- Integer value11"11"- String value11'11'- invalid JSON value!"'11'"- String value'11'"\"11\"- String value"11"(strings with inner quotes must be escaped)true- Boolean valuetrue"true"- String valuetrue["apple", "orange"]- Array with 2 String valuesappleandorange['apple', 'orange"]- invalid JSON value!{"fruit": "apple"}- Hash with keyfruitwith valueapple{'fruit': 'apple'}- invalid JSON value!
"\"quoted string\"'). This is usually seen in the oned.conf-like configuration files.Examples
# onecfg diff --format line
/etc/one/cli/oneimage.yaml ins :ID/:adjust false
/etc/one/cli/oneimage.yaml set :USER/:size 15
/etc/one/cli/oneimage.yaml set :GROUP/:size 15
/etc/one/cli/oneimage.yaml ins :NAME/:expand false
/etc/one/oned.conf set DEFAULT_DEVICE_PREFIX "\"sd\""
/etc/one/oned.conf ins HM_MAD/ARGUMENTS "\"-p 2101 -l 2102 -b 127.0.0.1\""
/etc/one/oned.conf ins VM_RESTRICTED_ATTR "\"NIC/FILTER\""
How to read the output? Let’s go through few examples from above:
/etc/one/cli/oneimage.yaml ins :ID/:adjust false- add new key:adjustwith Boolean valuefalseinto top Hash structure:ID/etc/one/cli/oneimage.yaml set :USER/:size 15- value for existing key:sizeinside top Hash structure:USERchanges to15
Text Format
Text format is similar to line format with visually separated sections for each configuration file and without a redundant filename on each line. It’s easier to read by humans but can’t be used as an input of the patch subcommand.
Example
# onecfg diff --format text
- ins :ID/:adjust false
- set :USER/:size 15
- set :GROUP/:size 15
- ins :NAME/:expand false
/etc/one/oned.conf
- set DEFAULT_DEVICE_PREFIX "\"sd\""
- ins HM_MAD/ARGUMENTS "\"-p 2101 -l 2102 -b 127.0.0.1\""
- ins VM_RESTRICTED_ATTR "\"NIC/FILTER\""
YAML Format
Contains complete information about the changes, the old original and new values, position (index) of value within an array, and even preserves symbolized keys and values (which are used in several configuration files). This format is recommended for use if it’s expected to identify and apply (patch) changes most accurately.
Example
# onecfg diff --format yaml
patches:
"/etc/one/cli/oneimage.yaml":
class: Yaml::Strict
change:
- path:
- :ID
key: :adjust
value: false
state: ins
extra: {}
- path:
- :USER
key: :size
value: 15
old: 8
state: set
extra: {}
- path:
- :GROUP
key: :size
value: 15
old: 8
state: set
extra: {}
- path:
- :NAME
key: :expand
value: false
state: ins
extra: {}
