Virtual Machine Instances
This guide may be considered a continuation of the Virtual Machines Templates guide. Once a Template is instantiated to a Virtual Machine, there are a number of operations that can be performed using the onevm command.
Basic Virtual Machine Operations
Creating and Listing VMs
Assuming we have a VM template registered called vm-example with ID 6, then we can instantiate the VM by issuing a:
$ onetemplate list
  ID USER     GROUP    NAME                         REGTIME
   6 oneadmin oneadmin vm_example            09/28 06:44:07
$ onetemplate instantiate vm-example --name my_vm
VM ID: 0
If the template has USER INPUTS defined, the CLI will prompt the user for these values:
  * (BLOG_TITLE) Blog Title: <my_title>
  * (DB_PASSWORD) Database Password:
VM ID: 0
Afterwards, the VM can be listed with the onevm list command. You can also use the onevm top command to list VMs continuously.
$ onevm list
    ID USER     GROUP    NAME         STAT CPU     MEM        HOSTNAME        TIME
     0 oneadmin oneadmin my_vm        pend   0      0K                 00 00:00:03
The scheduler will automatically deploy the VM in one of the Hosts with enough resources available. The deployment can also be forced by oneadmin using onevm deploy:
$ onehost list
  ID NAME               RVM   TCPU   FCPU   ACPU   TMEM   FMEM   AMEM   STAT
   2 testbed              0    800    800    800    16G    16G    16G     on
$ onevm deploy 0 2
$ onevm list
     0 oneadmin oneadmin my_vm        runn   0      0K         testbed 00 00:02:40
and details about it can be obtained with show:
$ onevm show 0
VIRTUAL MACHINE 0 INFORMATION
STATE               : ACTIVE
LCM_STATE           : RUNNING
START TIME          : 04/14 09:00:24
END TIME            : -
DEPLOY ID:          : one-0
OWNER          : um-
GROUP          : ---
OTHER          : ---
VIRTUAL MACHINE MONITORING
NET_TX              : 13.05
NET_RX              : 0
USED MEMORY         : 512
USED CPU            : 0
VIRTUAL MACHINE TEMPLATE
VIRTUAL MACHINE HISTORY
 SEQ        HOSTNAME REASON           START        TIME       PTIME
   0         testbed   none  09/28 06:48:18 00 00:07:23 00 00:00:00
Searching for VM Instances
You can search for VM instances by using the --search option of the onevm list command. This is especially useful on large environments with many VMs. The filter must be in a VM.KEY1=VALUE1&VM.KEY2=VALUE2 format and will return all the VMs which fit the filter. The & works as logical AND. You can use *=VALUE to search the full VM body or VM.TEMPLATE=VALUE to search whole template.
Searching is performed using JSON on the whole body of the VM. You can use the MySQL JSON path without the leading $., information about the path structure can be found in the MySQL Documentation or MariaDB Documentation. Currently, the value is wrapped in % for the query, so it will match if it contains the value provided.
The VALUE part of a search query can utilize special characters to create flexible matching patterns:
  • %: Matches any string, allowing for wildcard searches. For example, a%a%a matches names containing three “a”s in any position, with any number of characters between them.
  • _: Matches any single character, enabling precise pattern matching. For instance, a_a_a matches names with three “a”s, each separated by exactly one character.
  • &: Cannot be used in the VALUE part of the search query, as it is always interpreted as logical AND operator and does not support escaping.
To search for strings that contain % or _ literally, escape these characters with a backslash \. For example:
  • a\%a will search for “a%a” as an exact sequence.
  • a\_a will match “a_a” without interpreting _ as a single-character wildcard.
For example, for to search for a VM with a specific MAC address:
$ onevm list --search 'VM.TEMPLATE.NIC[*].MAC=02:00:0c:00:4c:dd'
 ID    USER     GROUP    NAME    STAT UCPU UMEM HOST TIME
 21005 oneadmin oneadmin test-vm pend    0   0K      1d 23h11
Equivalently, if there is more than one VM instance that matches the result they will be shown. For example, VM’s NAME containing a pattern and owned by oneadmin:
$ onevm list --search 'VM.NAME=test-vm&VM.UNAME=oneadmin'
 21005 oneadmin oneadmin test-vm  pend    0   0K       1d 23h13
 2100  oneadmin oneadmin test-vm2 pend    0   0K      12d 17h59
Terminating VM Instances
You can terminate an instance with the onevm terminate command, from any state. It will shut down (if needed) and delete the VM. This operation will free the resources (images, networks, etc.) used by the VM.
If the instance is running, there is a --hard option that has the following meaning:
  • terminate: Gracefully shuts down and deletes a running VM, sending the ACPI signal. Once the VM is shut down the Host is cleaned and persistent and deferred-snapshot disk will be moved to the associated datastore. If after a given time the VM is still running (e.g., guest ignoring ACPI signals), OpenNebula will return the VM to the RUNNING state.
  • terminate --hard: Same as above but the VM is immediately destroyed. Use this action instead of terminate when the VM doesn’t have ACPI support.
Pausing VM Instances
There are two different ways to temporarily stop the execution of a VM: short and long term pauses. A short term pause keeps all the VM resources allocated to the Hosts so it resumes its operation in the same Hosts quickly. Use the following onevm commands or Sunstone actions:
  • suspend: the VM state is saved in the running Host. When a suspended VM is resumed, it is immediately deployed in the same Host by restoring its saved state.
  • poweroff: Gracefully powers off a running VM by sending the ACPI signal. It is similar to suspend but without saving the VM state. When the VM is resumed it will boot immediately in the same Host.
  • poweroff --hard: Same as above but the VM is immediately powered off. Use this action when the VM doesn’t have ACPI support.
You can also plan a long term pause. The Host resources used by the VM are freed and the Host is cleaned. VM disk state is saved in the system datastore. The following actions are useful if you want to preserve network and storage allocations (e.g., IPs, persistent disk images):
  • undeploy: Gracefully shuts down a running VM, sending the ACPI signal. The Virtual Machine disks are transferred back to the system datastore. When an undeployed VM is resumed it is moved to the pending state and the scheduler will choose where to re-deploy it.
  • undeploy --hard: Same as above but the running VM is immediately destroyed.
  • stop: Same as undeploy but also the VM state is saved to resume it later.
When the VM is successfully paused you can resume its execution with:
  • resume: Resumes the execution of VMs in the stopped, suspended, undeployed, and poweroff states.
Rebooting VM Instances
Use the following commands to reboot a VM:
  • reboot: Gracefully reboots a running VM, sending the ACPI signal.
  • reboot --hard: Performs a ‘hard’ reboot.
Delaying VM Instances
The deployment of a PENDING VM (e.g., after creating or resuming it) can be delayed with:
  • hold: Sets the VM to hold state. The scheduler will not deploy VMs in the hold state. Please note that VMs can be created directly on hold by using ‘onetemplate instantiate –hold’ or ‘onevm create –hold’.
Then you can resume it with:
  • release: Releases a VM from hold state, setting it to pending. Note that you can automatically release a VM by scheduling the operation as explained below.
Hotplug Devices to a Virtual Machine
Disk Hot-plugging
New disks can be hot-plugged to running VMs with the onevm, disk-attach, and disk-detach commands. For example, to attach the Image named storage to a running VM:
$ onevm disk-attach one-5 --image storage
To detach a disk from a running VM, find the disk ID of the Image you want to detach using the onevm show command, and then simply execute onevm detach vm_id disk_id:
$ onevm show one-5
DISK=[
  DISK_ID="1",
$ onevm disk-detach one-5 1
NIC Hot-plugging
You can hot-plug network interfaces to VMs in the RUNNING, POWEROFF, or SUSPENDED states. Simply specify the network where the new interface should be attached, for example:
$ onevm show 2
VIRTUAL MACHINE 2 INFORMATION
STATE               : ACTIVE
LCM_STATE           : RUNNING
VM NICS
ID NETWORK      VLAN BRIDGE   IP              MAC
 0 net_172        no vbr0     172.16.1.201    02:00:ac:10:0
$ onevm nic-attach 2 --network net_172
After the operation you should see two NICs, 0 and 1:
$ onevm show 2
STATE               : ACTIVE
LCM_STATE           : RUNNING
VM NICS
 0 net_172        no vbr0     172.16.1.201    02:00:ac:10:00:c9
                              fe80::400:acff:fe10:c9
 1 net_172        no vbr0     172.16.1.202    02:00:ac:10:00:ca
                              fe80::400:acff:fe10:ca
It is possible to attach (and live-attach) PCI and SR-IOV interfaces. Simply select the device by its address, id, vendor, or class.
$ onevm nic-attach 2 --network net_172 onevm nic-attach 2 --network net_172 --pci '00:06.1'
Important, predictable PCI addresses for guests will be only generated if PCI bus 1 is present in the Virtual Machine as PCI bridges cannot be hot-plugged.
You can also detach a NIC by its ID. If you want to detach interface 1 (MAC 02:00:ac:10:00:ca), execute:
$ onevm nic-detach 2 1
NIC Update
Qos attributes can be updated by the command onevm nic-update. If the Virtual Machine is running, the action triggers the driver action to live-update the network parameters.
$ cat update_nic.txt
NIC = [
    INBOUND_AVG_BW = "512",
    INBOUND_PEAK_BW = "1024"
$ onevm nic-update 0 0 update_nic.txt
Security Group Hot-plugging
You can live attach or detach security groups to VMs. Simply specify the VM, network interface, and security group to attach, for example:
$ onevm sg-attach centos-server 0 101
Similarly to detach a security group execute:.
$ onevm sg-detach centos-server 0 101
On Sunstone, you can attach and detach security groups to an NIC on a running or powered off VM by going to the Network tab.
sunstone_sg_main_view
To attach a new security group, you need to click on the shield on the NIC row. A dialog will be displayed where you can find all the security groups that do not belong to the selected network.
sunstone_sg_attach
To detach the security group, you must click on the Trash button next to the security group. A confirm dialog will be displayed to ensure that you want to detach the security group.
PCI Devices
You can attach or detach a PCI to/from a Virtual Machine in the POWEROFF and UNDEPLOYED state. For example:
$ onevm pci-attach alpine01 --pci_class 0c03 --pci_device 0015 --pci_vendor 1912
$ onevm pci-detach alpine01 0
Virtual Machine System Snapshots
$ onevm snapshot-create 4 "just in case"
$ onevm show 4
SNAPSHOTS
  ID         TIME NAME                                           HYPERVISOR_ID
   0  02/21 16:05 just in case                                   onesnap-0
$ onevm snapshot-revert 4 0 --verbose
VM 4: snapshot reverted
Virtual Machine Disk Snapshots
There are two kinds of operations related to disk snapshots:
  • disk-snapshot-create, disk-snapshot-revert, disk-snapshot-delete, disk-snapshot-rename: Allows the user to take snapshots of the disk states and return to them during the VM life-cycle. It is also possible to rename or delete snapshots.
  • disk-saveas: Exports VM disk (or a previously created snapshot) to an Image in an OpenNebula Datastore. This is a live action.
Managing Disk Snapshots
A user can take snapshots of VM disks to create a checkpoint of the state of a specific disk at any time. Depending on the storage backend, these snapshots can be organized:
  • In a tree-like structure, meaning that every snapshot has a parent, except for the first snapshot whose parent is -1. The active snapshot, the one the user has last reverted to or taken, will act as the parent of the next snapshot. It’s possible to delete snapshots that are not active and that have no children.
  • Flat structure, without parent/child relationship. In that case, snapshots can be freely removed.
Disk snapshots are managed with the following commands:
  • disk-snapshot-create <vmid> <diskid> <name>: Creates a new snapshot of the specified disk.
  • disk-snapshot-revert <vmid> <diskid> <snapshot_id>: Reverts to the specified snapshot. The snapshots are immutable, therefore users can revert to the same snapshot as many times as they want; the disk will always return to the state of the snapshot at the time it was taken.
  • disk-snapshot-delete <vmid> <diskid> <snapshot_id>: Deletes a snapshot if it has no children and is not active.
disk-snapshot-create can take place when the VM is in RUNNING state, provided that the drivers support it, while disk-snapshot-revert requires the VM to be in POWEROFF or SUSPENDED. Live snapshots are only supported for some hypervisors and storage drivers:
  • Hypervisor VM_MAD=kvm combined with TM_MAD=qcow2 datastores. In this case OpenNebula will request that the hypervisor executes virsh snapshot-create.
  • Hypervisor VM_MAD=kvm with Ceph datastores (TM_MAD=ceph). In this case OpenNebula will initially create the snapshots as Ceph snapshots in the current volume.
With these combinations (CEPH and qcow2 datastores, and KVM hypervisor) you can enable QEMU Guest Agent. With this agent enabled the filesystem will be frozen while the snapshot is being taken.
See the Storage Driver guide for a reference on the driver actions invoked to perform live and non-live snapshots.
Persistent Images and Disk Snapshots
These actions are available for both persistent and non-persistent Images. In the case of persistent Images the snapshots will be preserved upon VM termination and will be able to be used by other VMs using that Image. See the snapshots section in the Images guide for more information.
Saving a VM Disk to an Image (disk-saveas)
Any VM disk can be saved to a new Image (if the VM is in RUNNING, POWEROFF, SUSPENDED, UNDEPLOYED, or STOPPED states). This is a live operation that happens immediately. This operation accepts --snapshot <snapshot_id> as an optional argument, which specifies a disk snapshot to use as base of the new Image, instead of the current disk state (value by default).
Resizing VM Resources
You may resize the capacity assigned to a Virtual Machine in terms of the virtual CPUs, memory, and CPU allocated. VM resizing can be done in any of the following states: POWEROFF, UNDEPLOYED and, with some limitations, also live in RUNNING state.
If you have created a Virtual Machine and you need more resources, the following procedure is recommended:
  • Perform any operation needed to prepare your Virtual Machine for shutting down, e.g., you may want to manually stop some services
  • Power off the Virtual Machine
  • Resize the VM
  • Resume the Virtual Machine using the new capacity
Note that using this procedure the VM will preserve any resource assigned by OpenNebula, such as IP leases.
The following is an example of the previous procedure from the command line:
$ onevm poweroff web_vm
$ onevm resize web_vm --memory 2G --vcpu 2
$ onevm resume web_vm
Live Resize of Capacity
If you need to resize the capacity in the RUNNING state you have to set up some extra attributes in the VM template. These attributes must be set before the VM is started. These attributes are driver-specific, more info for KVM.
Resizing VM Disks
If the disks assigned to a Virtual Machine need more size, this can achieved at instantiation time of the VM. The SIZE parameter of the disk can be adjusted and, if it is bigger than the original size of the Image, OpenNebula will:
  • Increase the size of the disk container prior to launching the VM
  • Using the contextualization packages, at boot time the VM will grow the filesystem to adjust to the new size.
You can override the size of a DISK in a VM template at instantiation:
$ onetemplate instantiate <template> --disk u2104:size=20000 # Image u2104 will be resized to 2 GB
You can also resize VM disks for both RUNNING and POWEROFF VMs:
$ onevm disk-resize <vm_id> <disk_id> <new_size> # <new_size> must be greater than current disk size
This will make the VM disk grow on the hypervisor node. Then the contextualization service running inside the guest OS will expand the filesystem with the newly available free space. The support for this filesystem expansion depends on the Guest OS.
Updating the Virtual Machine Configuration
Some of the VM configuration attributes defined in the VM template can be updated after the VM is created. The onevm updateconf command will allow you to change the following attributes:
AttributeSub-attributes
OSARCH, MACHINE, KERNEL, INITRD, BOOTLOADER, BOOT,
KERNEL_CMD, ROOT, SD_DISK_BUS, UUID, FIRMWARE, FIRMWARE_FORMAT
FEATURESACPI, PAE, APIC, LOCALTIME, HYPERV, GUEST_AGENT,
VIRTIO_SCSI_QUEUES, VIRTIO_BLK_QUEUES, IOTHREADS
INPUTTYPE, BUS
GRAPHICSTYPE, LISTEN, PASSWD, KEYMAP, COMMAND
VIDEOTYPE, IOMMU, ATS, VRAM, RESOLUTION
RAWDATA, DATA_VMX, TYPE, VALIDATE
CPU_MODELMODEL, FEATURES
BACKUP_CONFIGFS_FREEZE, KEEP_LAST, BACKUP_VOLATILE, MODE,
INCREMENT_MODE
CONTEXTAny value, except ETH*. Variable substitution will be made
Visit the Virtual Machine Template reference for a complete description of each attribute.
Cloning a Virtual Machine
A VM template or VM instance can be copied to a new VM template. This copy will preserve the changes made to the VM disks after the instance is terminated. The template is private and will only be listed to the owner user.
There are two ways to create a persistent private copy of a VM:
  • Instantiate a VM template with the to persistent option.
  • Save an existing VM instance with onevm save.
Instantiate to Persistent
When instantiating to persistent the template is cloned recursively (a private persistent clone of each disk Image is created), and that new template is instantiated.
To “instantiate to persistent” use the --persistent option:
$ onetemplate instantiate web_vm --persistent --name my_vm
VM ID: 31
$ onetemplate list
   7 oneadmin        oneadmin        web_vm                       05/12 14:53:11
   8 oneadmin        oneadmin        my_vm                        05/12 14:53:38
$ oneimage list
  ID USER       GROUP      NAME            DATASTORE     SIZE TYPE PER STAT RVMS
   7 oneadmin   oneadmin   web-img         default       200M OS   Yes used    1
   8 oneadmin   oneadmin   my_vm-disk-0    default       200M OS   Yes used    1
Equivalently, in Sunstone activate the “Persistent” switch next to the Create button.
Please bear in mind the following ontemplate instantiate --persistent limitation: volatile disks cannot be persistent. The contents of the disks will be lost when the VM is terminated. The cloned VM template will contain the definition for an empty volatile disk.
Save a VM Instance
Alternatively, a VM that was not created as persistent can be saved before it is destroyed. To do so, the user has to poweroff the VM first and then use the save operation.
This action clones the VM source template, replacing the disks with copies of the current disks (see the disk-snapshot action). If the VM instance was resized, the current capacity is also used. The new cloned Images can be made persistent with the --persistent option. NIC interfaces are also overwritten with the ones from the VM instance, to preserve any attach/detach action.
$ onevm save web_vm copy_of_web_vm --persistent
Template ID: 26
Please bear in mind the following onevm save limitations:
  • The VM’s source template will be used. If this template was updated since the VM was instantiated, the new contents will be used.
  • Volatile disks cannot be saved and the current contents will be lost. The cloned VM template will contain the definition for an empty volatile disk.
  • Disks and NICs will only contain the target Image/Network NAME and UNAME if defined. If your template requires extra configuration, you will need to update the new template.
Scheduled Actions for Virtual Machines
Scheduled actions lets you program operations over a VM to be performed in the future, e.g., Shutdown the VM after 5 hours. OpenNebula supports two types of schedule actions:
  • punctual, that can be also periodic.
  • relative actions.
One-Time Punctual Actions
Most of the onevm commands accept the --schedule option, allowing users to delay the actions until a given date and time.
Here is an usage example:
$ onevm suspend 0 --schedule "09/20"
VM 0: suspend scheduled at 2016-09-20 00:00:00 +0200
$ onevm resume 0 --schedule "09/23 14:15"
VM 0: resume scheduled at 2016-09-23 14:15:00 +0200
$ onevm show 0
SCHEDULED ACTIONS
ID    ACTION  ARGS   SCHEDULED REPEAT   END STATUS
 0   suspend     - 09/20 00:00              Next in 12.08 days
 1    resume     - 09/23 14:15              Next in 15.67 days
These actions can be deleted or edited using the onevm sched-delete and onevm sched-update command. The time attributes use Unix time internally.
$ onevm sched-update 0 0
ID="0"
PARENT_ID="0"
TYPE="VM"
ACTION="suspend"
TIME="1703164454"
REPEAT="-1"
END_TYPE="-1"
END_VALUE="-1"
DONE="-1"
Periodic Punctual Actions
To schedule periodic actions you can also use the option –schedule. However this command also needs more options to define the periodicity of the action:
  • --weekly: defines a weekly periodicity, so the action will be executed every week on the days that the user defines.
  • --monthly: defines a monthly periodicity, so the action will be executed every month, on the days that the user defines.
  • --yearly: defines a yearly periodicity, so the action will be executed every year, on the days that the user defines.
  • --hourly: defines an hourly periodicity, so the action will be executed each ‘x’ hours.
  • --end: defines when you want the relative action to finish.
The option --weekly, --monthly, and --yearly need the index of the days that the users wants to execute the action.
  • --weekly: days separated with commas between 0 (Sunday) and 6 (Saturday). [0,6]
  • --monthly: days separated with commas between 1 and 31. [1,31]
  • --yearly: days separated with commas between 0 and 365. [0,365]
The option --hourly needs a number with the number of hours. [0,168] (1 week)
The option --end can be a number or a date:
  • Number: defines the number of repetitions.
  • Date: defines the date that the user wants to finish the action.
Here is a usage example:
$ onevm suspend 0 --schedule "09/20" --weekly "1,5" --end 5
VM 0: suspend scheduled at 2018-09-20 00:00:00 +0200
$ onevm resume 0 --schedule "09/23 14:15" --weekly "2,6" --end 5
VM 0: resume scheduled at 2018-09-23 14:15:00 +0200
$ onevm snapshot-create 0 snap-01 --schedule "09/23" --hourly 5 --end "12/25"
VM 0: snapshot-create scheduled at 2018-09-23 14:15:00 +0200
$ onevm show 0
SCHEDULED ACTIONS
 0          suspend        -  09/20 00:00    Weekly 1,5  After 5 times  Next in 1.08 days
 1           resume        -  09/23 14:15    Weekly 2,6  After 5 times  Next in 4.67 days
 2  snapshot-create  snap-01  09/19 21:16  Each 5 hours    On 12/25/18  Next in 4.78 hours
$ onevm sched-update 0 2
ID="2"
PARENT_ID="0"
TYPE="VM"
ACTION="snapshot-create"
ARGS="snap-01"
TIME="1701998190"
REPEAT="3"
DAYS="5"
END_TYPE="2"
END_VALUE="1893452400"
DONE="1701980968"
Relative Actions
Scheduled actions can be also relative to the Start Time of the VM. That is, it can be set on a VM Template and apply to the number of seconds after the VM is instantiated.
For instance, a VM Template with the following SCHED_ACTION will spawn VMs that will automatically shut down after 1 hour of being instantiated:
$ onetemplate update 0
SCHED_ACTION=[
   ACTION="terminate",
   ID="0",
   TIME="+3600" ]
This functionality is present graphically in Sunstone in the VM template creation and update wizard, on the second step Advanced options, under Schedule Action tab.
The following table summarizes the actions that can be scheduled. Note that some of the above actions need some parameters to run (e.g., a disk ID or a snapshot name).
ActionArguments
terminate [--hard]
undeploy [--hard]
hold
release
stop
suspend
resume
reboot [--hard]
poweroff [--hard]
snapshot-createname
snapshot-revertsnap ID
snapshot-deletesnap ID
disk-snapshot-createdisk ID, name
disk-snapshot-revertdisk ID, snap ID
disk-snapshot-deletedisk ID, snap ID
backupdatastore ID, reset
You can pass arguments to the scheduled actions by using the parameter ARGS in the action definition. For example:
ID="2"
PARENT_ID="0"
TYPE="VM"
ACTION="disk-snapshot-create",
ARGS="0, disksnap_example",
DAYS="1,5",
END_TYPE="1",
END_VALUE="5",
ID="0",
REPEAT="0",
TIME="1537653600"
In this example, the first argument would be the disk and the second the snapshot name.
Virtual Machine States
The life-cycle of a Virtual Machine within OpenNebula includes the following stages:
Short stateStateMeaning
pendPendingBy default a VM starts in the pending state, waiting for a resource to run on. It will stay in this state until the scheduler decides to deploy it, or the user deploys it using the onevm deploy command.
holdHoldThe owner has held the VM and it will not be scheduled until it is released. It can be deployed manually, however.
clonCloningThe VM is waiting for one or more disk images to finish the initial copy to the repository (image state still in lock).
prolPrologThe system is transferring the VM files (disk images and the recovery file) to the Host in which the Virtual Machine will be running.
bootBootOpenNebula is waiting for the hypervisor to create the VM.
runnRunningThe VM is running (note that this stage includes the internal virtualized machine booting and shutting down phases). In this state, the virtualization driver will periodically monitor it.
migrMigrateThe VM is migrating from one resource to another. This can be a life migration or cold migration (the VM is saved, powered off or powered off hard and VM files are transferred to the new resource).
hotpHotplugA disk attach/detach, nic attach/detach, save as or resize operation is in process.
snapSnapshotA system snapshot is being taken.
saveSaveThe system is saving the VM files after a migration, stop, or suspend operation.
epilEpilogIn this phase the system cleans up the Host used to virtualize the VM, and additionally disk images to be saved are copied back to the system datastore.
shutShutdownOpenNebula has sent the VM the shutdown ACPI signal and is waiting for it to complete the shutdown process. If after a timeout period the VM does not disappear, OpenNebula will assume that the guest OS ignored the ACPI signal and the VM state will be changed to running instead of done.
stopStoppedThe VM is stopped. VM state has been saved and it has been transferred back along with the disk images to the system datastore.
suspSuspendedSame as stopped, but the files are left in the Host to later resume the VM there (i.e., there is no need to reschedule the VM).
poffPowerOffSame as suspended, but no checkpoint file is generated. Note that the files are left in the Host to later boot the VM there.
When the VM guest is shut down, OpenNebula will put the VM in this state.
undeUndeployedThe VM is shut down. The VM disks are transferred to the system datastore. The VM can be resumed later.
drszDisk ResizeThe VM disk resize is in progress.
backBackupThe VM backup is in progress.
restRestoreThe VM disks are restored from backup image.
failFailedThe VM failed.
unknUnknownThe VM couldn’t be reached, it is in an unknown state.
cleaCleanup-resubmitThe VM is waiting for the drivers to clean the Host after a onevm recover --recreate action.
doneDoneThe VM is done. VMs in this state won’t be shown with onevm list but are kept in the database for accounting purposes. You can still get their information with the onevm show command.
Virtual Machine Charters
This functionality automatically adds scheduling actions in VM templates. To enable the creation of Charters in Sunstone, you only need to add the following to the vm-tab.yaml file in the corresponding Sunstone view:
info-tabs:
  sched_actions:
    enabled: true
    actions:
      charter_create: true
sunstone_vm_charter
After enabling the creation of Charters, you have to define the schedule actions that have a Charter. To do that, you only need to modify the file sunstone-server.conf in the FireEdge configuration.
To explain this, we’ll use an example:
leases:
  terminate:
    edit: false
    execute_after_weeks: 3
  poweroff:
    edit: true
    execute_after_minutes: 5
The previous example will create two schedule actions:
  • The Virtual Machine will be terminated 3 weeks after it was instantiated and you cannot edit this action before creating it.
  • The Virtual Machine will be powered off after 5 minutes after it was instantiated and you can edit the action before creating it.
So, when the user clicks on the Charter button, the following info will appear:
sunstone_charter_info
The first action cannot be edited but in the second one, you can change the action and the time. Also, you can tune the definition of a Charter:
editIf the action could be edited or not. Allow values: true, false
execute_after_<period_type>
Execute the action after the time that is defined. <period_type> allow values: years, months, weeks, days, hours, minutes.
e.g., execute_after_years: 2 -> The action will be executed 2 years after the Virtual Machine was instantiated.
e.g., execute_after_months: 3 -> The action will be executed 3 months after the Virtual Machine was instantiated.
This functionality is also available in the CLI through the following commands:
  • onevm create-chart
  • onevm sched-update
  • onevm sched-delete
The Charters can be added into the onevm configuration file /etc/one/cli/onevm.yaml:
:charters:
  :suspend:
    :time: "+1209600"
    :warning:
        :time: "+1123200"
  :terminate:
    :time: "+1209600"
    :warning:
        :time: "+1123200"
The information about the Charters can be checked with the command onevm show, the * in front of the ID indicates that the warning time passed:
SCHEDULED ACTIONS
*0  suspend          -  01/01 03:00                               Next in 1.25 hours
 1  terminate        -  15/01 03:00                               Next in 14 days
User-defined Data
Custom attributes can be added to a VM to store metadata related to this specific VM instance. To add custom attributes simply use the onevm update command:
$ onevm show 0
VMID="0"
$ onevm update 0
ROOT_GENERATED_PASSWORD="1234"
$ onevm show 0
VMID="0"
USER TEMPLATE
Virtual Machine VM Permissions
OpenNebula comes with an advanced ACL rules permission mechanism intended for administrators, but each VM object has also implicit permissions that can be managed by the VM owner. To share a VM instance with other users or to allow them to list and show its information, use the onevm chmod command:
$ onevm show 0
OWNER          : um-
GROUP          : ---
OTHER          : ---
$ onevm chmod 0 640
$ onevm show 0
OWNER          : um-
GROUP          : u--
OTHER          : ---
Administrators can also change the VM’s group and owner with the chgrp and chown commands.
Advanced Operations for Administrators
There are some onevm commands operations meant for cloud administrators:
Scheduling:
  • resched: Sets the reschedule flag for the VM. The Scheduler will migrate (or live-migrate, depending on the Scheduler configuration) the VM in the next monitorization cycle to a Host that better matches the requirements and rank restrictions. Read more in the Scheduler documentation.
  • unresched: Clears the reschedule flag for the VM, canceling the rescheduling operation.
Deployment:
  • deploy: Starts an existing VM in a specific Host.
  • migrate --live: The Virtual Machine is transferred between Hosts with no noticeable downtime. The VM storage cannot be migrated to other system datastores.
  • migrate: The VM is stopped and resumed in the target Host. In an infrastructure with multiple system datastores, VM storage can also be migrated (by specifying the datastore ID).
Note: By default, the above operations do not check the target Host capacity. You can use the --enforce option to be sure that the Host capacity is not overcommitted.
Troubleshooting:
  • recover: If the VM is stuck in any other state (or the boot operation does not work), you can recover the VM with the following options. Read the Virtual Machine Failures guide for more information.
    • --success: simulates the success of the missing driver action
    • --failure: simulates the failure of the missing driver action
    • --retry: tries to perform the current driver action again. Optionally the --interactive can be combined if it’s a Transfer Manager problem
    • --delete: Deletes the VM, moving it to the DONE state immediately
    • --recreate: Deletes the VM and moves it to the PENDING state
  • migrate or resched: A VM in the UNKNOWN state can be booted in a different Host manually (migrate) or automatically by the scheduler (resched). This action must be performed only if the storage is shared, or manually transferred by the administrator. OpenNebula will not perform any action on the storage for this migration.
Accessing VM Console and Desktop
Sunstone provides several different methods to access your VM console and desktop: VNC, RDP, and SSH. If configured in the VM, these methods can be used to access the VM console through Sunstone. This section shows how these different technologies can be configured and what each requirement is.
FireEdge automatically installs dependencies for Guacamole connections which are necessary to use VNC, RDP, and SSH.
Configuring Your VM for VNC
VNC is a graphical console with wide support among many hypervisors and clients.
To enable the VNC console service you must have a GRAPHICS section in the VM template, as stated in the documentation. Make sure the attribute IP is set correctly (0.0.0.0 to allow connections from everywhere), otherwise no connections will be allowed from the outside.
For example, to configure this in the Virtual Machine template:
GRAPHICS=[
    LISTEN="0.0.0.0",
    TYPE="vnc"
Your browser must support websockets, and have them enabled.
To configure it via Sunstone, you need to update the VM template. In the second step, Advanced options, under the Input/Output tab, you can see the graphics section where you can add the IP, the port, a connection password, or define your keymap.
sunstone_guac_vnc
Configure VM for RDP
Short for Remote Desktop Protocol, it allows one computer to connect to another computer over a network in order to use it remotely.
To enable RDP connections to the VM, you must have one NIC with RDP attribute equal to YES in the template.
Via Sunstone, you need to enable an RDP connection on one of the VM template networks, after or before its instantiation.
sunstone_guac_nic_1 sunstone_guac_nic_2
To configure this in the Virtual Machine template in advanced mode:
NIC=[
    RDP = "YES"
Once the VM is instantiated, users will be able to connect via browser.
sunstone_guac_rdp
RDP connection permits users to choose the screen resolution from Sunstone interface.
sunstone_guac_rdp_interface
If the VM template has a PASSWORD and USERNAME set in the contextualization section, this will be reflected in the RDP connection. You can read about them in the Virtual Machine Definition File reference section.
Configure VM for SSH
Unlike VNC or RDP, SSH is a text protocol. SSH connections require a hostname or IP address to define the destination machine. As with the RDP connections, you need to enable the SSH connection on one of the VM template networks.
For example, to configure this in the Virtual Machine template in advanced mode:
NIC=[
    SSH = "YES"
SSH is standardized to use port 22 and this will be the proper value in most cases. You only need to specify the SSH port in the contextualization section as SSH_PORT if you are not using the standard port.
For example, to allow connection by username and password to a guest VM, first make sure you have SSH root access to the VM, check more info here.
After that you can access the VM and configure the SSH service:
oneadmin@frontend:~$ ssh root@<guest-vm>
# Allow authentication with password: PasswordAuthentication yes
root@<guest-VM>:~$ vi /etc/ssh/sshd_config
# Restart SSH service
root@<guest-VM>:~$ service sshd restart
# Add user: username/password
root@<guest-VM>:~$ adduser <username>
fireedge_sunstone_ssh_list fireedge_sunstone_ssh_console
The onevm command
The onevm command manages OpenNebula virtual machines. The general structure of the command is as follows:
onevmcommand[args] [options]
Commands
backup vmid
  • Creates a VM backup on the given datastore
  • States: RUNNING, POWEROFF
  • Valid options: datastore, end, hourly, monthly, reset, schedule, weekly, yearly
backup-cancel vmidCancels an active VM backup operation. States: RUNNING, POWEROFF
backupmode vmid modeUpdates the backup mode of a VM. It can be FULL|INCREMENT
chgrp range|vmid_list groupidChanges the VM group
chmod range|vmid_list octetChanges the VM permissions
chown range|vmid_list userid [groupid]Changes the VM owner and group
create [file]
  • Creates a new VM from the given description instead of using a previously defined template (see onetemplate create and onetemplate instantiate).
  • Valid options: arch, boot, context, cpu, disk, dry, files_ds, hold, init, memory, multiple, name, net_context, nic, raw, report_ready, spice, spice_keymap, spice_listen, spice_password, ssh, startscript, user_inputs, vcpu, video, video_ats, video_iommu, video_resolution, video_vram, vnc, vnc_keymap, vnc_listen, vnc_password
  • Examples:
    • Using a template description file: onevm create vm_description.tmpl
    • New VM named “arch vm” with a disk and a nic: onevm create --name "arch vm" --memory 128 --cpu 1 --disk arch \ --network private_lan
    • A vm with two disks: onevm create --name "test vm" --memory 128 --cpu 1 --disk arch,data
create-chart vmidAdds a charter to the VM; these are some consecutive scheduled actions. You can configure the actions in onevm.yaml
delete-chart vmid sched_idDeletes a charter from the VM. Deprecated, use sched-delete instead.
deploy range|vmid_list hostid [datastoreid]
  • Deploys the given VM in the specified Host. This command forces the deployment, in a standard installation the Scheduler is in charge of this decision.
  • A template can be passed as a file with or the content via STDIN. Bash symbols must be escaped on STDIN passing.
  • States: PENDING, HOLD, STOPPED, UNDEPLOYED
  • Valid options: enforce, file
disk-attach vmid
  • Attaches a disk to a running VM.
  • A template can be passed as a file with or the content via STDIN. Bash symbols must be escaped on STDIN passing. When using a template add only one DISK instance.
  • Valid options: cache, discard, file, image, prefix, target
disk-detach vmid diskidDetaches a disk from a running VM. States: RUNNING, POWEROFF
disk-resize vmid diskid size
  • Resizes a VM disk. The new size should be larger than the old one.
  • The valid units are: T (TiB), G (GiB), and M (MiB). By default it is MiB.
disk-saveas vmid diskid img_name
  • Saves the specified VM disk as a new Image. The Image is created immediately, and the contents of the VM disk will be saved to it.
  • States: ANY
  • Valid options: snapshot, type
disk-snapshot-create vmid diskid name
  • Takes a new snapshot of the given disk. This operation needs support from the Datastore drivers: QCOW2 or Ceph.
  • States: RUNNING, POWEROFF, SUSPENDED
  • Valid options: end, hourly, monthly, schedule, weekly, yearly
disk-snapshot-delete vmid diskid disk_snapshot_id
  • Deletes a disk snapshot.
disk-snapshot-list vmid diskidLists the snapshots of a disk.
disk-snapshot-rename vmid diskid disk_snapshot_id new_snapshot_nameRenames a disk snapshot.
disk-snapshot-revert vmid diskid disk_snapshot_id
  • Reverts disk state to a previously taken snapshot.
  • States: POWEROFF, SUSPENDED
hold range|vmid_list
  • Sets the given VM on hold. A VM on hold is not scheduled until it is released. It can be, however, deployed manually; see onevm deploy.
  • States: PENDING
list [filterflag]
  • Lists VMs in the pool. The default columns and their layout can be configured in onevm.yaml
  • Valid options: adjust, csv, csv_del, delay, describe, expand, extended, filter, json, kilobytes, list, listconf, no_expand, no_header, no_pager, numeric, operator, search, size, xml, yaml
lock range|vmid_list
  • Locks a VM to prevent certain actions defined by different levels. The show and monitoring action will never be locked.
  • States: All.
  • Valid options: all, admin, manage, use. [Admin]: locks only Admin actions. [Manage]: locks Manage and Use actions. [Use]: locks Admin, Manage and Use actions.
migrate range|vmid_list hostid [datastoreid]
  • Migrates the given running VM to another Host. If used with --live parameter the migration is done without downtime. Datastore migration is not supported for --live flag.
  • States: RUNNING
  • Valid options: enforce, live, poweroff, poweroff_hard
nic-attach vmid
  • Attaches a NIC to a VM.
  • To attach a nic alias: A template can be passed as a file with or the content via STDIN. Bash symbols must be escaped on STDIN passing. When using a template add only one NIC instance.
  • To hotplug a PCI device and use it as a NIC interface in the VM select it with --pci (short_address) or --pci_device (device ID), --pci_class (class ID) and/or --pci_vendor (vendor ID).
  • Valid options: alias, file, ip, network, nic_name, pci, pci_class, pci_device, pci_vendor
nic-detach vmid nicidDetaches a NIC from a running VM. States: RUNNING, POWEROFF
nic-update vmid nicid [file]
  • Updates a NIC for a VM. In case the VM is running, trigger NIC update on the host.
  • States: Almost all, except BOOT*, MIGRATE and HOTPLUG-NIC
  • Valid options: append
pci-attach vmid
  • Attaches a PCI to a VM. You can specify the PCI device with --pci (short_address) or --pci_device (device ID), --pci_class (class ID) and/or --pci_vendor (vendor ID).
  • States: POWEROFF
  • Valid options: file, pci, pci_class, pci_device, pci_vendor
pci-detach vmid pciidDetaches a PCI device from a VM. States: POWEROFF
port-forward vmid [port]Gets port forwarding from a NIC, e.g: 1.2.3.4@4000 -> 1, means that to connect to VM port 1, you need to connect to IP 1.2.3.4 in port 4000. Valid options: nic_id
poweroff range|vmid_list
  • Powers off the given VM. The VM will remain in the poweroff state, and can be powered on with the onevm resume command.
  • States: RUNNING
  • Valid options: end, hard, hourly, monthly, schedule, weekly, yearly
reboot range|vmid_list
  • Reboots the given VM, this is equivalent to execute the reboot command from the VM console. The VM will be ungracefully rebooted if --hard is used.
  • States: RUNNING
recover range|vmid_list
  • Recovers a stuck VM that is waiting for a driver operation. The recovery may be done by failing, succeeding or retrying the current operation. You need to manually check the VM status on the host, to decide if the operation was successful or not, or if it can be retried.
  • Example: A VM is stuck in migrate because of a hardware failure. You need to check if the VM is running in the new host or not to recover the vm with --success or --failure, respectively.
  • States for success/failure recovers: Any ACTIVE state.
  • States for a retry recover: Any FAILURE state
  • States for delete: Any
  • States for recreate: Any but DONE
  • States for delete-db: Any
  • Valid options: delete, deletedb, failure, interactive, recreate, retry, success
release range|vmid_list
  • Releases a VM on hold. See onevm hold
  • States: HOLD
rename vmid nameRenames the VM.
resched range|vmid_listSets the rescheduling flag for the VM. States: RUNNING, POWEROFF
resize vmid
  • Resizes the capacity of a Virtual Machine.
  • Valid options: cpu, enforce, file, memory, vcpu
restore vmid imageidRestores the Virtual Machine from the backup Image. The VM must be in poweroff state. Valid options: disk_id, increment
resume range|vmid_list
  • Resumes the execution of a saved VM
  • States: STOPPED, SUSPENDED, UNDEPLOYED, POWEROFF, UNKNOWN
save vmid name
  • Clones the VM’s source Template, replacing the disks with live snapshots of the current disks. The VM capacity and NICs are also preserved
  • States: POWEROFF
  • Valid options: persistent
sched-delete vmid sched_idDeletes a Scheduled Action from the VM.
sched-update vmid sched_id [file]Updates a Scheduled Action from a VM.
sg-attach vmid nicid sgidAttaches a Security Group to a VM. States: All, except BOOT, MIGRATE and HOTPLUG_NIC
sg-detach vmid nicid sgidDetaches a Security Group from a VM. States: All, except BOOT, MIGRATE and HOTPLUG_NIC
show vmidShows information for the given VM. Valid options: all, decrypt, json, xml, yaml
snapshot-create range|vmid_list [name]Creates a new VM snapshot. Valid options: end, hourly, monthly, schedule, weekly, yearly
snapshot-delete vmid snapshot_idDeletes a snapshot of a VM. Valid options: end, hourly, monthly, schedule, weekly, yearly
snapshot-list vmidLists the snapshots of a VM.
snapshot-revert vmid snapshot_idReverts a VM to a saved snapshot. Valid options: end, hourly, monthly, schedule, weekly, yearly
ssh vmid [login]
  • SSH into VM.
  • Options example:-o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null
  • Valid options: cmd, nic_id, ssh_opts
stop range|vmid_list
  • Stops a running VM. The VM state is saved and transferred back to the front-end along with the disk files
  • States: RUNNING
suspend range|vmid_list
  • Saves a running VM. Similar to onevm stop, but the files are left in the remote machine to later restart the VM there. The resources are not freed and there is no need to re-schedule the VM.
  • States: RUNNING
terminate range|vmid_list
  • Terminates the given VM. The VM life cycle will end. With --hard it unplugs the VM.
  • States: valid if no operation is being performed on the VM
top [filterflag]Lists Images continuously. Valid options: adjust, csv, csv_del, delay, expand, extended, filter, json, kilobytes, list, listconf, no_expand, no_header, no_pager, numeric, operator, size, xml, yaml
undeploy range|vmid_list
  • Shuts down the given VM. The VM is saved in the system Datastore. With –hard it unplugs the VM.
  • States: RUNNING
unlock range|vmid_listUnlocks a Virtual Machine. Valid states: All.
unresched range|vmid_listClears the rescheduling flag for the VM. States: RUNNING, POWEROFF
update vmid [file]Updates the user template contents. If a path is not provided the editor will be launched to modify the current content. Valid options: append
update-chart vmid sched_id [file]Updates a charter from a VM. Deprecated command: use sched-update instead.
updateconf vmid [file]
  • Updates the configuration of a VM.
  • This command accepts a template or opens an editor. A template can be passed as a file with or the content via STDIN. Bash symbols must be escaped on STDIN passing.
  • Valid states are: running, pending, failure, poweroff, undeploy, hold or cloning. In running state only changes in CONTEXT and BACKUP_CONFIG take effect immediately, other values may need a VM restart.
  • Configuration attributes include:
    • OS = [“ARCH”, “MACHINE”, “KERNEL”, “INITRD”, “BOOTLOADER”, “BOOT”, “KERNEL_CMD”, “ROOT”, “SD_DISK_BUS”, “UUID”, “FIRMWARE”, “FIRMWARE_FORMAT”]
    • FEATURES = [“ACPI”, “PAE”, “APIC”, “LOCALTIME”, “HYPERV”, “GUEST_AGENT”, “VIRTIO_SCSI_QUEUES”, “VIRTIO_BLK_QUEUES”, “IOTHREADS”]
    • INPUT = [“TYPE”, “BUS”]
    • GRAPHICS = [“TYPE”, “LISTEN”, “PASSWD”, “KEYMAP”, “COMMAND”]
    • VIDEO = [“TYPE”, “IOMMU”, “ATS”, “VRAM”, “RESOLUTION”]
    • RAW = [“DATA”, “DATA_VMX”, “TYPE”, “VALIDATE”]
    • CPU_MODEL = [“MODEL”, “FEATURES”]
    • BACKUP_CONFIG = [“FS_FREEZE”, “KEEP_LAST”, “BACKUP_VOLATILE”, “MODE”, “INCREMENT_MODE”]
    • CONTEXT (any value, ETH* if CONTEXT_ALLOW_ETH_UPDATES set in oned.conf, variable substitution will be made)
vnc vmidOpens a VNC session to the VM. Valid options include: vnc
Back to The onevm Command
Args
datastoreidOpenNebula DATASTORE name or id
disk_snapshot_idDisk_snapshot name or id
diskidDisk id
filePath to a file
filterflag <option>Option list:
  • a, all: all the known VMs
  • m, mine: the VM belonging to the user in ONE_AUTH
  • g, group: ‘mine’ plus the VM belonging to the groups the user is member of
  • G, primary group: The VM owned the user’s primary group
  • uid: VM of the user identified by this uid
  • user: VM of the user identified by the username
    groupidOpenNebula GROUP name or id
    hostidOpenNebula HOST name or id
    imageidOpenNebula IMAGE name or id
    nicidNIC name or id
    pciidPCI id
    rangeList of id’s in the form 1,8..15
    sched_idScheduled Action id
    sgidSecurity Group id
    sizeDisk size in MiB
    snapshot_idSnapshot name or id
    textString
    useridOpenNebula USER name or id
    vmidOpenNebula VM name or id
    vmid_listComma-separated list of OpenNebula VM names or ids
    Options
    --adjust x,y,zAdjusts size to not truncate selected columns
    --adminLocks admin actions
    -a, --alias aliasAttaches the NIC as an ALIAS
    --allShows all template data
    -a, --appendAppends new attributes to the current template
    --arch archLists details of the VM architecture. Example: i386 or x86_64
    --boot device_listSets boot device list e.g. disk0,disk2,nic0
    --cache cache_modeConfigures hypervisor cache mode: default, none, writethrough, writeback, directsync or unsafe, (Only KVM driver)
    --cmd cmdCMD to run when SSH
    --context line1,line2,line3Replaces the context section with the specified lines
    --cpu cpuShows CPU percentage reserved for the VM (1=100% one CPU)
    --csvWrites table in csv format
    --csv-del delSets delimiter for csv output
    -d, --datastore id|nameSelects the datastore
    --decryptGets decrypted attributes
    -d, --delay xSets the delay in seconds for top command
    --deleteDeletes the VM. Important: No recovery action possible.
    --delete-dbDeletes the VM from the DB. It does not trigger any action on the hypervisor. Important: No recovery action possible.
    --describeDescribes list of columns
    --discard discard_modeHypervisor discard mode: ignore or unmap. Only KVM driver.
    --disk image0,image1Disks to attach. To use an image owned by other user run user[disk]. Add any additional attributes separated by ‘:’ and in the shape of KEY=VALUE. For example, if the disk must be resized, use image0:size=1000. Alternatively, image0:size=1000:target=vda,image1:target=vdb
    --disk-id disk_idUses only selected disk ID
    --dryJust prints the template
    --end number|TIME—-
    --endpoint endpointURL of OpenNebula xmlrpc frontend
    -e, --enforceEnforces that the host capacity is not exceeded
    --expand [x=prop,y=prop]Expands column size to fill the terminal. For example: $onevm list --expand name=0.4,group=0.6 will expand name 40% and group 60%. $onevm list --expand name,group expands name and group based on its size. $onevm list --expand will expand all columns.
    --extendedShows info extended. It only works with xml output.
    --failureRecovers a VM by failing the pending action
    -f, --file fileSelects the template file
    --files_ds file1,file2Adds files to the contextualization CD from the files datastore
    -f, --filter x,y,zFilters data. An array is specified with column=value pairs. Valid operators =,!=,<,<=,>,>=,~. Examples: NAME=test matches name with test, and NAME~test matches every NAME containing the substring ’test’
    --hardDoes not communicate with the guest OS
    -h, --helpShows this message
    --holdCreates the new VM on hold state instead of pending
    --hourly hourRepeats the schedule action with the given hourly frequency. For example every 5 hours: onevm resume 0 --schedule "09/23 14:15" --hourly 5
    -i, --image id|nameSelects the image
    --increment increment_idUses the given increment ID to restore the backup. If not provided the last one will be used.
    --init script1,script2Script or scripts to start in context
    --interactiveEnables interactive recovery. Only works alongside the --retry option.
    -i, --ip ipIP address for the new NIC
    -j, --jsonShows the resource in JSON format
    -k, --kilobytesShows units in kilobytes
    -l, --list x,y,zSelects columns to display with list command
    -c, --listconf confSelects a predefined column list
    --livePerforms the action while the VM is running
    --manageLocks manage actions
    --memory memoryMemory amount given to the VM. By default the unit is megabytes. To use gigabytes add a g, floats can be used: 8g=8192, 0.5g=512
    --monthly daysRepeats the scheduled action the days of the month specified, it can be a number between 1,31 separated with commas. For example: onevm resume 0 --schedule "09/23 14:15" --monthly 1,14
    -m, --multiple xInstances multiple VMs
    --name nameName for the new VM
    --net_contextAdds network contextualization parameters
    -n, --network id|nameSelects the virtual network
    --nic network0,network1Networks to attach. To use a network owned by another user run user[network]. Additional attributes are supported like with the --disk option. Also you can use auto if you want OpenNebula to automatically select the network
    --nic-id nic_idNIC to use when SSH
    --nic_name nameName of the NIC
    --no-expandDisables expand
    --no-headerHides the header of the table
    --no-pagerDisables pagination
    -n, --numericDoes not translate user and group IDs
    --operator operatorLogical operator used on filters: AND, OR.Default: AND.
    --password passwordPassword to authenticate with OpenNebula
    --pci short_addressSelects PCI device by its short address
    --pci_class class IDSelects PCI device by its class ID
    --pci_device device IDSelects PCI device by its device ID
    --pci_vendor vendor IDSelects PCI device by its vendor ID
    --persistentMakes the new images persistent
    --poffDoes the migrate by poweringoff the vm
    --poff-hardDoes the migrate by poweringoff hard the vm
    --prefix prefixOverrides the DEV_PREFIX of the image
    --raw stringRaw string to add to the template. Not to be confused with the RAW attribute.
    --recreateDeletes and recreates the VM. No recovery action possible.
    --report_readySends READY=YES to OneGate, useful for OneFlow.
    --resetCreates a new backup image, from a new full backup (only for incremental)
    --retryRecovers a VM by retrying the last failed action.
    --schedule TIMESchedules this action to be executed after the given time. For example: onevm resume 0 --schedule "09/23 14:15"
    --search searchQueries in PATH=VALUE format. For example: onevmlist --search "VM.NAME=abc&VM.TEMPLATE.DISK[*].IMAGE=db1"
    -s, --size x=size,y=sizeChanges the size of selected columns. For example: $ onevm list --size "name=20" will make column name size 20.
    -s, --snapshot snapshotID of the Snapshot to save.
    --spiceAdds spice server to the VM.
    --spice-keymap keymapSpice server keyboard layout
    --spice-listen ipSpice server IP where to listen for connections. By default, it is 0.0.0.0 (all interfaces).
    --spice-password passwordSpice server password
    --ssh [file]Adds an ssh public key to the context. If the file is omitted then the user variable SSH_PUBLIC_KEY will be used.
    --ssh-options optionsSSH options to use
    --startscript [file]Starts script to be executed
    --successRecovers a VM by succeeding the pending action
    -t, --target targetDevice where the image will be attached
    -t, --type typeLists type of the new Image
    --useLocks use actions
    --user nameUser name to connect to OpenNebula
    --user-inputs ui1,ui2,ui3Specifies the user inputs values when instantiating
    --vcpu vcpuNumber of virtualized CPUs
    -v, --verboseVerbose mode
    -V, --versionShows version and copyright information
    --video typeAdds a custom video device (none, vga, cirrus, virtio)
    --video-atsEnables ATS (Address Translation Services) for the video device.
    --video-iommuEnables IOMMU (I/O Memory Management Unit) for the video device.
    --video-resolution resolutionVideo resolution, in format like: 1280x720 or 1920x1080
    --video-vram vramVRAM allocated to the video device. By default the unit is megabytes. To use gigabytes add a g, floats can be used: 8g=8192, 0.5g=512
    --vncAdds VNC server to the VM
    --vnc-keymap keymapVNC keyboard layout
    --vnc-listen ipVNC IP where to listen for connections. By default it is 0.0.0.0 (all interfaces).
    --vnc-password passwordVNC password
    --weekly daysRepeats the scheduled action on the specified days of the week. It can be a number between 0 (Sunday) to 6 (Saturday) separated with commas. For example: onevm resume 0 --schedule "09/23 14:15" --weekly 0,2,4
    -x, --xmlShows the resource in xml format
    -y, --yamlShows the resource in YAML format
    --yearly daysRepeats the scheduled action on the specififed days of the year. It can be a number between 0,365 separated with commas. For example: onevm resume 0 --schedule "09/23 14:15" --yearly 30,60
