Configuration and Deployment
Basic Configuration
To set up Ceph RBD mirroring between two OpenNebula sites, you will need to configure asynchronous block-level replication of RBD images in order to ensure that Virtual Machine disk images are synchronized.
First, you deploy two independent Ceph clusters, one per site (Site A and Site B). These clusters must use matching RBD pool names. (In this guide, we will use a pool called one). To avoid duplicate image names, Site B does not have any images in the same pool.
On Site A, you need to:
- Set the VM images as persistent in the OpenNebula database. This means that modifications you make to each image will be preserved after the VM is terminated. You can set a VM image as persistent when you create the image or later, using the
oneimagecommand. For details see Creating Images and Changing the Persistent Mode in the Images documentation.
On Site B, you need to:
- Retrieve the metadata for each VM. You can do this with
onevm show. For full details on this and other Virtual Machine operations, see Virtual Machine Instances.
Create Ceph Users
To use RBD mirroring, you will need to set up two users for the Ceph clusters: one for the rbd-mirror daemon on the source Ceph cluster (Site A) and one for the daemon on the target Ceph cluster (Site B). These users will enable the rbd-mirror daemon on each Ceph cluster to authenticate against each other.
This section lists the commands to create the Ceph user on the Ceph clusters for Site and Site B.
Throughout this guide, one is used as the pool name, and site-a and site-b as the Ceph cluster names.
Unless otherwise specified, all commands in this guide should be run as root.
On Site A
To create the user in the source Ceph cluster, run:
ceph auth get-or-create client.rbd-mirror-peer-a mon 'profile rbd' osd 'profile rbd' -o /etc/ceph/site-a.client.rbd-mirror-peer-a.keyring
This creates a secret key for the user and outputs it to the file /etc/ceph/site-a.client.rbd-mirror-peer-a.keyring. You will need to copy this file to the Ceph cluster at Site B. To copy the contents to all hosts on Site B, you can run this one-line script, (replacing the node and site names if necessary):
for host in node{0..3}-site-b; do echo $host; scp /etc/ceph/site-a.client.rbd-mirror-peer-a.keyring root@$host:/etc/ceph/site-a.client.rbd-mirror-peer-a.keyring; done
Then, on each host change the ownership of the file to user ceph:
for host in node{0..3}-site-b; do echo $host; ssh $host chown ceph:ceph /etc/ceph/site-a.client.rbd-mirror-peer-a.keyring; done
On Site B
On the target Ceph cluster (Site B), you will need to create a local user for the rbd-mirror daemon. Here we will use $(hostname) to match the unique ID to that used for other Ceph services such as monitors.
ceph auth get-or-create client.rbd-mirror.$(hostname) mon 'profile rbd-mirror' osd 'profile rbd' -o /etc/ceph/ceph.client.rbd-mirror.$(hostname).keyring
If you wish to restrict the user permissions to this specific pool, you can use profile rdb pool=one:
ceph auth get-or-create client.rbd-mirror.$(hostname) mon 'profile rbd-mirror' osd 'profile rbd pool=one' -o /etc/ceph/ceph.client.rbd-mirror.$(hostname).keyring
Enabling Daemon Access to the “Site A” Ceph Cluster
To enable the rbd-mirror daemon on Site B to access the Ceph cluster on Site A, you will need to copy the ceph.conf file from Site A to Site B, and name it site-a.conf.
On Site A, you can run the command below to copy the file to all nodes on Site B (replacing the node and site names if necessary):
for host in node{0..3}-site-b; do echo $host; scp /etc/ceph/ceph.conf root@$host:/etc/ceph/site-a.conf; done
root@site-a $ for host in node{0..3}-site-b; do echo $host; ssh $host chown ceph:ceph /etc/ceph/site-a.conf; done
Then, to change ownership of the file to system user ceph:
Make sure that the name of the config file matches the name used in the keyring that stores the authentication information.
Enable Mirroring
When RBD mirroring is enabled for the entire pool, all newly-created images will inherit the journal and exclusive-lock attributes. However, only template images that do not need to be synchronized will be automatically synchronized to the opposite site, and VM images will not be synchronized even if they inherit the journal and exclusive-lock attributes, since that would require flattening the image.
Site A can be configured with mirroring in image mode, but Site B always needs to use mirroring in pool mode.
The below commands illustrate how to enable mirroring on the source and target Ceph clusters.
Enable Mirroring on Site A
On Site A, you can enable mirroring in pool or image mode. To enable it in pool mode, run:
rbd mirror pool enable one pool
If you wish to enable mirroring with image mode, skip the above command and follow the steps below, then come back to this section to enable mirroring in Site B.
Enable Mirroring on Site B
On Site B, mirroring must always use pool mode. To enable it, run:
To verify mirroring:
rbd mirror pool info one
Next, we need to tell the pool on site B which keyring and Ceph config file it should use to connect to the peer (Site A).
rbd mirror pool peer add one client.rbd-mirror-peer-a@site-a
You can check the settings by running:
For example:
root@site-b $ rbd mirror pool info one
Mode: pool
Site Name: 16c707cc-a764-47d4-b308-eefa06ff1205
Peer Sites:
UUID: 164f8358-70a3-4f2d-a727-8729fa186b88
Mirror UUID:
Direction: rx-tx
Client: client.rbd-mirror-peer-a
The Direction field should display rx-tx and the client should be set correctly to match the keyring file. The name should also be shown correctly (site-a).
Install the rbd-mirror Daemon on Site B
To install the daemon, run:
apt install rbd-mirror
Then, enable and modify the systemd unit file for rbd-mirror:
systemctl enable ceph-rbd-mirror.target
cp /usr/lib/systemd/system/ceph-rbd-mirror@.service /etc/systemd/system/ceph-rbd-mirror@.service
Create the Mirroring Service on Site B
Next, you will need to create and start the mirroring service. Ensure to give it the same name as the local user for the Site B cluster created earlier (see above), or the Site A daemon won’t be able to authenticate against the Site B cluster.
systemctl enable --now ceph-rbd-mirror@rbd-mirror.$(hostname).service
If we check the status and logs of the ceph-rbd-mirror@rbd-mirror.<hostname>.service_ service, we should see that it comes up and does not log any authentication errors.
To check service status, run:
systemctl status ceph-rbd-mirror@rbd-mirror.ubuntu2204-kvm-ceph-squid-6-10-cqyoo-0.service
For example:
root@site-b $ systemctl status ceph-rbd-mirror@rbd-mirror.ubuntu2204-kvm-ceph-squid-6-10-cqyoo-0.service
● ceph-rbd-mirror@rbd-mirror.ubuntu2204-kvm-ceph-squid-6-10-cqyoo-0.service - Ceph rbd mirror daemon
Loaded: loaded (/etc/systemd/system/ceph-rbd-mirror@.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2025-06-09 12:04:50 UTC; 6 days ago
Main PID: 17234 (rbd-mirror)
Tasks: 51
Memory: 55.5M
CPU: 21min 42.097s
CGroup: /system.slice/system-ceph\x2drbd\x2dmirror.slice/ceph-rbd-mirror@rbd-mirror.ubuntu2204-kvm-ceph-squid-6-10-cqyoo-0.service
└─17234 /usr/bin/rbd-mirror -f --cluster ceph --id rbd-mirror.ubuntu2204-kvm-ceph-squid-6-10-cqyoo-0 --setuser root --setgroup root
At this point, mirroring should be configured from Site A to Site B, with direction tx-only. To verify the mirroring, see below.
Verify Mirroring
On Site A, run:
Output should similar to:
root@site-a $ rbd mirror pool info one
Mode: pool
Site Name: 277ddb4b-1323-425f-bf28-fa8c58c0137e
Peer Sites:
UUID: 0ab31017-3e80-470d-b80d-1ba04d606b13
Mirror UUID: 5218ea1d-fcb7-404e-82f0-e48a77a05935
Direction: tx-only
To obtain detailed information about the mirroring, run:
rbd mirror pool status one --verbose
For example:
root@site-b $ rbd mirror pool status one --verbose
health: OK
daemon health: OK
image health: OK
images: 0 total
DAEMONS
service 14595:
instance_id: 14597
client_id: ubuntu2204-kvm-ceph-squid-6-10-cqyoo-0
hostname: ubuntu2204-kvm-ceph-squid-6-10-cqyoo-0
version: 19.2.2
leader: true
health: OK
Enable Mirroring on Site A in image mode
If you want to use image mode for Site A mirroring, you will need to define which images should be mirrored, and enable the exclusive-lock and journal features for the images.
To enable journal-based mirroring for an image (in this example, image one-0-0-0), run:
rbd mirror image enable one/one-0-0-0 exclusive-lock,journal
Then, verify the image:
rbd image 'one-0-0-0':
For example:
root@site-a $ rbd image 'one-0-0-0':
size 256 MiB in 64 objects
order 22 (4 MiB objects)
snapshot_count: 0
block_name_prefix: rbd_data.39b66a80b833
format: 2
features: layering, exclusive-lock, journaling
op_features:
flags:
create_timestamp: Wed Jun 4 10:31:42 2025
access_timestamp: Mon Jun 9 12:08:11 2025
modify_timestamp: Mon Jun 9 12:08:05 2025
parent: one/one-0@snap
overlap: 256 MiB
journal: 39b66a80b833
mirroring state: enabled
mirroring mode: journal
mirroring global id: f0523ef9-a784-420f-8725-c3f81ff5a302
mirroring primary: true
Next, since VM disks are just snapshots based on the image, we will need to flatten the required image:
rbd flatten one/one-0-0-0
After performing these steps, to enable mirroring on Site B go back to the section above.
Enable Two-way Mirroring for Failback
Failback is the process by which Virtual Machines are restored to the primary site, once normal operation on the site has resumed.
To failback Virtual Machines to Site A when it becomes available again after an outage, you will need to set up the rbd-mirror daemon on Site A. The daemon will connect to Site B during failback. On Site A, install the rbd-mirror daemon and enable the service by following the same steps described above for Site B:
