OpenNebula Repositories for Enterprise Edition
OpenNebula Systems provides the OpenNebula Enterprise Edition (EE) to customers with an active support subscription. To distribute the packages of the Enterprise Edition there is a private repository accessible only to Enterprise Edition customers that contains all packages (including major, minor, and maintenance releases). You only need to change your repository configuration on your OpenNebula Front-end once per major release and you’ll have access to every package in that series. OpenNebula’s private repositories contain all OpenNebula released packages.
AlmaLinux/RHEL
Some dependencies require enabling the CodeReady Linux Builder repository:
crb enable
To add the OpenNebula Enterprise Edition repository, execute the following commands for your respective OS as user root:
RHEL 9, 10
cat << "EOT" > /etc/yum.repos.d/opennebula.repo
[opennebula]
name=OpenNebula Enterprise Edition
baseurl=https://enterprise.opennebula.io/repo/7.2/RedHat/$releasever/$basearch
username=<user>
password=<password>
enabled=1
gpgkey=https://downloads.opennebula.io/repo/repo2.key
gpgcheck=1
repo_gpgcheck=1
EOT
chmod 600 /etc/yum.repos.d/opennebula.repo
dnf makecache
AlmaLinux 9, 10
[opennebula]
baseurl=https://enterprise.opennebula.io/repo/7.2/AlmaLinux/$releasever/$basearch
username=<user>
password=<password>
enabled=1
gpgcheck=1
repo_gpgcheck=1
EOT
dnf makecache
Debian/Ubuntu
First, add the repository signing GPG key on the Front-end by executing as user root:
wget -q -O- https://downloads.opennebula.io/repo/repo2.key | gpg --dearmor --yes --output /etc/apt/keyrings/opennebula.gpg
And then continue with repository configuration:
Debian 12
cat << "EOT" > /etc/apt/auth.conf.d/opennebula.conf
machine enterprise.opennebula.io
login <user>
password <password>
EOT
chmod 600 /etc/apt/auth.conf.d/opennebula.conf
echo "deb [signed-by=/etc/apt/keyrings/opennebula.gpg] https://enterprise.opennebula.io/repo/7.2/Debian/12 stable opennebula" > /etc/apt/sources.list.d/opennebula.list
apt-get update
Debian 13
login <user>
password <password>
EOT
echo "deb [signed-by=/etc/apt/keyrings/opennebula.gpg] https://enterprise.opennebula.io/repo/7.2/Debian/13 stable opennebula" > /etc/apt/sources.list.d/opennebula.list
apt-get update
Ubuntu 22.04
login <user>
password <password>
EOT
echo "deb [signed-by=/etc/apt/keyrings/opennebula.gpg] https://enterprise.opennebula.io/repo/7.2/Ubuntu/22.04 stable opennebula" > /etc/apt/sources.list.d/opennebula.list
apt-get update
Ubuntu 24.04
login <user>
password <password>
EOT
echo "deb [signed-by=/etc/apt/keyrings/opennebula.gpg] https://enterprise.opennebula.io/repo/7.2/Ubuntu/24.04 stable opennebula" > /etc/apt/sources.list.d/opennebula.list
apt-get update
SUSE
SUSE Linux Enterprise Server 15 SP7
Execute the following as user root:
arch=$(uname -m)
SUSEConnect -p PackageHub/15.7/$arch
SUSEConnect -p sle-module-desktop-applications/15.7/$arch
SUSEConnect -p sle-module-public-cloud/15.7/$arch
rpm --import https://downloads.opennebula.io/repo/repo2.key
mkdir -p /etc/zypp/credentials.d
cat << "EOT" > /etc/zypp/credentials.d/opennebula.conf
username=<user>
password=<password>
EOT
chmod 600 /etc/zypp/credentials.d/opennebula.conf
cat << "EOT" > /etc/zypp/repos.d/opennebula.repo
[opennebula]
enabled=1
autorefresh=1
baseurl=https://enterprise.opennebula.io/repo/7.2/SLES/15/$basearch?credentials=opennebula.conf
gpgcheck=1
repo_gpgcheck=1
EOT
zypper refresh
openSUSE Leap 16.0
openSUSE Leap 16.0 requires the OpenNebula repository and the openSUSE Science repository for SciPy. Execute the following as user root:
username=<user>
password=<password>
EOT
[opennebula]
enabled=1
autorefresh=1
baseurl=https://enterprise.opennebula.io/repo/7.2/openSUSE/16/$basearch?credentials=opennebula.conf
gpgcheck=1
repo_gpgcheck=1
EOT
zypper ar -f https://download.opensuse.org/repositories/science/openSUSE_Leap_16.0/ science
zypper refresh
