VM HA
The goal of this section is to provide information to prepare for failures of the Virtual Machines or Hosts and to recover from them. These failures are categorized depending on whether they come from the physical infrastructure (Host failures) or from the virtualized infrastructure (VM crashes). In both scenarios, OpenNebula provides a cost-effective failover solution to minimize downtime from server and OS failures.
Host Failures
When OpenNebula detects that a Host is down, a hook can be triggered to deal with the situation. OpenNebula comes out-of-the-box with a script that can act as a hook to be triggered when a Host enters the ERROR state. This can very useful to limit the downtime of a service due to a hardware failure, since it can redeploy the VMs on another Host.
To set up this Host hook to be triggered in the ERROR state, you need to create it using the following template and command:
$ cat /usr/share/one/examples/host_hooks/error_hook
ARGUMENTS = "$TEMPLATE -m -p 5"
ARGUMENTS_STDIN = "yes"
COMMAND = "ft/host_error.rb"
NAME = "host_error"
STATE = "ERROR"
REMOTE = "no"
RESOURCE = HOST
TYPE = state
$ onehook create /usr/share/one/examples/host_hooks/error_hook
We are defining a Host hook, named host_error, that will execute the script ft/host_error.rb locally with the following arguments:
| Argument | Description | Default |
$TEMPLATE | Template of the HOST which triggered the hook. In XML format, base64 encoded | NA |
| Action | This defines the action to be performed upon the VMs that were running in the Host that went down. This can be: - -m migrate VMs to another Host. Only for images on shared storage (NFS, Ceph, …): This option skips VMs deployed on local datastores, so they can be started after Host recovery. - -r delete and recreate VMs running in the Host. Their state will be lost!- -d delete VMs running in the Host | NA |
| Force Inactive | -f force resubmission of VMs in SUSPEND and POWEROFF states | False |
| Avoid Transient | -p <n> avoid resubmission if Host comes back after <n> monitoring cycles | 2 |
| Avoid Fencing | --no-fencing avoid Host fencing | False |
More information on hooks here.
Tuning HA responsiveness
This HA mechanism is based on the Host state monitoring. How long the Host takes to be reported in ERROR is crucial for how quickly you want the VMs to be available.
There are multiple timers that you can adjust on /etc/one/monitord.conf to adjust this. BEACON_HOST dictates how often the Host is checked to make sure it is responding. If it doesn’t respond past MONITORING_INTERVAL_HOST then the Front-end will attempt to restart the monitoring on the Host.
This process tries to connect to the Host via SSH, synchronize the probes, and start their execution. It might be possible that this SSH connection hangs if the Host is not responsive. This can lead to a situation where the VM workloads running on said Host will be unavailable and the HA will not be present during this process. You can adjust how much are you comfortable with waiting for this SSH to fail by setting the parameter ConnectTimeout on the oneadmin SSH configuration at /var/lib/one/.ssh/config.
The following is an example configuration
Host *
ServerAliveInterval 10
ControlMaster no
ControlPersist 70s
ControlPath /run/one/ssh-socks/ctl-M-%C.sock
StrictHostKeyChecking no
UserKnownHostsFile /dev/null
ConnectTimeout 15
Enabling Fencing
In order to enable fencing you need to implement file /var/lib/one/remotes/hooks/ft/fence_host.sh:
- Update your Hosts using
onehost update <HOST_ID>and add there the attributeFENCE_IPwith the fencing device IP. - Update the above script and add
USERNAMEandPASSWORDof your fencing device. - Remove the line
echo ""Fence host not configured, please edit ft/fence_host.sh"" && exit 1from above script. - Depending on your hardware provider, you will need to use a different tool to control the ILO, so please check your hardware manual, for example:
while [ "$RETRIES" -gt 0 ]
do
fence_ilo5 -P --ip=$FENCE_IP --password="${PASSWORD}" --username="${USERNAME}" --action="${ACTION}" && exit 0
RETRIES=$((RETRIES-1))
sleep $SLEEP_TIME
done
Continue with Troubleshooting guide to understand how to recover failed VMs.
