Deployment of AI-ready Kubernetes
Tools like Kubernetes provide robust orchestration for deploying AI workloads at scale, being able to manage isolation between cluster workloads and GPU resources for AI inference tasks. With the use of NVIDIA GPU Operator, you perform the provision of the necessary NVIDIA drivers and libraries for making GPU resources available to containers. Kubernetes embraces multitenancy, supporting different isolated namespaces where the access from different teams or users are managed with Role Based Access Control (RBAC) and network policies. As an administrator, you can also enforce limits on the GPU usage or other resources consumed per namespace, ensuring fair resource allocation.
Additionally, running Kubernetes clusters on top of OpenNebula-provisioned virtual machines (VMs) provides several advantages, like hardware-level isolation, physical secure multi-tenancy, an additional layer of resource isolation for performance-sensitive workloads, multi-cloud architectures, flexibility as well as lifecycle management, resource efficiency, among others. Use CAPONE, the OpenNebula Cluster API provisioner for Kubernetes, to run K8s clusters over OpenNebula- provisioned infrastructure. This allows you to provision Kubernetes workload clusters in a declarative manner.
In this guide you will learn how to combine all of these components for provisioning a secure, robust and scalable solution for our AI workloads on top of the NVIDIA Dynamo framework powered by the OpenNebula cloud platform.
Before Starting
Before starting this tutorial, you must complete the AI-factory deployment with either on-premise resources or cloud resources. Please complete one of the following guides relevant to your available resources:
Architecture
The diagram below depicts the top-level architecture of the NVIDIA Dynamo framework setup in an OpenNebula deployment. The OpenNebula frontend host contains two NVIDIA L40S GPU PCI cards which operate as the host server for the K8s Cluster VMs. For this reference setup, the VMs share a simple bridged network.
Architecture of NVIDIA Dynamo in OpenNebula over two servers
To deploy the GPU-enabled Kubernetes workload cluster, first deploy a VM with the OpenNebula “CAPI Service” marketplace appliance which contains a light Kubernetes management cluster based in K3s and includes a Rancher and CAPONE controller deployment. This instance is used to provision the GPU-enabled Kubernetes workload cluster nodes in a declarative way.
The GPU-enabled Kubernetes workload cluster consists of three VMs that operate as a control plane node and two worker nodes. Each worker node uses one of the two NVIDIA L40S GPU PCI cards. Deploy the NVIDIA GPU Operator in this cluster for automatic configuration of the nodes that make the GPU available to its workloads, and the NVIDIA Dynamo framework operator to deploy inference graphs in a declarative manner.
Infrastructure Deployment and Configuration
Here is a brief glossary of the components described in this section:
  • Management Cluster: a lightweight Kubernetes cluster that contains Cluster API provider components for creating workload Kubernetes declaratively, based on CRDs and yaml manifests/Helm charts.
  • Workload Cluster: the Kubernetes clusters created through the Cluster API that manage the actual workloads.
  • CAPI service Appliance: an OpenNebula Cluster API VM appliance that contains a lightweight-Kubernetes-based (k3s) management cluster prebuilt with the OpenNebula Cluster API Provider (CAPONE) and other Cluster API providers, as well as a Rancher instance. This appliance is ready for deploying and managing workload clusters without any previous setup.
  • CAPONE: the OpenNebula Cluster API Provider which is a Kubernetes Cluster API infrastructure provider that contacts with the OpenNebula frontend API for provisioning the necessary infrastructure for running workload clusters over OpenNebula VMs.
Infrastructure Provisioning
This setup requires OpenNebula running on a GPU-ready environment, such as an OpenNebula host configured with PCI-Passthrough for exposing the GPU cards to the node workloads.
Kubernetes GPU Workload Cluster Provisioning with CAPONE
Deploying the Management Cluster
First we need to deploy the Kubernetes management cluster. This cluster uses the CAPONE controller for automatically provisioning the required VMs for hosting the Kubernetes GPU workload cluster.
Deploy your Kubernetes management cluster through the CAPI Service in OpenNebula.
Step 1: Deploying the CAPI Appliance
  1. Login as oneadmin user on the frontend instance and download the CAPI Service from the marketplace:
    onemarketapp export "Service Capi" service_Capi -d <datastore_id>
    Where datastore_id is your image datastore identifier. In this example, use the default one, with ID:1.
    onemarketapp export "Service Capi" service_Capi -d 1
  2. Update the service_Capi template by adding the necessary scheduling requirements for deploying in to the desired host. In this case, we’re enabling the host-passthrough feature and adding a NIC card attached to the default admin_net network, but you can change it to another network if necessary. The chosen network must be the same that we are going to use for the workload cluster vRouter ingress traffic.
    onetemplate update service_Capi
    NIC=[ NETWORK="admin_net" ]
    CPU_MODEL=[MODEL="host-passthrough" ]
  3. Instantiate the service_Capi appliance:
    onetemplate instantiate service_Capi --name capi
    The CLI will ask you to input some values. Just press “Enter” for each input in order to keep the default values.
The CAPI appliance takes some minutes to be in “Ready” status. Once the appliance is available, proceed to deploy the workload to the Kubernetes cluster with the following steps.
Step 2: Deploy the Workload Cluster
  1. Login as root user in the frontend and install helm 3 and kubectl tools on the frontend instance:
    Helm:
    curl -fsSL https://raw.githubusercontent.com/helm/helm/main/scripts/get-helm-3 | bash
    kubectl:
    curl -fsSL "https://dl.k8s.io/release/$(curl -L -s https://dl.k8s.io/release/stable.txt)/bin/linux/amd64/kubectl" | \
         install -o root -g root -m 0755 -D /dev/fd/0 /usr/local/bin/kubectl
  2. Switch to the oneadmin user again in the frontend and gather the following information from your setup and export the following environment variables:
    In this example, ONE_FRONETEND_IP is set as the IP of the machine running the OpenNebula Front-end in the example AI Factory inventory file given in the on-prem deployment guide. In some cases, the gateway of the Virtual Network may be more appropriate, uncomment the following line if this is the case.
    export ONE_VNET=admin_net
    export ONE_FRONTEND_IP=192.168.122.2
    #export ONE_FRONTEND_IP=$(onevnet show $ONE_VNET -j | jq .VNET.TEMPLATE.GATEWAY | tr -d '"')
    export CAPI_VM_IP=$(onevm show capi -j | jq '.VM.TEMPLATE.NIC[0].IP' | tr -d '"')
    export ONEADMIN_PASSWORD=$(cat /var/lib/one/.one/one_auth | awk -F: '{print $2}')
    The $ONE_VNET variable contains the name of the vnet where the CAPI instance has been deployed and where the workload cluster is going to be deployed (in our case, admin_net), $ONE_FRONTEND_IP is the IP used for accessing the OpenNebula frontend XMLRPC API (in our case we are using the admin_vnet virtual network gateway IP, that is bridged with the OpenNebula Front-end host),
    The $CAPI_VM_IP is the CAPI appliance IP address, and the $ONEADMIN_PASSWORD variable is the defined password for the oneadmin user.
    Check that the environment variables have been properly set:
    echo $ONE_VNET
    echo $ONE_FRONTEND_IP
    echo $CAPI_VM_IP
    echo $ONEADMIN_PASSWORD
    you should see an output like this (note that the IP addresses and the password could change depending on the environment):
    admin_net
    192.168.100.1
    192.168.100.50
    p455w0rd
  3. Retrieve the management cluster kubeconfig connecting to the CAPI appliance through the frontend oneadmin user SSH key:
    ssh root@$CAPI_VM_IP cat /etc/rancher/k3s/k3s.yaml | \
    sed "s|server: https://127.0.0.1:6443|server: https://$CAPI_VM_IP:6443|"> \
    kubeconfig_management.yaml
    Check that you can access the management cluster with the following command:
    kubectl --kubeconfig ./kubeconfig_management.yaml get nodes
    You should see an output similar to this:
    NAME   STATUS   ROLES                  AGE     VERSION
    capi   Ready    control-plane,master   9m20s   v1.31.4+k3s1
  4. Create a values.yaml file for parameterizing the workload cluster helm chart. You will see that the values.yaml file contains some default value overrides, like the images and templates applied for the workload nodes:
    cat > values.yaml << EOF
    ONE_XMLRPC: "http://$ONE_FRONTEND_IP:2633/RPC2"
    ONE_AUTH: "oneadmin:$ONEADMIN_PASSWORD"
    ROUTER_TEMPLATE_NAME: "{{ .Release.Name }}-router"
    MASTER_TEMPLATE_NAME: "{{ .Release.Name }}-master"
    WORKER_TEMPLATE_NAME: "{{ .Release.Name }}-worker"
    CLUSTER_IMAGES:
    - imageName: "{{ .Release.Name }}-router"
      imageContent: |
        PATH = "https://d24fmfybwxpuhu.cloudfront.net/service_VRouter-7.0.0-0-20250528.qcow2"
        DEV_PREFIX = "vd"
    - imageName: "{{ .Release.Name }}-node"
      imageContent: |
        PATH = "https://d24fmfybwxpuhu.cloudfront.net/ubuntu2404-7.0.0-0-20250528.qcow2"
        DEV_PREFIX = "vd"
    CLUSTER_TEMPLATES:
    - templateName: "{{ .Release.Name }}-router"
      templateContent: |
        CONTEXT = [
            NETWORK = "YES",
            ONEAPP_VNF_DNS_ENABLED = "YES",
            ONEAPP_VNF_DNS_NAMESERVERS = "1.1.1.1,8.8.8.8",
            ONEAPP_VNF_DNS_USE_ROOTSERVERS = "NO",
            ONEAPP_VNF_NAT4_ENABLED = "YES",
            ONEAPP_VNF_NAT4_INTERFACES_OUT = "eth0",
            ONEAPP_VNF_ROUTER4_ENABLED = "YES",
            SSH_PUBLIC_KEY = "\$USER[SSH_PUBLIC_KEY]",
            TOKEN = "YES" ]
        CPU = "1"
        CPU_MODEL=[
        DISK = [
            IMAGE = "{{ .Release.Name }}-router" ]
        GRAPHICS = [
            LISTEN = "0.0.0.0",
            TYPE = "vnc" ]
        LXD_SECURITY_PRIVILEGED = "true"
        MEMORY = "512"
        NIC_DEFAULT = [
            MODEL = "virtio" ]
        SCHED_REQUIREMENTS="HYPERVISOR=kvm"
        OS = [
            ARCH = "x86_64",
            FIRMWARE_SECURE = "YES" ]
        VCPU = "2"
        VROUTER = "YES"
    - templateName: "{{ .Release.Name }}-master"
      templateContent: |
        CONTEXT = [
            BACKEND = "YES",
            NETWORK = "YES",
            GROW_FS = "/",
            SET_HOSTNAME = "\$NAME",
            TOKEN = "YES" ]
        CPU = "12"
        CPU_MODEL=[
        DISK = [
            IMAGE = "{{ .Release.Name }}-node",
            SIZE = "41920" ]
        FEATURES=[
            ACPI="yes",
            APIC="yes",
            PAE="yes" ]
        GRAPHICS = [
            LISTEN = "0.0.0.0",
            TYPE = "vnc" ]
        HYPERVISOR = "kvm"
        MEMORY = "32768"
        NIC=[
            NETWORK="$ONE_VNET" ]
        OS = [
            ARCH = "x86_64",
            FIRMWARE="UEFI",
            MACHINE="pc-q35-noble" ]
        SCHED_REQUIREMENTS = "HYPERVISOR=kvm"
        VCPU = "16"
    - templateName: "{{ .Release.Name }}-worker"
      templateContent: |
        CONTEXT = [
            BACKEND = "YES",
            NETWORK = "YES",
            GROW_FS = "/",
            TOKEN = "YES" ]
        CPU = "12"
        CPU_MODEL=[
        DISK = [
            SIZE = "204800" ]
        FEATURES=[
            ACPI="yes",
            APIC="yes",
            PAE="yes" ]
        GRAPHICS = [
            LISTEN = "0.0.0.0",
            TYPE = "vnc" ]
        HYPERVISOR = "kvm"
        MEMORY = "32768"
        NIC=[
        OS=[
            ARCH="x86_64",
            FIRMWARE="UEFI",
        PCI=[
            CLASS="0302",
            DEVICE="26b9",
            VENDOR="10de" ]
        VCPU = "16"
    CONTROL_PLANE_MACHINE_COUNT: 1
    WORKER_MACHINE_COUNT: 2
    PUBLIC_NETWORK_NAME: $ONE_VNET
    PRIVATE_NETWORK_NAME: $ONE_VNET
    EOF
    The number of GPU devices mounted in each worker node depends on the definition of the PCI attribute in the worker nodes template (note that the attributes of this map could change depending on the GPU model). In our case, we are deploying 2 worker nodes, with 1 GPU attached to each one. In case you only have available a single GPU card, change the number or WORKER_MACHINE_COUNT to 1. More information on NVIDIA GPU Passthrough section. In this example, we will attach a single NVIDIA GPU card to each worker nodes.
  5. Once the values.yaml file is available, you can proceed to deploy the workload cluster with Helm. First, add the helm chart repo for CAPONE and apply the helm chart referencing the values file:
    helm repo add capone https://opennebula.github.io/cluster-api-provider-opennebula/charts/ \
        && helm repo update
    Verify the available charts in that repo:
    helm search repo capone
    The result should output the capone-kadm and capone-rke2 charts:
    NAME                    CHART VERSION   APP VERSION     DESCRIPTION
    capone/capone-kadm      0.1.7           v0.1.7          OpenNebula/Kubeadm CAPI Templates
    capone/capone-rke2      0.1.7           v0.1.7          OpenNebula/RKE2 CAPI Templates
  6. Finally, proceed to install the workload cluster template in the CAPI appliance from the capone-rke2 chart:
    helm install --kubeconfig ./kubeconfig_management.yaml \
        k8s-gpu-test capone/capone-rke2 --values ./values.yaml
The CAPONE and rke2 Cluster API controllers in the management cluster will deploy the workload cluster on the scheduled host. Check the logs of those controllers to review the progress:
kubectl get pods -A --kubeconfig kubeconfig_management.yaml -l control-plane=controller-manager
You should be able to see the following pods:
NAMESPACE                           NAME                                                             READY   STATUS    RESTARTS   AGE
capi-kubeadm-bootstrap-system       capi-kubeadm-bootstrap-controller-manager-548b88955-5qktn        1/1     Running   0          9m39s
capi-kubeadm-control-plane-system   capi-kubeadm-control-plane-controller-manager-79ddf6c498-lckn9   1/1     Running   0          9m37s
capi-system                         capi-controller-manager-698c5749d4-prxw5                         1/1     Running   0          9m46s
capone-system                       capone-controller-manager-5cfc7d5f85-8r7tw                       1/1     Running   0          9m36s
rancher-turtles-system              caapf-controller-manager-6b9b6ccdc-27vz7                         2/2     Running   0          9m35s
rancher-turtles-system              rancher-turtles-controller-manager-546957d6dc-d4t2z              1/1     Running   0          10m
rke2-bootstrap-system               rke2-bootstrap-controller-manager-8567757df9-cnzvr               1/1     Running   0          9m31s
rke2-control-plane-system           rke2-control-plane-controller-manager-6cdf48586d-dzqfm           1/1     Running   0          9m29s
Check the virtual machines in order to see if the cluster has been finally deployed:
onevm list
When the deployment finishes you will see the following list of VMs: 1 vRouter instance with control plane Kubernetes API as backend (with the vr- suffix), 1 control plane node, and 2 worker nodes (with the md-0 affix in the name).
ID USER     GROUP    NAME                                  STAT  CPU     MEM HOST
448 oneadmin oneadmin k8s-gpu-test-md-0-m5tzv-drg4k         runn   16     32G vgpu2
447 oneadmin oneadmin k8s-gpu-test-md-0-m5tzv-btvn4         runn   16     32G vgpu2
446 oneadmin oneadmin k8s-gpu-test-qb8dl                    runn   16     32G vgpu2
445 oneadmin oneadmin vr-k8s-gpu-test-cp-0                  runn    2    512M vgpu2
Connecting to the Workload Cluster Kubernetes API Locally
To establish a local connection to the Workload Cluster Kubernetes API, you will need to export the following environment variables. The $VROUTER_IP will contain the public IP address of the vRouter instance, and the $CONTROL_PLANE_IP will contain the IP address of the workload cluster control plane instance. Here, we will connect directly to the Kubernetes cluster from the OpenNebula frontend, to make things simpler. Note that the virtual machines change on each deploy, so change the name of the vRouter and control plane instance appropriately in the following code block:
export VROUTER_VM_NAME=<changeme>
export CONTROL_PLANE_VM_NAME=<changeme>
export VROUTER_IP=$(onevm show $VROUTER_VM_NAME -j | jq '.VM.TEMPLATE.NIC[0].VROUTER_IP' | tr -d '"')
export CONTROL_PLANE_IP=$(onevm show $CONTROL_PLANE_VM_NAME -j | jq '.VM.TEMPLATE.NIC[0].IP' | tr -d '"')
for instance, corresponding to our previous example:
export VROUTER_VM_NAME=vr-k8s-gpu-test-cp-0
export CONTROL_PLANE_VM_NAME=k8s-gpu-test-qb8dl
echo the declared variables for checking they have been properly filled:
echo $VROUTER_IP
echo $CONTROL_PLANE_IP
you should see an output like this (the IP addresses could change depending on the environment):
192.168.100.51
192.168.100.54
To access the Kubernetes API from your localhost, use the kubeconfig file that is located in the /etc/rancher/rke2/rke2.yaml file of the workload cluster control plane node.
ssh -J root@$VROUTER_IP root@$CONTROL_PLANE_IP cat /etc/rancher/rke2/rke2.yaml | \
    sed "s|server: https://127.0.0.1:6443|server: https://$VROUTER_IP:6443|">  kubeconfig_workload.yaml
Connect to the workload cluster through kubectl, checking for instance the workload cluster nodes:
kubectl --kubeconfig=kubeconfig_workload.yaml get nodes
This command should output the workload cluster nodes:
k8s-gpu-test-md-0-m5tzv-btvn4   Ready    <none>                      8d    v1.31.4+rke2r1
k8s-gpu-test-md-0-m5tzv-drg4k   Ready    <none>                      8d    v1.31.4+rke2r1
k8s-gpu-test-qb8dl              Ready    control-plane,etcd,master   8d    v1.31.4+rke2r1
If you want to avoid setting the --kubeconfig flag each time you use kubectl, export an env variable referencing the kubeconfig file. This will make kubectl refer to that kubeconfig by default on the shell that you are using:
export KUBECONFIG="$PWD/kubeconfig_workload.yaml"
NVIDIA GPU Operator Installation
The NVIDIA GPU Operator executes the necessary steps for allowing NVIDIA GPU workloads in Kubernetes using the device plugin framework. The managed components includes:
The procedure to install the NVIDIA GPU Operator is as follows:
  1. Add the NVIDIA helm repo:
    helm repo add nvidia https://helm.ngc.nvidia.com/nvidia \
    && helm repo update
  2. Export the KUBECONFIG variable.
  3. Deploy the gpu-operator on the workload cluster:
    # create gpu-operator namespace
    kubectl create ns gpu-operator
    # enforce privileged pods on that namespace
    kubectl label --overwrite ns gpu-operator pod-security.kubernetes.io/enforce=privileged
    # install the helm chart
    helm install --wait --generate-name \
        -n gpu-operator --create-namespace \
        nvidia/gpu-operator \
        --version=v25.3.2 \
        --set "toolkit.env[0].name=CONTAINERD_CONFIG" \
        --set "toolkit.env[0].value=/var/lib/rancher/rke2/agent/etc/containerd/config.toml" \
        --set "toolkit.env[1].name=CONTAINERD_SOCKET" \
        --set "toolkit.env[1].value=/run/k3s/containerd/containerd.sock" \
        --set "toolkit.env[2].name=CONTAINERD_RUNTIME_CLASS" \
        --set "toolkit.env[2].value=nvidia" \
        --set "toolkit.env[3].name=CONTAINERD_SET_AS_DEFAULT" \
        --set-string "toolkit.env[3].value=true"
    Note that you have specified the CONTAINERD_CONFIG and CONTAINERD_SOCKET paths for the rke2 Kubernetes distribution, as it’s using a different one than the default.
    After a successful Helm installation, you will see this output:
    LAST DEPLOYED: Thu Jul 31 10:13:01 2025
    NAMESPACE: gpu-operator
    STATUS: deployed
    REVISION: 1
    TEST SUITE: None
  4. Check that the deployed pods for the gpu-operator are up and running:
    kubectl get pods -n gpu-operator
    You should see the following pods running on the gpu-operator namespace:
    gpu-feature-discovery-f9fs6                                       1/1     Running     0          8d
    gpu-feature-discovery-q7h26                                       1/1     Running     0          8d
    gpu-operator-1753950388-node-feature-discovery-gc-854b7fb8jr989   1/1     Running     0          8d
    gpu-operator-1753950388-node-feature-discovery-master-955d78rh4   1/1     Running     0          8d
    gpu-operator-1753950388-node-feature-discovery-worker-4tvlv       1/1     Running     0          8d
    gpu-operator-1753950388-node-feature-discovery-worker-d7sxz       1/1     Running     0          8d
    gpu-operator-1753950388-node-feature-discovery-worker-zb5gj       1/1     Running     0          8d
    gpu-operator-84f4699cc4-kdcjn                                     1/1     Running     0          8d
    nvidia-container-toolkit-daemonset-d5fwk                          1/1     Running     0          8d
    nvidia-container-toolkit-daemonset-k54w7                          1/1     Running     0          8d
    nvidia-cuda-validator-gmnrq                                       0/1     Completed   0          8d
    nvidia-cuda-validator-vl94m                                       0/1     Completed   0          8d
    nvidia-dcgm-exporter-g5j2n                                        1/1     Running     0          8d
    nvidia-dcgm-exporter-g6x99                                        1/1     Running     0          8d
    nvidia-device-plugin-daemonset-rhj8z                              1/1     Running     0          8d
    nvidia-device-plugin-daemonset-v5bcq                              1/1     Running     0          8d
    nvidia-operator-validator-ctg6s                                   1/1     Running     0          8d
    nvidia-operator-validator-z52q7                                   1/1     Running     0          8d
  5. Check if the Kubernetes nodes gpu autodiscovery operates as expected, by checking the workload nodes, for instance the nvidia.com/* labels and the allocatable gpu capacity:
    kubectl describe node <kubernetes_workload_node_name>
    for instance, in the example above:
    kubectl describe node k8s-gpu-test-md-0-m5tzv-drg4k
    Those are the labels you should see
                        nvidia.com/gpu.memory=46068
                        nvidia.com/gpu.mode=compute
                        nvidia.com/gpu.present=true
                        nvidia.com/gpu.product=NVIDIA-L40S
                        nvidia.com/gpu.replicas=1
    Capacity:
    cpu:                16
    ephemeral-storage:  202051056Ki
    hugepages-1Gi:      0
    hugepages-2Mi:      0
    memory:             32855784Ki
    nvidia.com/gpu:     1
    pods:               110
    Allocatable:
    cpu:                16
    ephemeral-storage:  196555267123
    hugepages-1Gi:      0
    hugepages-2Mi:      0
    memory:             32855784Ki
    nvidia.com/gpu:     1
    pods:               110
  6. Finally, to use the PCI GPUs on the specific pod, add the spec.runtimeClassName:nvidia parameter in the pod/deploy manifest and set nvidia.com/gpu:1 as a requested resource.
Verification:
To use the PCI GPU in a pod deployment add the spec.runtimeClassName:nvidia parameter in the pod/deploy manifest and set nvidia.com/gpu:1 as a requested resource.
For example, we can deploy a job targeting the NVIDIA GPU. Create a manifest with the following schema as l40s-verify.yaml:
apiVersion: batch/v1
kind: Job
metadata:
spec:
  template:
    spec:
      # Maps the pod to the NVIDIA Container Toolkit
      runtimeClassName: nvidia
      containers:
      - name: cuda-test
        image: nvidia/cuda:12.4.1-base-ubuntu22.04
        command: ["nvidia-smi"]
        resources:
          limits:
            # Requests exactly 1 physical GPU
            nvidia.com/gpu: 1
          requests:
            nvidia.com/gpu: 1
      # Ensures the pod doesn't loop if it fails
      restartPolicy: Never
  backoffLimit: 0
Then apply the job:
kubectl apply -f l40s-verify.yaml & kubectl get pods -l job-name=l40s-verify-gpu -w
Then check the logs:
kubectl logs -l job-name=l40s-verify-gpu
Then delete for cleanup:
kubectl delete -f l40s-verify.yaml
