PCI Passthrough
It is possible to discover PCI devices in the Hosts and directly assign them to Virtual Machines in the KVM hypervisor.
The setup and environment information is taken from here. You can safely ignore all the VGA-related sections, those for PCI devices that are not graphic cards, or if you don’t want to output video signal from them.
Requirements
Virtualization Host must
- support I/O MMU (processor features Intel VT-d or AMD-Vi)
- have Linux kernel >= 3.12
(instructions below are made for Intel branded processors but the process should be very similar for AMD)
Machine Configuration (Hypervisor)
Kernel Configuration
The kernel must be configured to support I/O MMU and to blacklist any driver that could be accessing the PCIs that we want to use in our VMs. The parameter to enable I/O MMU is:
intel_iommu=on
We also need to tell the kernel to load the vfio-pci driver and blacklist the drivers for the selected cards. For example, for NVIDIA GPUs we can use these parameters:
rd.driver.pre=vfio-pci rd.driver.blacklist=nouveau
Loading VFIO Driver in initrd
The modules for vfio must be added to initrd. The list of modules are vfio vfio_iommu_type1 vfio_pci vfio_virqfd. For example, if your system uses dracut, add the file /etc/dracut.conf.d/local.conf with this line:
add_drivers+="vfio vfio_iommu_type1 vfio_pci vfio_virqfd"
and regenerate initrd:
# dracut --force
Driver Blacklisting
The same blacklisting done in the kernel parameters must be done in the system configuration. /etc/modprobe.d/blacklist.conf for NVIDIA GPUs:
blacklist nouveau
blacklist lbm-nouveau
options nouveau modeset=0
alias nouveau off
alias lbm-nouveau off
Alongside this configuration the VFIO driver should be loaded by passing the id of the PCI cards we want to attach to VMs. For example, for NVIDIA GRID K2 GPU we pass the id 10de:11bf. File /etc/modprobe.d/local.conf:
options vfio-pci ids=10de:11bf
VFIO Device Binding
I/O MMU separates PCI cards into groups to isolate memory operation between devices and VMs. To add the cards to VFIO and assign a group to them we can use the scripts shared in the aforementioned web page.
This script binds a card to VFIO. It goes into /usr/local/bin/vfio-bind:
#!/bin/sh
modprobe vfio-pci
for dev in "$@"; do
vendor=$(cat /sys/bus/pci/devices/$dev/vendor)
device=$(cat /sys/bus/pci/devices/$dev/device)
if [ -e /sys/bus/pci/devices/\$dev/driver ]; then
echo $dev > /sys/bus/pci/devices/$dev/driver/unbind
fi
echo $vendor $device > /sys/bus/pci/drivers/vfio-pci/new_id
done
The configuration goes into /etc/sysconfig/vfio-bind. The cards are specified with PCI addresses. Addresses can be retrieved with the lspci command. Make sure to prepend the domain that is usually 0000. For example:
DEVICES="0000:04:00.0 0000:05:00.0 0000:84:00.0 0000:85:00.0"
Here is a systemd script that executes the script. It can be written to /etc/systemd/system/vfio-bind.service and enabled:
[Unit]
Description=Binds devices to vfio-pci
After=syslog.target
[Service]
EnvironmentFile=-/etc/sysconfig/vfio-bind
Type=oneshot
RemainAfterExit=yes
ExecStart=-/usr/local/bin/vfio-bind $DEVICES
[Install]
WantedBy=multi-user.target
QEMU Configuration
Now we need to give QEMU access to the VFIO devices for the groups assigned to the PCI cards. We can get a list of PCI cards and its I/O MMU group using this command:
# find /sys/kernel/iommu_groups/ -type l
In our example our cards have the groups 45, 46, 58, and 59 so we add this configuration to /etc/libvirt/qemu.conf:
cgroup_device_acl = [
"/dev/null", "/dev/full", "/dev/zero",
"/dev/random", "/dev/urandom",
"/dev/ptmx", "/dev/kvm", "/dev/kqemu",
"/dev/rtc","/dev/hpet", "/dev/vfio/vfio",
"/dev/vfio/45", "/dev/vfio/46", "/dev/vfio/58",
"/dev/vfio/59"
/dev/vfio devices are not owned by oneadmin:kvm. In this cases, a udev rule like SUBSYSTEM=="vfio", GROUP="kvm", OWNER="oneadmin" will set up the necessary owner:group for them to workDriver Configuration
The only configuration needed is the filter for the monitoring probe that gets the list of PCI cards. By default, the probe doesn’t list any cards from a Host. To narrow the list, the configuration can be changed in /var/lib/one/remotes/etc/im/kvm-probes.d/pci.conf. The following configuration attributes are available:
| Parameter | Description |
:filter | (List) Filters by PCI vendor:device:class patterns (same as for lspci) |
:short_address | (List) Filters by short PCI address bus:device.function |
:device_name | (List) Filters by device names with case-insensitive regular expression patterns |
/var/lib/one/remotes/etc/im/kvm-probes.d/pci.conf must be edited in the Front-end. After this, the command onehost sync --force should be executed to update the drivers in the KVM nodes.All filters are applied on the final PCI cards list.
Example:
# This option specifies the main filters for PCI card monitoring. The format
# is the same as used by lspci to filter on PCI card by vendor:device(:class)
# identification. Several filters can be added as a list, or separated
# by commas. The NULL filter will retrieve all PCI cards.
# From lspci help:
# -d [<vendor>]:[<device>][:<class>]
# Show only devices with specified vendor, device and class ID.
# The ID's are given in hexadecimal and may be omitted or given
# as "*", both meaning "any value"#
# For example:
# :filter:
# - '10de:*' # all NVIDIA VGA cards
# - '10de:11bf' # only GK104GL [GRID K2]
# - '*:10d3' # only 82574L Gigabit Network cards
# - '8086::0c03' # only Intel USB controllers
# or
# :filter: '*:*' # all devices
# or
# :filter: '0:0' # no devices
:filter: '*:*'
# The PCI cards list restricted by the :filter option above can be even more
# filtered by the list of exact PCI addresses (bus:device.func).
# For example:
# :short_address:
# - '07:00.0'
# - '06:00.0'
:short_address:
- '00:1f.3'
# filtered by matching the device name against the list of regular expression
# case-insensitive patterns.
# For example:
# :device_name:
# - 'Virtual Function'
# - 'Gigabit Network'
# - 'USB.*Host Controller'
# - '^MegaRAID'
:device_name:
- 'Ethernet'
- 'Audio Controller'
Per-Host Device Filtering
The driver configuration file ( /var/lib/one/remotes/etc/im/kvm-probes.d/pci.conf ) contains the definition of PCI device filtering rules which are applied globally across all hosts. Additionally, if the cloud administrator intends to apply filtering rules to specific hosts, these attributes can be configured on a per-host or per-cluster basis within the corresponding host template:
PCI_FILTER | (List) Filters by PCI vendor:device:class patterns (same as for lspci) |
PCI_SHORT_ADDRESS | (List) Filters by short PCI address bus:device.function |
Example: The command below filters by PCI with the 10de:* pattern and addresses using the e1 bus`
$ onehost show 0 | grep PCI
PCI_FILTER="10de:*"
PCI_SHORT_ADDRESS="e1:00.0"
Usage
The basic workflow is to inspect the Host information, either in the CLI or in Sunstone, to find out the available PCI devices and to add the desired device to the template. PCI devices can be added by specifying VENDOR, DEVICE and CLASS, or simply CLASS. Alternatively, you can select and specific device by its address with (SHORT_ADDRESS).
Note that OpenNebula will only deploy the VM in a Host with the available PCI device. If no Hosts match, an error message will appear in the Scheduler log.
CLI
A new table in onehost show command gives us the list of PCI devices per Host. For example:
PCI DEVICES
VM ADDR TYPE NAME
00:00.0 8086:0a04:0600 Haswell-ULT DRAM Controller
00:02.0 8086:0a16:0300 Haswell-ULT Integrated Graphics Controller
123 00:03.0 8086:0a0c:0403 Haswell-ULT HD Audio Controller
00:14.0 8086:9c31:0c03 8 Series USB xHCI HC
00:16.0 8086:9c3a:0780 8 Series HECI #0
00:1b.0 8086:9c20:0403 8 Series HD Audio Controller
00:1c.0 8086:9c10:0604 8 Series PCI Express Root Port 1
00:1c.2 8086:9c14:0604 8 Series PCI Express Root Port 3
00:1d.0 8086:9c26:0c03 8 Series USB EHCI #1
00:1f.0 8086:9c43:0601 8 Series LPC Controller
00:1f.2 8086:9c03:0106 8 Series SATA Controller 1 [AHCI mode]
00:1f.3 8086:9c22:0c05 8 Series SMBus Controller
02:00.0 8086:08b1:0280 Wireless 7260
VM- The VM ID using that specific device. Empty if no VMs are using that device.ADDR- PCI Address.TYPE- Values describing the device. These are VENDOR:DEVICE:CLASS. These values are used when selecting a PCI device do to passthrough.NAME- Name of the PCI device.
To make use of one of the PCI devices in a VM a new option can be added to select which device to use. For example, this will ask for a Haswell-ULT HD Audio Controller:
PCI = [
VENDOR = "8086",
DEVICE = "0a0c",
CLASS = "0403" ]
The device can also be specified without all the type values. For example, to get any PCI Express Root Ports this can be added to a VM template:
PCI = [
CLASS = "0604" ]
More than one PCI options can be added to attach more than one PCI device to the VM.
In some scenarios it may be useful to select a specific device. In this case simply input the address of the device you are interested in:
PCI = [
SHORT_ADDRESS = "00:03.0"
Sunstone
In Sunstone the information is displayed in the PCI tab of a Host:
To add a PCI device to a template, select the PCI Devices tab when you are creating a Virtual Machine template:
Usage as Network Interfaces
It is possible use a PCI device as an NIC interface directly in OpenNebula. In order to do so you will need to follow the configuration steps mentioned in this guide, namely changing the device driver.
For SR-IOV interfaces you can configure some parameters, in particular the following attributes can be defined for a SR-IOV interface:
MACVLAN_IDSPOOFCHKTRUST
The context packages support the configuration of the following attributes:
MAC: It will change the mac address of the corresponding network interface to the MAC assigned by OpenNebula.IP: It will assign an IPv4 address to the interface, assuming a/24netmask.IPV6: It will assign an IPv6 address to the interface, assuming a/128netmask.VLAN_ID: If present, it will create a tagged interface and assign the IPs to the tagged interface.
CLI
When a PCI in a template contains the attribute TYPE="NIC", it will be treated as a NIC and OpenNebula will assign a MAC address, a VLAN_ID, an IP, etc., to the PCI device.
This is an example of the PCI section of an interface that will be treated as an NIC:
PCI = [
NETWORK = "passthrough",
NETWORK_UNAME = "oneadmin",
TYPE = "NIC",
CLASS = "0200",
DEVICE = "10d3",
VENDOR = "8086",
TRUST = "yes"
Note that the order of appearance of the PCI elements and NIC elements in the template is relevant. They will be mapped to NICs in the order they appear, regardless of whether or not they’re NICs of PCIs.
Sunstone
In the Network tab, under advanced options, the hardware profile of the interface can be of three types:
- “Emulated”, it includes the hardware model emulated by Qemu.
- “PCI - Automatic”, OpenNebula hardware scheduler will pick the best PCI device for the NIC.
- “PCI - Manual”, user can specify the PCI device by its short-address as shown in Host information.
Use the rest of the dialog as usual by selecting a network from the table.
