Command Line Interface Configuration
There are necessary environment variables and command-line arguments for OpenNebula users to authenticate and communicate with the core services, ensuring proper function of the one* CLI tools. You will also find about the use of command-line parameters (–user, –password, –endpoint) as an alternative to environment variables and notes configuration for OneFlow and OneGate services.
Shell Environment
OpenNebula users should have the following environment variables set, you may want to place them in the .bashrc of the user’s Unix account for convenience:
- ONE_XMLRPC: URL where the OpenNebula Daemon is listening. If it is not set, CLI tools will use the default:
http://localhost:2633/RPC2. See thePORTattribute in the Daemon configuration file for more information. - ONE_XMLRPC_TIMEOUT: number of seconds to wait before a xmlrpc request times out.
- ONE_ZMQ: URL to subscribe to receive ZMQ messages. If it is not set, CLI tools will use the default:
tcp://localhost:2101. - ONE_AUTH: needs to point to a file containing a valid authentication key, it can be:
- A password file with just a single line stating
username:password. - A token file with just a single line with
username:token, where token is a valid token created with theoneuser logincommand or API call.
If ONE_AUTH is not defined, $HOME/.one/one_auth will be used instead. If no auth file is present, OpenNebula cannot work properly, as this is needed by the core, the CLI, and the cloud components as well.
- ONE_POOL_PAGE_SIZE: by default the OpenNebula Cloud API (CLI and Sunstone make use of it) paginates some pool responses. By default this size is 300 but it can be changed with this variable. A numeric value greater than 2 is the pool size. To disable it you can use a non-numeric value.
$ export ONE_POOL_PAGE_SIZE=5000 # Sets the page size to 5000
$ export ONE_POOL_PAGE_SIZE=disabled # Disables pool pagination
- ONE_PAGER: list commands will send their output through a pager process when in an interactive shell. By default, the pager process is set to
lessbut it can be change to any other program. The pagination can be disabled using the argument--no-pager. It sets theONE_PAGERvariable tocat. - ONE_LISTCONF: allows the user to use an alternate layout to displays lists.
$ onevm list
20 oneadmin oneadmin tty-20 fail 0 0K localhost 0d 00h32
21 oneadmin oneadmin tty-21 fail 0 0K localhost 0d 00h23
22 oneadmin oneadmin tty-22 runn 0.0 104.7M localhost 0d 00h22
$ export ONE_LISTCONF=user
$ onevm list
ID NAME IP STAT UCPU UMEM HOST TIME
20 tty-20 10.3.4.20 fail 0 0K localhost 0d 00h32
21 tty-21 10.3.4.21 fail 0 0K localhost 0d 00h23
22 tty-22 10.3.4.22 runn 0.0 104.7M localhost 0d 00h23
- ONE_CERT_DIR and ONE_DISABLE_SSL_VERIFY: if OpenNebula XML-RPC endpoint is behind an SSL proxy you can specify an extra trusted certificates directory using
ONE_CERT_DIR. Make sure that the certificate is named<hash>.0. You can get the hash of a certificate with this command:
$ openssl x509 -in <certificate.pem> -hash
Alternatively you can set the environment variable ONE_DISABLE_SSL_VERIFY to any value to disable certificate validation. You should only use this parameter for testing as it makes the connection insecure.
For instance, a user named regularuser may have the following environment:
$ tail ~/.bashrc
ONE_XMLRPC=http://localhost:2633/RPC2
export ONE_XMLRPC
$ cat ~/.one/one_auth
regularuser:password
Please note that the example above is intended for a user interacting with OpenNebula from the Front-end, but you can use it from any other computer. Just set the appropriate hostname and port in the ONE_XMLRPC variable.
If you do not want passwords to be stored in plain files, protected with basic filesystem permissions, please refer to the token-based authentication mechanism described below.An alternative method to specify credentials and OpenNebula endpoint is using command line parameters. Most of the commands can understand the following parameters:
--user name | User name used to connect to OpenNebula |
--password password | Password to authenticate with OpenNebula |
--endpoint endpoint | URL of OpenNebula XML-RPC Front-end |
If user is specified but not password the user will be prompted for the password. endpoint has the same meaning and gets the same value as ONE_XMLRPC. For example:
$ onevm list --user my_user --endpoint http://one.frontend.com:2633/RPC2
Password:
Warning
You shouldn’t use --password parameter in a shared machine. Process parameters can be seen by any user with the command ps so it is highly insecure.- ONE_SUNSTONE: URL of the Sunstone portal, used for downloading Marketplace Apps streamed through Sunstone. If this is not specified, it will be inferred from
ONE_XMLRPC(by changing the port to 9869), and if that ENV variable is undefined as well, it will default tohttp://localhost:9869. - ONEFLOW_URL, ONEFLOW_USER and ONEFLOW_PASSWORD: these variables are used by the OneFlow command line tools. If not set, the default OneFlow URL will be
http://localhost:2474. The user and password will be taken from theONE_AUTHfile if the environment variables are not found.
CLI views
You can customize how certain commands are displayed by default. Each command has a yaml file associated to it, located at /etc/one/cli/
root@supermicro9:~# tree /etc/one/cli/
/etc/one/cli/
├── oneacct.yaml
├── oneacl.yaml
├── onecluster.yaml
├── onedatastore.yaml
├── oneflowtemplate.yaml
├── oneflow.yaml
├── onegroup.yaml
├── onehook.yaml
├── onehost.yaml
├── oneimage.yaml
├── onemarketapp.yaml
├── onemarket.yaml
├── oneprovider.yaml
├── onesecgroup.yaml
├── oneshowback.yaml
├── onetemplate.yaml
├── oneuser.yaml
├── onevdc.yaml
├── onevmgroup.yaml
├── onevm.yaml
├── onevnet.yaml
├── onevntemplate.yaml
├── onevrouter.yaml
└── onezone.yaml
For example, in the case of onevm list, by default it looks like this:
root@supermicro9:~# onevm list
ID USER GROUP NAME STAT CPU MEM HOST TIME
9234 oneadmin oneadmin alma8-alma8-6-7-80-e3f1f4b2-6a26f4bd-1825.build unde 0.5 8G 0d 05h57
9233 nhansen users alma8-kvm-local-6-6-pkofu-2.test runn 0.5 1.3G localhost 0d 07h04
9232 nhansen users alma8-kvm-local-6-6-pkofu-1.test runn 0.5 1.3G localhost 0d 07h04
9231 nhansen users alma8-kvm-local-6-6-pkofu-0.test runn 0.5 1.8G localhost 0d 07h04
But you can change the default columns, increase the column width and disable expansion to make it look like this:
~ onevm list
ID NAME STAT IP
9188 minione-9188 runn 172.20.0.65
9184 ubuntu2204-func-6-7-1lbob-0.test unde 172.20.0.61,192.168.150.1
9183 ubuntu2204-func-6-7-xjz0p-0.test unde 172.20.0.59,192.168.150.1
9182 ubuntu2204-func-6-7-q1okq-0.test unde 172.20.0.55,192.168.150.1
8705 bots poff 172.20.0.20
6460 tmux poff 172.20.0.5
5947 market-builder-5947 poff 172.20.0.26
Shell Environment for Self-Contained Installations
If OpenNebula was installed from sources in self-contained mode (this is not the default, and not recommended), these two variables must be also set. These are not needed if you installed from packages, or performed a system-wide installation from sources.
- ONE_LOCATION: it must point to the installation
<destination_folder>. - PATH: the OpenNebula bin files must be added to the path:
$ export PATH=$ONE_LOCATION/bin:$PATH
