Key Features
OpenNebula offers a simple but feature-rich and flexible solution to build and manage data center virtualization and enterprise clouds. This page provides a summary of its key features(*).
To learn more about the infrastructure platforms and services supported in each version of OpenNebula, please refer to the Platform Notes for each version.
For high-level overviews and in-depth technical guides, please refer to OpenNebula’s White Papers.
INTERFACES
- Simple, clean, intuitive GUI, with different views for cloud admins and end users
- Powerful command-line tools resembling typical Unix tools
- API in multiple languages
APPLICATION MANAGEMENT AND CATALOG
- Easy self-provision of containerized and virtualized workflows from a catalog
- Secure sharing of applications with other cloud users
- Multi-tier applications with auto-scaling
- Gain insight into applications to query their status and metrics, and use them in auto-scaling
APPLIANCE MARKETPLACE
- Public Marketplace with pre-built applications ( PaaS, K8S, CI/CD…)
- Build your private Marketplace to share and distribute applications within your organization
- Integration with third-party public or private Marketplaces such as Linux Containers
CHARGEBACK
- Fine-grained accounting and monitoring
- Showback capability enabling integration with chargeback and billing systems
CAPACITY AND PERFORMANCE MANAGEMENT
- Fine-grained ACLs for resource allocation
- Resource Quota Management to track and limit resource utilization
- Dynamic creation of Clusters as pools of Hosts
- Dynamic creation of Virtual Data Centers as fully-isolated virtual environments
- Federation of multiple Zones for scalability, isolation or multiple-site support
- Powerful and flexible Scheduler - deploy your workload in different locations
HIGH AVAILABILITY AND BUSINESS CONTINUITY
- High-availability architecture
- Persistent database backend with support for high-availability configurations
- Configurable behavior in the event of failure, for cost-effective failover solutions
VIRTUAL INFRASTRUCTURE MANAGEMENT
- Virtual infrastructure management adjusted for enterprise data centers
- Complete life cycle management of virtual resources
- Powerful hooking system
- Full control, monitoring, and accounting of virtual infrastructure resources
- Fine-grained multi-tenancy
TRUE HYBRID AND EDGE CLOUD
- Dynamically grow your private cloud with remote cloud providers
- Automatic provision of remote resources
PLATFORM
- Fully platform independent
- Broad support for commodity and enterprise-grade infrastructure platforms
- Packages for major Linux distributions
SECURITY
- Fine-grained ACLs and user quotas
- Powerful user, group, and role management
- Integration with enterprise and open source user management services
- Login token functionality
- Fine-grained auditing and support for isolation at different levels
INTEGRATION WITH THIRD-PARTY TOOLS
- Modular and extensible architecture
- Customizable plug-ins for integration with any third-party data center service
- API for integration with higher-level tools such as billing, self-service portals, and more
LICENSING
- Fully open source software released under the Apache license
UPGRADE PROCESS
- Automatic import of existing environments
- All key functionalities for enterprise cloud in a single install
- Long-term stability and performance through a single patching and upgrade process
QUALITY ASSURANCE
- Internal quality assurance process
- Technology matured through a large, active, and engaged community
- Scalability and performance tested on many massive scalable deployments
PRODUCT SUPPORT
- Best-effort community support
- SLA-based commercial support directly from the developers
(*) Because OpenNebula leverages the functionality exposed by the underlying platform services, its functionality and performance may be affected by the limitations imposed by those services.
- The list of features may change on the different platform configurations
- Not all platform configurations exhibit similar performance and stability
- The features may change to offer users more features and integration with other virtualization and cloud components
- The features may change due to changes in the functionality provided by underlying virtualization services
