OpenNebula Repositories
Before you can proceed with installation, you must configure the packaging tools on your Front-end Host to include OpenNebula repositories. OpenNebula software is provided via two distinct distribution channels depending on the build type you intend to install:
Choose the page matching the OpenNebula edition you intend to deploy:
