Run a Kubernetes Cluster on OpenNebula
Overview
Previous tutorials of this Quick Start guide show how to use miniONE to:
- Install an OpenNebula Front-end and a KVM Host on-premises
- Install an OpenNebula Front-end and a KVM Host on AWS
- Validate the environment created by miniONE, by running a Virtual Machine
This tutorial builds on the infrastructure created in those previous tutorials. By following it, you can:
- Download a complete Kubernetes cluster from the OpenNebula Public Marketplace
- Deploy the cluster on the KVM Host installed by miniONE
- Validate the cluster by running a simple test application
This tutorial was designed and tested on an AWS metal instance – the same c5.metal
instance used for the miniONE on AWS guide. However, you should also be able to complete this tutorial on an on-premises installation with sufficient resources (for requirements, see Deploy OpenNebula On-prem).
Tip
If deploying on-prem, you can also install and manage Kubernetes with Rancher as part of this Quick Start guide.As mentioned above, the Kubernetes cluster deployed in this tutorial is available in the OpenNebula Public Marketplace. You can find it as the multi-VM appliance Service OneKE, the OpenNebula Kubernetes Edition.
To deploy the Kubernetes cluster, we’ll follow these high-level steps:
- Download the OneKE Service from the OpenNebula Marketplace.
- Instantiate a private network on the Edge Cluster.
- Instantiate the Kubernetes Service.
- Deploy an application on Kubernetes.
In this tutorial we’ll perform a basic install of the Kubernetes cluster plus the Traefik ingress router and Longhorn storage. The OneKE appliance offers additional options such as High Availability, load balancing and CNI plugins, which are out of the scope of this guide.
Tip
For more information about OneKE, please see OneKE Service (Kubernetes). The full documentation for OneKE is available in the OpenNebula Apps Documentation.Step 1. Download the OneKE Service from the OpenNebula Marketplace
The OpenNebula Public Marketplace is a repository of Virtual Machines and appliances which are curated, tested and certified by OpenNebula.
The Kubernetes cluster is packaged in a multi-VM service appliance listed as Service OneKE
Open the left-hand pane, then select Storage -> Apps. Sunstone will display the Apps screen, showing the first page of apps that are available for download.
In the search field at the top, type oneke
to filter by name. Then, select Service OneKE
Click the Import button.
As with the WordPress appliance, Sunstone displays the Download App to OpenNebula wizard. In the first screen of the wizard, click Next.
In the second screen you will need to select a datastore for the appliance. Select the default datastore.
Click Finish. Sunstone will import the appliance template and display a message at bottom right. To see the imported template, in the left-hand menu select Templates -> Service Templates:
Step 2. Instantiate a Private Network on the Cloud Cluster
In this step we will create a new virtual network and assign a range of private IPs to. This will network will be used by the OneKE service for internal communication.
In Sunstone, open the left-hand pane, then select Networks -> Virtual Networks. Sunstone displays the Virtual networks page showing the network automatically created by miniONE:
Click the Create button at the top. Sunstone will display the Create Virtual Network screen. Enter a name for the network – for this example we will use privnet
. Then, click Next.
In the next screen, activate the Use only private host networking switch:
Then, click the Addresses tab. Here we will enter a range of private IP addresses. For this example, enter 192.168.200.2
for the base network address, and set the network size to 100
Click Finish.
Step 3. Instantiate the Kubernetes Service
In the left-hand pane, select Templates -> Service Templates.
Select Service OneKE 1.31, then click the Instantiate icon .
Sunstone displays the Instantiate Service Template wizard. In the first screen you can give your service a name and specify the number of instances to instantiate. In this example we’ll leave the default name Service OneKE 1.31
and start a single instance.
Click Next to go to the next screen, Networks.
Here we will select the private and the public network for the OneKE service.
To select the public network, click the Public tab on the left, then select network vnet. For the private network, click the Private tab, then select privnet.
Click Next. Sunstone displays the Service Inputs screen:
Here you can define parameters for the cluster, including a custom domain, plugins, VNF routers, storage options and others.
For this tutorial we’ll apply the following configuration:
In the Kubernetes Cluster tab, scroll down and activate Enable Longhorn. Then scroll down to the bottom of the page and Enable Traefik.
Click Next.
In the last screen, click Finish.
Verify the OneKE Service Deployment
To verify that the OneKE Service has correctly deployed, you can either use the Sunstone UI, or the command line the Front-end node.
To verify in the Sunstone GUI, open the left-hand pane, then Select Instances -> Services. You should see the OneKE service up and running. Its running VMs should be visible in the Roles tab.
To verify the deployment using the command line, log in to the Front-end node as user oneadmin
, then run oneflow list
. In the command output, check that the State is RUNNING
, as shown below. Bear in mind that the service may take a few moments to display the RUNNING
state.
[oneadmin@FN]$ oneflow list
ID USER GROUP NAME STARTTIME STAT
1 oneadmin oneadmin Service OneKE 1.31 04/29 08:18:17 RUNNING
To verify that the VMs for the cluster were correctly deployed, you can use the onevm list
command. In the example below, the command lists the VMs for the cluster:
oneadmin@ip-172-31-47-22:~$ onevm list
ID USER GROUP NAME STAT CPU MEM HOST TIME
6 oneadmin oneadmin worker_0_(service_2) runn 2 3G localhost 0d 00h00
5 oneadmin oneadmin master_0_(service_2) runn 2 3G localhost 0d 00h00
4 oneadmin oneadmin vnf_0_(service_2) runn 1 512M localhost 0d 00h00
At this point you have successfully instantiated the Kubernetes cluster on your local hypervisor.
If the state of the OneKE service as reported by oneflow list
remains in DEPLOYING
, see below.
Before deploying the test application described in this tutorial, you will need to find out the IP address of the VNF node on the public network – in this case, the vnet network that we set as public network when instantiating the OneKE service – since this is the address that we will use to connect to the application.
Check the IP Address for the VNF Node
To check the VNF node IP in Sunstone, in the left-hand pane go to Instances -> VMs, then check the information displayed under vnf_0_(service_172.16.100.2
Alternatively, to check on the command line, on the Front-end node as user oneadmin
run:
onevm show <VM ID> | less
(Replace VM ID
for the VM ID number as shown by onevm show
, in this case 4
This displays the complete information for the VM, piped through the less
pager. Use the up and down arrow to scroll, until you find the VM NICS
table:
VM NICS
ID NETWORK BRIDGE IP MAC PCI_ID
0 vnet minionebr 172.16.100.2 02:00:ac:10:64:02
1 privnet onebr1 192.168.200.2 02:00:c0:a8:c8:02
2 vnet minionebr 172.16.100.3 02:00:ac:10:64:03
3 privnet onebr1 192.168.200.3 02:00:c0:a8:c8:03
The relevant IP is the first displayed for the vnet
network, 172.16.100.2
To stop displaying the information for the VM, press q
If you do not see all VMs listed, or if the OneKE Service is stuck in DEPLOYING
, see Known Issues below.
Tip
Once the OneFlow service has deployed, you can add more worker nodes. In Sunstone:
- Go to Instances -> Services.
- Select the OneKE service.
- Select the Roles tab.
- Click Worker, then the green Scale button.
Step 5. Deploy an Application
In this tutorial we will deploy a very simple application designed for training purposes: a MariaDB database to which you can add sample data from the Kubernetes master. The database will reside in the Kubernetes cluster’s Longhorn storage, so the first step is to enable storage for the cluster.
Enable Longhorn Storage
We can enable Longhorn storage with a single command:
oneflow scale <OneKE service ID> storage 1
Most probably, the OneKE service ID
should be 1
. You can find out with the oneflow list
command:
In the example above, the ID is 1
, so:
oneflow scale 1 storage 1
This will create a Virtual Machine as part of the OneKE Service which will serve as Longhorn storage for the Kubernetes cluster.
The command will take a moment to execute. During that time the OneKE service will change state, from RUNNING
to COOLDOWN
and back to RUNNING
. You must wait until this cycle is finished to continue with the next steps. You can continuously check the status of the cluster by running (as oneadmin
on the Front-end node):
oneflow top
This produces the output of oneflow list
, updated continuously. Once the status is RUNNING
, to exit the command type Ctrl+C
On the Front-end node, we can check the status of the newly-created storage VM with onevm list
7 oneadmin oneadmin storage_0_(service_2) runn 2 3G localhost 0d 04h38
6 oneadmin oneadmin worker_0_(service_2) runn 2 3G localhost 0d 05h36
5 oneadmin oneadmin master_0_(service_2) runn 2 3G localhost 0d 05h36
4 oneadmin oneadmin vnf_0_(service_2) runn 1 512M localhost 0d 05h36
Log into the Master Node and Deploy the Application
First, we will need to connect to the Kubernetes master node via SSH. To this, we need to use the VNF node as “jump host”, i.e. we connect first to the VNF node and from there to the Kubernetes master node.
As we have seen above, in this example the IP address of the VNF is 172.16.100.2
. With our network configuration, the IP address for the Kubernetes master node is probably 192.168.200.4
(the second IP address in the private network privnet
that we assigned to the OneKE service). Of course if your configuration varies (for example if you installed additional networked Virtual Machines before deploying the OneKE service), then you will have to use the appropriate IPs.
To connect to the Kubernetes master node, from the Front-end, as user root
run:
ssh -A -J root@172.16.100.2 root@192.168.200.4
An example run as user root
root@ip-172-31-47-22:~# ssh -A -J 172.16.100.2 192.168.200.4
Warning: Permanently added '172.16.100.2' (ED25519) to the list of known hosts.
The authenticity of host '192.168.200.4 (<no hostip for proxy command>)' can't be established.
ED25519 key fingerprint is SHA256:8fbzSN9OgOGZ1+2Zfdiq9r/6e+yEIJe1Ar6cqLpZ2Cw.
This key is not known by any other names.
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
Warning: Permanently added '192.168.200.4' (ED25519) to the list of known hosts.
Welcome to Ubuntu 22.04.5 LTS (GNU/Linux 5.15.0-126-generic x86_64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/pro
System information as of Wed Jun 4 10:10:11 UTC 2025
System load: 0.61
Usage of /: 4.8% of 24.05GB
Memory usage: 8%
Swap usage: 0%
Processes: 106
Users logged in: 0
IPv4 address for eth0: 10.0.2.15
IPv6 address for eth0: fec0::211:22ff:fe33:4455
* Strictly confined Kubernetes makes edge and IoT secure. Learn how MicroK8s
just raised the bar for easy, resilient and secure K8s cluster deployment.
https://ubuntu.com/engage/secure-kubernetes-at-the-edge
Expanded Security Maintenance for Applications is not enabled.
8 updates can be applied immediately.
8 of these updates are standard security updates.
To see these additional updates run: apt list --upgradable
1 additional security update can be applied with ESM Apps.
Learn more about enabling ESM Apps service at https://ubuntu.com/esm
The list of available updates is more than a week old.
To check for new updates run: sudo apt update
___ _ __ ___
/ _ \ | '_ \ / _ \ OpenNebula Service Appliance
| (_) || | | || __/
\___/ |_| |_| \___|
2/3 Configuration step is in progress...
* PLEASE WAIT *
In the above example the Kubernetes master is self-configuring, hence the “PLEASE WAIT” message.
Once you have connected to the Kubernetes master node, check if kubectl
is working, by running kubectl get nodes
root@oneke-ip-192-168-200-4:~# kubectl get nodes
NAME STATUS ROLES AGE VERSION
oneke-ip-192-168-200-4 Ready control-plane,etcd,master 5h32m v1.31.3+rke2r1
oneke-ip-192-168-200-6 Ready <none> 5h32m v1.31.3+rke2r1
oneke-ip-192-168-200-8 Ready <none> 4h38m v1.31.3+rke2r1
The last row in the output is the storage
role in the cluster created in the previous step, with IP 172.168.200.8
Now we are ready to download and deploy our example application.
We can download the application from the master node itself, by running:
wget https://github.com/alpeon/training-files/raw/refs/heads/main/OneKE/test-app.tar
This downloads the test-app.tar
package file. Unpack it with:
tar xvf test-app.tar
This creates the test-app
directory, which contains the YAML manifest files we will use to deploy the application.
Switch to the test-app
directory:
cd test-app
Create all of the applications in the directory:
kubectl apply -f .
For example:
root@oneke-ip-192-168-200-4:~/test-app# kubectl apply -f .
deployment.apps/mariadb created
persistentvolumeclaim/mariadb-data created
service/mariadb created
deployment.apps/test-app created
ingressroute.traefik.io/test-app-ingress created
service/test-app-service created
Check the status of the applications:
kubectl get pods
This should display the status of the database and the test-app
application:
NAME READY STATUS RESTARTS AGE
mariadb-55496464b6-66kl9 1/1 Running 0 45s
test-app-56b5745c76-bxxld 1/1 Running 0 45s
The process may take some seconds to complete. When both pods display status Running
, we are ready to connect to the application.
Connect to the Application
From the Front-end node, as user oneadmin
run curl <VNF node IP>
. In our case:
curl 172.16.100.2
You should be greeted with:
oneadmin@ip-172-31-47-22:~$ curl 172.16.100.2
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>Spaceship: Nebula Explorer</title>
</head>
<body>
<div>
<h1>
'sup Space Man, want to explore some Nebula?
</h1>
<div>
Visit /create-db to create the database
<br>
Visit /insert-dummy to insert some dummy data
<br>
Visit /get-data to print out the dummy data
</div>
<div>
<h2>
See you, Space Cowboy!
</h2>
<pre>
</pre>
Now we can create the database with:
curl 172.16.100.2/create-db
This should return the following:
oneadmin@ip-172-31-47-282:~$ curl 172.16.100.2/create-db
{"message":"Table 'data' created successfully"}
To insert some dummy data into the database:
curl 172.16.100.2/insert-dummy
Repeat this commands to insert more than one data point. Then, verify the inserted data with:
curl 172.16.100.2/get-data
For example:
oneadmin@ip-172-31-47-22:~$ curl 172.16.100.2/get-data
[{"data1":"2025-06-23 11:51:27","data2":"50","id":1},{"data1":"2025-06-23 11:51:54","data2":"63","id":2},{"data1":"2025-06-23 11:52:09","data2":"84","id":3}]
And that’s it – you have successfully deployed a Kubernetes cluster, and deployed and tested an application.
For more information including additional features for the OneKE Appliance, please refer to the OpenNebula Apps Documentation.
Known Issues
OneFlow Service is Stuck in DEPLOYING
An error in network configuration, or any major failure (such as network timeouts or performance problems) can cause the OneKE service to lock up due to a communications outage between it and the Front-end node. The OneKE service will lock if any of the VMs belonging to it does not report READY=YES
to OneGate within the default time.
If one or more of the VMs in the Kubernetes cluster never leave the DEPLOYING
state, you can troubleshoot OneFlow communications by inspecting the file /var/log/one/oneflow.log
on the Front-end node. Look for a line like the following:
[E]: [LCM] [one.document.info] User couldn't be authenticated, aborting call.
The line above means that provisioning the service exceeded the allowed time. In this case it is not possible to recover the broken VM instance; it must be recreated.
Before attempting to recreate the instance, ensure that your environment has a good connection to the public Internet and does not suffer from any impairments in performance.
To recreate the VM instance, you must first terminate the OneKE service. A service stuck in DEPLOYING
cannot be terminated by the delete
operation. To terminate it, you need to run the following command:
oneflow recover --delete <service_ID>
Then, re-instantiate the service from the Sunstone UI: in the left-hand pane, Service Templates -> OneKE 1.31, then click the Instantiate icon.
One or more VMs Fail to Report Ready
Another possible cause for failure of the OneKE Service to leave the DEPLOYING
state is that a temporary network glitch or other variation in performance prevented one or more of the VMs in the service to report READY
to the OneGate service. In this case, it is possible that you see all of the VMs in the service up and running, but the OneKE service is stuck in DEPLOYING
For example on the Front-end, the output of onevm list
shows all VMs running:
6 oneadmin oneadmin worker_0_(service_2) runn 2 3G localhost 0d 01h36
5 oneadmin oneadmin master_0_(service_2) runn 2 3G localhost 0d 01h36
4 oneadmin oneadmin vnf_0_(service_2) runn 1 512M localhost 0d 01h37
Yet oneflow list
indicates the OneKE service is DEPLOYING
2 oneadmin oneadmin OneKE 1.31 06/20 12:30:07 DEPLOYING
In this case you can manually instruct the VMs to report READY
to the OneGate server. Follow these steps:
From the Front-end node, log in to the VNF node as user
root
, by running:ssh root@<VNF IP>
(To find out the IP address of the VNF node, see above.)
For each VM in the OneKE service, run:
onegate vm update <ID> --data "READY=YES"
For each VM, use the ID reported by the
onevm list
command. For example, given theonevm
output shown above, to update the Kubernetes master node runonegate vm update 5 --data "READY=YES"
.Then, on the VNF node you can check the status of the service with
onegate vm show
:SERVICE 3 NAME : OneKE 1.31 STATE : RUNNING ROLE vnf VM 1 NAME : vnf_0_(service_2) ROLE master VM 2 NAME : master_0_(service_2) ROLE worker VM 3 NAME : worker_0_(service_2) ROLE storage
On the Front-end, run
oneflow list
again to verify that the service reportsRUNNING
:[oneadmin@FN]$ oneflow list ID USER GROUP NAME STARTTIME STAT 2 oneadmin oneadmin OneKE 1.31 08/30 12:35:21 RUNNING
One or more VMs is Ready, but Unreachable
As in the previous situation, here onevm list
shows all VMs running, but the service is stuck in DEPLOYING
; additionally, the VNF VM is not reachable through SSH – and hence you cannot run the onegate vm update
command.
In this case, we can try to scale down and up the role of the problematic VM from Sunstone, web UI:
- In Sunstone, go to Services, then select the OneKE Service.
- In the Roles tab, choose the problematic VM’s role (e.g.
worker
).- Scale the role to
0
.- Wait until VM shuts down and the scaling and cooldown period of the service finishes.
- Scale the role to
1
.- Verify if the problem is solved and
oneflow list
reports theRUNNING
state.
