On-cloud Deployment on Scaleway
This document describes the procedure to deploy an AI-ready OpenNebula cloud using OneDeploy on a single Scaleway Elastic Metal bare-metal server equipped with GPUs.
The architecture is a converged OpenNebula installation, where the frontend services and KVM hypervisor run on the same physical host. This approach is ideal for demonstrations, proofs-of-concept (PoCs), or for quickly trying out the solution without the need for a complex physical infrastructure.
The outlined procedure is based on an instance with NVIDIA L40S GPUs as an example.
Prerequisites
Before you begin, ensure your environment meets the following prerequisites.
Instance Launch and Initial Checks
  1. Log in to your Scaleway console.
  2. Navigate to Bare Metal > Elastic Metal
  3. Click Create Elastic Metal Server.
  4. Configure your server in the portal:
    • Availability Zone: Choose your preferred zone, such as PARIS 2. Alternatively, select Auto allocate.
    • Billing Method: Select either hourly or monthly. Note that hourly billing is often more cost-effective for short-term projects or testing.
    • Server Type: Select an instance. For GPU acceleration, you must choose an Elastic Metal Titanium server.
    • Image: Choose Ubuntu 24.04 LTS as the operating system.
    • Cloud-init: You can skip this step, as it is not used in this setup.
    • Disk Partitions: Configure the disk partition table so that the / path has the full disk space available.
    • Name and Tags: Enter a name for your server and add any optional tags for organization.
    • SSH Keys: add your public SSH key. This is essential for securely accessing your server.
    • Public Bandwidth: the default bandwidth is usually sufficient. You can increase it here if your use case requires higher public throughput.
    • Private Networks: enabling 25Gbps Private Networks is not needed for a single-node setup.
    • Environmental Summary: review the Environmental Footprint Summary.
    • Cost Summary: review the Estimated Cost Summary to ensure it matches your expectations.
    • Create Server: once you have verified all settings, click “Create Elastic Metal Server” to provision and launch your instance.
  5. After some minutes and once the instance is running, connect to it via SSH using its public IP address:
ssh ubuntu@<your_instance_public_ip>
  1. Verify that the GPUs are detected as PCI devices:
lspci -Dnnk | grep NVIDIA
You should see an output similar to this, listing your NVIDIA GPUs:
0000:01:00.0 3D controller [0302]: NVIDIA Corporation AD102GL [L40S] [10de:26b9] (rev a1)
    Subsystem: NVIDIA Corporation AD102GL [L40S] [10de:1851]
0000:82:00.0 3D controller [0302]: NVIDIA Corporation AD102GL [L40S] [10de:26b9] (rev a1)
Make sure you note down the full PCI addresses for both GPUs.
  1. Confirm that IOMMU is enabled on the server. The ls command below should list several numbered subdirectories:
ls -la /sys/kernel/iommu_groups/
If the directory is not empty it means that IOMMU is active, which is a prerequisite for PCI passthrough.
Server Pre-configuration
The following steps prepare the server to run OneDeploy, which operates with root privileges.
  1. Obtain Root Privileges: OneDeploy installs software and modifies system-level configuration files. To perform these actions, open a root shell.
    sudo -i
  2. Configure Local Root SSH Access: Generate an SSH key pair for root and authorize it for local connections. This allows Ansible to connect to 127.0.0.1 as root.
    ssh-keygen -t ed25519 -f /root/.ssh/id_ed25519 -N "" -q
    cat /root/.ssh/id_ed25519.pub >> /root/.ssh/authorized_keys
  3. Create a Virtual Network Bridge: To provide network connectivity to the VMs, create a virtual bridge with NAT. This allows VMs to access the internet through the server’s public network interface.
    3.1 Create the Netplan configuration file for the bridge:
    tee /etc/netplan/60-bridge.yaml > /dev/null << 'EOF'
    network:
      version: 2
      bridges:
        br0:
          dhcp4: no
          addresses: [192.168.100.1/24]
          interfaces: []
          parameters:
            stp: false
            forward-delay: 0
          nameservers:
            addresses: [1.1.1.1,8.8.8.8]
    EOF
    3.2 Apply the network configuration and enable IP forwarding. Replace enp129s0f0np0 with your server’s main network interface if it is different.
    netplan apply
    sysctl -w net.ipv4.ip_forward=1
    iptables -t nat -A POSTROUTING -s 192.168.100.0/24 -o enp129s0f0np0 -j MASQUERADE
    iptables-save | uniq | iptables-restore
OneDeploy Dependencies
As a root user, clone the one-deploy repository and install its dependencies.
cd /root
git clone https://github.com/OpenNebula/one-deploy.git
cd one-deploy/
apt update && apt install -y pipx make
pipx install hatch
pipx ensurepath
source ~/.bashrc
make requirements
hatch shell
At this point, you should be using the hatch environment shell:
(one-deploy) #
For more details, refer to the OneDeploy System Requirements.
AI Factory Deployment
Create an inventory file named inventory/scaleway.yaml. This file defines a complete OpenNebula deployment on the local machine (127.0.0.1).
all:
  vars:
    ansible_user: root
    one_version: '7.0'
    one_pass: YOUR_SECURE_PASSWORD # Replace with a strong password
    gate_endpoint: "http://192.168.100.1:5030"
    ds:
      mode: ssh
    vn:
      admin_net:
        managed: true
        template:
          VN_MAD: bridge
          BRIDGE: br0
          AR:
            TYPE: IP4
            IP: 192.168.100.50
          NETWORK_ADDRESS: 192.168.100.0
          NETWORK_MASK: 255.255.255.0
          GATEWAY: 192.168.100.1
          DNS: 1.1.1.1
frontend:
  hosts:
    f1: { ansible_host: 127.0.0.1 }
node:
  hosts:
    h1:
      pci_passthrough_enabled: true
      pci_devices:
        - address: "0000:01:00.0" # First L40S GPU
        - address: "0000:82:00.0" # Second L40S GPU
Run the deployment on the one-deploy hatch shell environment previously created:
make I=inventory/scaleway.yaml
Post-Deployment Verification
Once the deployment is complete:
  1. Access the OpenNebula Sunstone web interface at http://<your_instance_public_ip>:2616.
  2. Log in with the username oneadmin and the password you set in the inventory file.
  3. Verify the GPU passthrough configuration:
    1. In Sunstone, navigate to Infrastructure -> Hosts.
    2. Select the 127.0.0.1 host.
    3. Go to the PCI tab. You should see both L40S GPUs listed and ready for passthrough.
