Kernels and Files Datastore
The Kernels and Files Datastore lets you store plain files to be used as VM kernels, ramdisks, or any other files that need to be passed to the VM through the contextualization process. The Kernels and Files Datastore does not expose any special storage mechanism but is a simple and secure way to use files within VM templates.
Configuration
The datastores common configuration attributes apply to the Kernels and Files Datastores and can be defined during the creation process or updated once the datastores have been created.
The specific attributes for Kernels and Files Datastore are listed in the following table:
| Attribute | Description |
TYPE | FILE_DS |
DS_MAD | fs |
TM_MAD | local |
DS_MAD and TM_MAD are the ones stated above but any other can be used to fit specific use cases. Regarding this, the same configuration guidelines defined for Image and System Datastores apply for the Kernels and Files Datastore.For example, the following illustrates the creation of Kernels and Files:
> cat kernels_ds.conf
NAME = kernels
DS_MAD = fs
TM_MAD = local
TYPE = FILE_DS
SAFE_DIRS = /var/tmp/files
> onedatastore create kernels_ds.conf
> onedatastore list
ID NAME CLUSTER IMAGES TYPE DS TM
0 system - 0 sys - dummy
1 default - 0 img dummy dummy
2 files - 0 fil fs local
100 kernels - 0 fil fs local
You can check more details of the datastore by issuing the onedatastore show <ds_id> command.
Host Configuration
The recommended local driver for the File Datastore does not need any special configuration for the Hosts. Just make sure that there is enough space under the datastore location (/var/lib/one/datastores by default) to hold the VM files in the Front-end and Hosts.
If different DS_MAD or TM_MAD attributes are used, refer to the corresponding node set up guide of the corresponding driver.
