Virtual Network Templates
The Virtual Network Templates allow the end user to create Virtual Networks without knowing the details of the underlying infrastructure. Typically the administrator sets up the templates with the required physical attributes, e.g., driver or physical device information and lets the end user add all the logic information like address ranges or gateway.
Virtual Network Templates can be instantiated several times and shared between multiple users.
Virtual Network Template Definition
A Virtual Network Template is a representation of a Virtual Network, so a template can be defined by using the same attributes available for a Virtual Network. Virtual Network Templates and Virtual Networks also share their required attributes depending on driver they are using (see the requirements here, Physical Network Attributes section).
When a network is created by instantiating a Virtual Network Template, it is associated to the default cluster. You can control which clusters the networks will be in with the CLUSTER_IDS attribute.
Here is an example of a Virtual Network Template with one address range:
NAME=vntemplate
VN_MAD="bridge"
AR=[
IP="10.0.0.1",
SIZE="10",
TYPE="IP4" ]
CLUSTER_IDS="1,100"
The networks created by instantiating this template will be on clusters 1 and 100.
Using Virtual Network Templates
By default just oneadmin can create Virtual Network Templates. If other users need permissions for creating Virtual Network Templates it can be provided by creating a specific ACL.
Once the Virtual Network Template is created, you can control access to it by its permissions. For example, if an end user needs to instantiate a specific template, it would be enough to give the template USE permission for others. You can find more information about permissions here.
Operations
The available operations for Virtual Network Templates are the following:
- allocate
- instantiate
- info
- update
- delete
- chown
- chmod
- clone
- rename
- lock
- unlock
Preparing Virtual Network Templates for End Users
First, create a Virtual Network Template and set all the attributes which need to be set to define the Virtual Network at the template like bridge, vlan id, etc.
$ cat vn_template.txt
NAME=vntemplate
VN_MAD="bridge"
BRIDGE="virbr0"
$ onevntemplate create vn_template.txt
Once the Virtual Network Template has been created, change the permissions to make it available for the users you want. In the example below all the users will be able to instantiate the template:
$ onevntemplate chmod 0 604
$ onevntemplate show 0
TEMPLATE 0 INFORMATION
USER : oneadmin
GROUP : oneadmin
LOCK : None
REGISTER TIME : 11/28 14:44:21
OWNER : um-
GROUP : ---
OTHER : u--
TEMPLATE CONTENTS
BRIDGE="virbr0"
VN_MAD="bridge"
#check everything works well
$ onevntemplate instantiate 0 --user user --name private
VN ID: 1
$ onevnet list
ID USER GROUP NAME CLUSTERS BRIDGE STATE LEASES
1 user users private 0 virbr0 rdy 0
The network is now ready. Users can create VMs and attach their interfaces to the newly created Virtual Network simply by adding NIC = [ NETWORK = private ] or selecting it through Sunstone.
You can also manage your Virtual Networks Templates using Sunstone UI Interface. Select the Networks Template tab to create and operate your Virtual Networks Templates in a user-friendly way.
- Create new Virtual Networks Template
