Hardware Specification and Architecture
This section describes the cloud architecture used in this guide, and provides the specification of hardware and software resources for the reference OpenNebula deployment on IONOS cloud.
Architecture
The target high-level cloud architecture overview is shown below. Two hosts are deployed: the first for hosting the OpenNebula Front-end services and VMs, the second for hosting VMs only. Both machines should have a public IP, which is used to manage the nodes. Additional public IPs are required to access running Virtual Machines. For internal networking between the VMs a VXLAN network is used, that is isolated from the public traffic.
Front-end Requirements
FRONT-END
Number of Zones1
Cloud ManagerOpenNebula 7.0
Server SpecsIONOS server with 2 dedicated cores and 8GB RAM (CPU model depends on the selected location)
Operating SystemDebian 12
High AvailabilityNo (1 Front-end)
AuthorizationBuiltin
Host Requirements
VIRTUALIZATION HOSTS
Number of Nodes1
HypervisorKVM
Special DevicesNone
Storage Specification
STORAGE
TypeSSH drivers using local disks
CapacityFull size of servers local disks
Network Requirements
NETWORK
NetworkingVXLAN, Public routed network
Number of Networks2 networks: VXLAN internal network, public network for external access
