Deployment of the NVIDIA KAI Scheduler
The NVIDIA® KAI Scheduler is an open source Kubernetes-native scheduler designed to optimize GPU resource allocation for AI and machine learning workloads at scale. It is capable of managing large GPU clusters and handling high-throughput demanding workload environments. KAI Scheduler targets both interactive jobs and large-scale training or inference tasks within the same cluster, orchestrating available resources across different users and teams. It also operates alongside other schedulers installed in a cluster.
Some of the key features are:
  • Share single or multiple GPU resources among multiple workloads for improving resource allocation.
  • Batch scheduling of different types of workloads, including gang scheduling (i.e. all pods are scheduled together or none are scheduled until all resources are available).
  • Effective workload priority with hierarchical queues.
  • Resource distribution with custom quotas, limits, priorities and fairness policies.
  • Elastic workloads with dynamic workload escalation.
  • Compatibility with other autoscalers like Karpenter.
As the KAI Scheduler operates on top of Kubernetes, users benefit from its robust orchestration, scalability, and resource management capabilities, further enhancing deployment flexibility and reliability. Running both KAI Scheduler and Kubernetes on OpenNebula, this solution extends resource management to hybrid and multi-cloud environments, enabling dynamic and cost-effective scaling of AI workloads while maintaining control over infrastructure. This synergy leverages the strengths of all three technologies to deliver efficient, fair, and portable GPU scheduling from on-premises data centers to the cloud.
In this guide you will learn how to perform a validation using NVIDIA KAI Scheduler in an AI-Ready Kubernetes cluster. You will find details about the installation and efficiently share GPU resources among different workloads.
Before Starting
Before starting this tutorial, you must complete the AI-factory deployment with either on-premise resources or cloud resources. Please complete one of the following guides relevant to your available resources:
You must then complete the AI-ready Kubernetes deployment guide. You also must undeploy any appliances, VMs or services you deployed in previous guides before continuing.
NVIDIA KAI Scheduler Installation
To install the NVIDIA KAI Scheduler, you need to accomplish the following prerequisites:
  1. Create a dedicated namespace for the KAI Scheduler components in the Kubernetes cluster:
    kubectl create namespace kai-scheduler
  2. Install the KAI Scheduler through Helm. In case you want to use GPU resource sharing feature, set the "global.gpuSharing=true" flag:
    helm install kai-scheduler \
        https://github.com/NVIDIA/KAI-Scheduler/releases/download/v0.9.8/kai-scheduler-v0.9.8.tgz \
        -n kai-scheduler --create-namespace \
        --set "global.gpuSharing=true" \
        --set "global.resourceReservation.runtimeClassName=nvidia"
    We recommend that you install version 0.9.8 of the KAI Scheduler to continue. If you wish to install a newer version, please consult the KAI Scheduler repository and install it via Helm. Note that later versions of the KAI Scheduler may require extensive modification of the example schemas provided below to function correctly.
  3. Verify that the Helm chart is successfully installed, and all the KAI Scheduler components are running:
    kubectl get pods -n kai-scheduler
    NAME                                   READY   STATUS    RESTARTS   AGE
    admission-55f6c958b6-sx8q6             1/1     Running   0          31s
    binder-66757b79cf-hnckr                1/1     Running   0          33s
    kai-operator-86579f5b96-nc8tl          1/1     Running   0          33s
    pod-grouper-845d589495-qxmlk           1/1     Running   0          31s
    podgroup-controller-75c6986688-7cfhs   1/1     Running   0          31s
    queue-controller-5bf44f6c4d-gwptq      1/1     Running   0          31s
    scheduler-685b9d6846-69vr4             1/1     Running   0          33s
  4. A workload must belong to a queue in order to be scheduled. To manage workloads, create the corresponding queues which are the essential scheduling primitives. These queues reflect different scheduling guarantees, like resource quota and priority. You can assign the queues to different types of consumers in the cluster, such as users and groups.
    Create two basic scheduling queue hierarchies:
    • A default top level queue.
    • A test leaf queue that you can use for your workloads.
    cat <<EOF | kubectl apply -f -
    apiVersion: scheduling.run.ai/v2
    kind: Queue
    metadata:
    spec:
        resources:
            cpu:
                quota: -1
                limit: -1
                overQuotaWeight: 1
            gpu:
                quota: -1
                limit: -1
                overQuotaWeight: 1
            memory:
                quota: -1
                limit: -1
                overQuotaWeight: 1
    kind: Queue
    metadata:
    spec:
        parentQueue: default
        resources:
            cpu:
                quota: -1
                limit: -1
                overQuotaWeight: 1
            gpu:
                quota: -1
                limit: -1
                overQuotaWeight: 1
            memory:
                quota: -1
                limit: -1
                overQuotaWeight: 1
    EOF
For scheduling your workloads using those queues you need to:
  • Specify the queue name using the kai.scheduler/queue: test label.
  • Specify the kai workload scheduler using the spec.schedulerName: kai-scheduler attribute.
Optionally, you can test the scheduler deploying this example from the KAI quickstart documentation.
At this point, the KAI Scheduler is installed and ready to schedule your AI workloads.
GPU Sharing with KAI Scheduler
One of the features of the KAI Scheduler is the GPU resource sharing, which allows multiple pods or workloads share the same GPU device efficiently, even if they reside in different namespaces.
Allocate a portion of the GPU by:
  • requesting a specific GPU amount. Example: 3Gib.
  • requesting a portion of a GPU device memory. Example: 0.5.
KAI Scheduler does not enforce memory allocation limits or performs memory isolation between processes, so it’s important that the running processes allocate the GPU memory up to the requested amount. For instance, vLLM workloads by default consume the 90% of the GPU memory, so you will limit this consumption using the --gpu-memory-utilization parameter with the corresponding memory fracton such as --gpu-memory-utilization=0.5.
To test the GPU sharing feature of KAI Scheduler, follow these steps:
  1. Create a namespace for the scheduled workloads
    kubectl create ns ai-workloads
  2. Deploy a sample workload that uses vLLM for inference serving
    apiVersion: apps/v1
    kind: Deployment
    metadata:
      namespace: ai-workloads
      labels:
        app: vllm-test-07
    spec:
      replicas: 1
      selector:
        matchLabels:
          app: vllm-test-07
      template:
        metadata:
          labels:
            app: vllm-test-07
          annotations:
            gpu-fraction: "0.7"
        spec:
          containers:
          - name: vllm
            image: vllm/vllm-openai:latest
            command: ["/bin/sh", "-c"]
            args: [
    	      "vllm serve Qwen/Qwen2.5-1.5B-Instruct --gpu-memory-utilization=0.7 --host 0.0.0.0"
            ports:
            - containerPort: 8000
            resources:
              limits:
                cpu: "8"
                memory: 15G
              requests:
                cpu: "6"
                memory: 6G
            livenessProbe:
              httpGet:
                path: /health
                port: 8000
              initialDelaySeconds: 60
              periodSeconds: 10
            readinessProbe:
              httpGet:
                path: /health
                port: 8000
              periodSeconds: 5
    EOF
  3. Verify that the deployment is allocated with the specified resources
    kubectl -n ai-workloads get pods -o custom-columns="NAME:.metadata.name,STATUS:.status.phase,NODE:.spec.nodeName,GPU-FRACTION:.metadata.annotations.gpu-fraction,GPU-GROUP:.metadata.labels.runai-gpu-group"
    NAME                            STATUS    NODE                       GPU-FRACTION   GPU-GROUP
    vllm-test-07-5979b99584-llf45   Running   k8s-gpu-md-0-wr9k6-gbtvr   0.7            407623a2-216d-4c06-b5b8-f8345bf28b5a
  4. Deploy a Kubernetes service to access the API
    apiVersion: v1
    kind: Service
    metadata:
    spec:
      ports:
      - name: http
        port: 80
        protocol: TCP
        targetPort: 8000
      selector:
          app: vllm-test-07
      sessionAffinity: None
      type: ClusterIP
    EOF
    Check the service:
    kubectl -n ai-workloads get svc
    NAME           TYPE        CLUSTER-IP    EXTERNAL-IP   PORT(S)   AGE
    vllm-test-07   ClusterIP   10.43.119.6   <none>        80/TCP    39s
  5. Port forward the service through kubectl
    kubectl -n ai-workloads port-forward svc/vllm-test-07 9000:80 &
  6. Test the deployment by sending a request to the vLLM service API:
    curl http://localhost:9000/v1/completions \
    -d '{
            "model": "Qwen/Qwen2.5-1.5B-Instruct",
            "prompt": "San Francisco is a",
            "max_tokens": 7,
            "temperature": 0
        }' | jq .
    You should receive a response similar to the following:
        "id": "cmpl-173532a758894deeae63d0a073c53289",
        "object": "text_completion",
        "created": 1763393534,
        "choices": [
            "index": 0,
            "text": " city in the state of California,",
            "logprobs": null,
            "finish_reason": "length",
            "stop_reason": null,
            "token_ids": null,
            "prompt_logprobs": null,
            "prompt_token_ids": null
        "service_tier": null,
        "system_fingerprint": null,
        "usage": {
            "prompt_tokens": 4,
            "total_tokens": 11,
            "completion_tokens": 7,
            "prompt_tokens_details": null
        "kv_transfer_params": null
Optionally, you might deploy another workload with a small GPU fraction on that node.
  1. Create another workload with a GPU memory fraction of 0.2
    apiVersion: apps/v1
    kind: Deployment
    metadata:
        labels:
            app: vllm-test-02
    spec:
        replicas: 1
        selector:
            matchLabels:
                app: vllm-test-02
        template:
            metadata:
                labels:
                    app: vllm-test-02
                annotations:
                    gpu-fraction: "0.2"
            spec:
                containers:
                  - name: vllm
                    args: [
                    "vllm serve Qwen/Qwen2.5-1.5B-Instruct --gpu-memory-utilization=0.2"
                    ports:
                    resources:
                        limits:
                            cpu: "8"
                            memory: 15G
                        requests:
                            cpu: "6"
                            memory: 6G
                    livenessProbe:
                        httpGet:
                            path: /health
                            port: 8000
                        periodSeconds: 10
                    readinessProbe:
                        httpGet:
                            path: /health
                            port: 8000
                        periodSeconds: 5
    EOF
  2. Check that the fraction is successfully assigned and the pod is running
    vllm-test-02-79b48968bc-dtzxs   Running   k8s-gpu-md-0-wr9k6-gbtvr   0.2            407623a2-216d-4c06-b5b8-f8345bf28b5a
With this validation, you have checked how you can efficiently share fractional GPU resources between workloads in an AI-Ready Kubernetes with KAI Scheduler.
Next Steps
After powering your AI Factory with NVIDIA KAI Scheduler on Kubernetes, you may continue with NVIDIA Dynamo on Kubernetes as an additional validation procedure built on top of K8s.
