KVM Node Installation
This page demonstrates how to configure an OpenNebula KVM Node from binary packages.
Overview
KVM (Kernel-based Virtual Machine) is the main virtualization solution for Linux on x86 hardware that contains virtualization extensions (Intel VT or AMD-V) and on ARM64 (currently in beta mode). It consists of the loadable KVM kernel modules (one that provides the core virtualization infrastructure and several processor-specific modules), but the complete KVM virtualization stack usually also contains the user-space machine hardware emulator QEMU accelerated by the KVM and Virtual Machines management tool libvirt.
By using KVM, you can run multiple Virtual Machines with unmodified Linux or Windows images. Each Virtual Machine has private virtualized hardware – network card, disk, graphics adapter, etc.
To understand the specific requirements, functionalities, and limitations of the KVM driver, see KVM Driver.
You can then check the Storage and Networking system configuration sections to deploy Virtual Machines on your KVM nodes and access them remotely over the network.
Step 1. Add OpenNebula Repositories
Refer to OpenNebula Repositories guide to add the Enterprise and Community Edition software repositories.
Step 2. Installing the Software
Installing on AlmaLinux/RHEL
Repository EPEL
OpenNebula depends on packages which aren’t in the base distribution repositories. Execute one of the commands below (distinguished by the Host platform) to configure access to additional EPEL (Extra Packages for Enterprise Linux) repository:
AlmaLinux 9, 10
yum -y install epel-release
RHEL 9
rpm -ivh https://dl.fedoraproject.org/pub/epel/epel-release-latest-9.noarch.rpm
Install OpenNebula KVM Node Package
Execute the following commands to install the OpenNebula KVM Node package and restart libvirt to use the OpenNebula-provided configuration file:
yum -y install opennebula-node-kvm
systemctl restart libvirtd
For further configuration, check the specific guide.
Installing on Debian/Ubuntu
apt-get update
apt-get -y install opennebula-node-kvm
For further configuration check the specific guide.
Installing on SLES/openSUSE
Execute the following command to install the OpenNebula KVM Node package:
zypper install opennebula-node-kvm
Step 3. Host OS Security Configuration (Optional)
Disable SELinux on AlmaLinux/RHEL
Depending on the type of OpenNebula deployment, the SELinux can block some operations initiated by the OpenNebula Front-end, which results in a failure of the particular operation. It’s not recommended to disable the SELinux on production environments, as it degrades the security of your server, but to investigate and work around each individual problem based on the SELinux User’s and Administrator’s Guide. The administrator might disable the SELinux to temporarily work around the problem or on non-production deployments by changing the following line in /etc/selinux/config:
SELINUX=disabled
After the change you have to reboot the machine.
  • package util-linux newer than 2.23.2-51 installed
  • SELinux boolean virt_use_nfs enabled (with datastores on NFS):
setsebool -P virt_use_nfs on
Disable AppArmor on Ubuntu/Debian
Depending on the type of OpenNebula deployment, the AppArmor can block some operations initiated by the OpenNebula Front-end, which results in a failure of the particular operation. It’s not recommended to disable the apparmor on production environments, as it degrades the security of your server, but to investigate and work around each individual problem. A good starting point is AppArmor HowToUse Guide. The administrator might disable the AppArmor to temporarily work around the problem or on non-production deployments the steps for disabling it can be found here.
/var/lib/one/datastores/** rwk,
Step 4. Configure Passwordless SSH
The OpenNebula Front-end connects to the hypervisor nodes using SSH. The following connection types are being established:
  • from Front-end to Front-end,
  • from Front-end to hypervisor node,
  • from Front-end to hypervisor node with another connection within to another node (for migration operations),
  • from Front-end to hypervisor node with another connection within back to Front-end (for data copy back).
When OpenNebula server package is installed on the Front-end, a SSH key pair is automatically generated for the oneadmin user into /var/lib/one/.ssh/id_rsa and /var/lib/one/.ssh/id_rsa.pub, the public key is also added into /var/lib/one/.ssh/authorized_keys. It happens only if these files don’t exist yet, existing files (e.g., leftovers from previous installations) are not touched! For new installations, the default SSH configuration is placed for the oneadmin from /usr/share/one/ssh into /var/lib/one/.ssh/config.
To enable passwordless connections you must distribute the public key of the oneadmin user from the Front-end to /var/lib/one/.ssh/authorized_keys on all hypervisor nodes. There are many methods to achieve the distribution of the SSH keys. Ultimately the administrator should choose a method; the recommendation is to use a configuration management system (e.g., Ansible or Puppet). In this guide, we are going to manually use SSH tools.
Since OpenNebula 5.12. The Front-end runs a dedicated SSH authentication agent service which imports the oneadmin’s private key on start. Access to this agent is delegated (forwarded) from the OpenNebula Front-end to the hypervisor nodes for the operations which need to connect between nodes or back to the Front-end. While the authentication agent is used, you don’t need to distribute private SSH key from Front-end to hypervisor nodes!
To learn more about the SSH, read the Advanced SSH Usage guide.
A. Populate Host SSH Keys
You should prepare and further manage the list of host SSH public keys of your nodes (a.k.a. known_hosts) so that all communicating parties know the identity of the other sides. The file is located in /var/lib/one/.ssh/known_hosts and we can use the command ssh-keyscan to manually create it. It should be executed on your Front-end under the oneadmin user and copied on all your nodes.
Make sure you are logged in on your Front-end and run the commands as oneadmin, e.g., by typing:
su - oneadmin
Create the known_hosts file by running following command with all the node names including the Front-end as parameters:
ssh-keyscan <frontend> <node1> <node2> <node3> ... >> /var/lib/one/.ssh/known_hosts
B. Distribute Authentication Configuration
To enable passwordless login on your infrastructure, you must copy authentication configuration for oneadmin user from Front-end to all your nodes. We’ll distribute only known_hosts created in the previous section and oneadmin’s SSH public key from Front-end to your nodes. We don’t need to distribute oneadmin’s SSH private key from Front-end, as it’ll be securely delegated from Front-end to hypervisor nodes with the default SSH authentication agent service running on the Front-end.
su - oneadmin
Enable passwordless logins by executing the following command for each of your nodes. For example:
ssh-copy-id -i /var/lib/one/.ssh/id_rsa.pub <node1>
ssh-copy-id -i /var/lib/one/.ssh/id_rsa.pub <node2>
ssh-copy-id -i /var/lib/one/.ssh/id_rsa.pub <node3>
If the list of host SSH public keys was created in the previous section, distribute the known_hosts file to each of your nodes. For example:
scp -p /var/lib/one/.ssh/known_hosts <node1>:/var/lib/one/.ssh/
scp -p /var/lib/one/.ssh/known_hosts <node2>:/var/lib/one/.ssh/
scp -p /var/lib/one/.ssh/known_hosts <node3>:/var/lib/one/.ssh/
Without SSH Authentication Agent (Optional)
C. Validate Connections
You should verify that none of these connections (under user oneadmin) fail and none require a password:
  • from the Front-end to Front-end itself
  • from the Front-end to all nodes
  • from all nodes to all nodes
  • from all nodes back to Front-end
For example, execute on the Front-end:
# from Front-end to Front-end itself
ssh <frontend>
exit
# from Front-end to node, back to Front-end and to other nodes
ssh <node1>
ssh <frontend>
exit
ssh <node2>
exit
ssh <node3>
exit
exit
ssh <node2>
ssh <frontend>
exit
ssh <node1>
exit
ssh <node3>
exit
exit
# from Front-end to nodes and back to Front-end and other nodes
ssh <node3>
ssh <frontend>
exit
ssh <node1>
exit
ssh <node2>
exit
exit
Step 5. Networking Configuration
Network connection is needed by the OpenNebula Front-end Daemons to access, manage, and monitor the Hosts, and to transfer the Image files. It is highly recommended to use a dedicated network for this purpose.
There are various models for virtual networks, check the Open Cloud Networking Chapter to find the ones supported by OpenNebula.
You may want to use the simplest network model that corresponds to the bridged driver. For this driver, you will need to set up a Linux bridge and include a physical device in the bridge. Later on, when defining the network in OpenNebula, you will specify the name of this bridge and OpenNebula will know that it should connect the VM to this bridge, thus giving it connectivity with the physical network device connected to the bridge. For example, a typical Host with two physical networks, one for public IP addresses (attached to an eth0 NIC for example) and the other for private virtual LANs (NIC eth1 for example) should have two bridges:
ip link show type bridge
4: br0: ...
5: br1: ...
ip link show master br0
2: eth0: ...
ip link show master br1
3: eth1: ...
Step 6. Storage Configuration (Optional)
In default OpenNebula configuration, the local storage is used for storing Images and running Virtual Machines. This is enough for basic use and you don’t need to take any extra steps now unless you want to deploy an advanced storage solution.
Follow the Open Cloud Storage Setup guide to learn how to use Ceph, NFS, LVM, etc.
Step 7. Adding Host to OpenNebula
In this step, we’ll register the hypervisor node we have configured above into the OpenNebula Front-end, so that OpenNebula can launch Virtual Machines on it. This step is documented for Sunstone GUI and CLI but both accomplish the same. Select one of the two options only.
Learn more in Hosts and Clusters Management.
Add Host with Sunstone
Open Sunstone as documented here. On the left side menu go to Infrastructure -> Hosts. Click on the + button.
sunstone_select_create_host
Then fill in the hostname, FQDN, or IP of the node in the Hostname field.
sunstone_create_host_dialog
Finally, return back to the Hosts list, and check that the Host has switched to ON status. It can take up to one minute. Click on the refresh button to check the status more frequently.
sunstone_list_hosts
Add Host with CLI
To add a node to the cloud, run this command as oneadmin in the Front-end (replace <node01> with your node hostname):
onehost create <node01> -i kvm -v kvm
onehost list
ID NAME            CLUSTER   RVM      ALLOCATED_CPU      ALLOCATED_MEM STAT
 1 localhost       default     0                  -                  - init
# After some time (up to 1 minute)
onehost list
 0 node01          default     0       0 / 400 (0%)     0K / 7.7G (0%) on
Next steps
Now, you can continue by controlling and extending your cloud:
