OneGate API
OneGate provides a REST API. To use this API you will need to get some data from the CONTEXT file. The contextualization cdrom should contain the context.sh and token.txt files.
# mkdir /mnt/context
# mount /dev/hdb /mnt/context
# cd /mnt/context
# ls
context.sh token.txt
# cat context.sh
# Context variables generated by OpenNebula
DISK_ID='1'
ONEGATE_ENDPOINT='http://192.168.0.1:5030'
VMID='0'
TARGET='hdb'
TOKEN='yes'
# cat token.txt
yCxieDUS7kra7Vn9ILA0+g==
With that data, you can obtain the headers required for all the ONEGATE API methods:
- Headers:
X-ONEGATE-TOKEN: token.txt contentsX-ONEGATE-VMID: <vmid>
OneGate supports these actions:
Self-awareness
GET ${ONEGATE_ENDPOINT}/vm: to request information about the current Virtual Machine.GET ${ONEGATE_ENDPOINT}/vms/${VM_ID}: to request information about a specific Virtual Machine of the Service. The information is returned in JSON format and is ready for public cloud usage.
$ curl -X "GET" "${ONEGATE_ENDPOINT}/vm" \
--header "X-ONEGATE-TOKEN: `cat token.txt`" \
--header "X-ONEGATE-VMID: $VMID"
"VM": {
"ID": ...,
"NAME": ...,
"TEMPLATE": {
"NIC": [
"IP": ...,
"IP6_LINK": ...,
"MAC": ...,
"NETWORK": ...,
// more nics ...
"USER_TEMPLATE": {
"ROLE_NAME": ...,
"SERVICE_ID": ...,
// more user template attributes
PUT ${ONEGATE_ENDPOINT}/vm: to add information to the template of the current VM. The new information is placed inside the VM’s user template section. This means that the application metrics are visible from the command line, Sunstone, or the APIs, and can be used to trigger OneFlow elasticity rules.PUT ${ONEGATE_ENDPOINT}/vms/${VM_ID}: to add information to the template of a specific VM of the Service.
$ curl -X "PUT" "${ONEGATE_ENDPOINT}/vm" \
--header "X-ONEGATE-VMID: $VMID" \
-d "APP_LOAD = 9.7"
The new metric is stored in the user template section of the VM:
$ onevm show 0
USER TEMPLATE
APP_LOAD="9.7"
PUT ${ONEGATE_ENDPOINT}/vm?type=2: to delete information from the template of the current VM.PUT ${ONEGATE_ENDPOINT}/vms/${VM_ID}?type=2: to delete information from the template of a specific VM of the Service.
$ curl -X "PUT" "${ONEGATE_ENDPOINT}/vm?type=2" \
-d "APP_LOAD"
$ onevm show 0
USER TEMPLATE
GET ${ONEGATE_ENDPOINT}/service: to request information about the Service. The information is returned in JSON format and is ready for public cloud usage. By pushing dataPUT /vmfrom one VM and pulling the Service data from another VMGET /service, nodes that are part of a OneFlow Service can pass values from one to another.
$ curl -X "GET" "${ONEGATE_ENDPOINT}/service" \
"SERVICE": {
"id": ...,
"name": ...,
"roles": [
"name": ...,
"cardinality": ...,
"state": ...,
"nodes": [
"deploy_id": ...,
"running": true|false,
"vm_info": {
// VM template as return by GET /VM
// more nodes ...
// more roles ...
GET ${ONEGATE_ENDPOINT}: returns information endpoints:
"vm_info": "http://<onegate_endpoint>/vm",
"service_info": "http://<onegate_endpoint>/service"
GET ${ONEGATE_ENDPOINT}/vrouter: to request information about the Virtual Router. The information is returned in JSON format and is ready for public cloud usage.
$ curl -X "GET" "${ONEGATE_ENDPOINT}/vrouter" \
"VROUTER": {
"NAME": "vr",
"ID": "0",
"VMS": {
"ID": [
"1"
"TEMPLATE": {
"NIC": [
"NETWORK": "vnet",
"NETWORK_ID": "0",
"NIC_ID": "0"
"TEMPLATE_ID": "0"
GET ${ONEGATE_ENDPOINT}/vnet: to request information about a Virtual Network. The information is returned in JSON format and is ready for public cloud usage.
$ curl -X "GET" "${ONEGATE_ENDPOINT}/vnet/<VNET_ID>" \
"VNET": {
"ID": "0",
"NAME": "vnet",
"USED_LEASES": "1",
"VROUTERS": {
"ID": [
"0"
"PARENT_NETWORK_ID": {
"AR_POOL": {
"AR": [
"AR_ID": "0",
"IP": "192.168.122.100",
"MAC": "02:00:c0:a8:7a:64",
"SIZE": "10",
"TYPE": "IP4",
"MAC_END": "02:00:c0:a8:7a:6d",
"IP_END": "192.168.122.109",
"USED_LEASES": "1",
"LEASES": {
"LEASE": [
"VM": "1"
"TEMPLATE": {
"NETWORK_ADDRESS": "192.168.122.0",
"NETWORK_MASK": "255.255.255.0",
"GATEWAY": "192.168.122.1",
"DNS": "1.1.1.1"
Self-configuration
POST ${ONEGATE_ENDPOINT}/service/${SERVICE_ID}/scale: to change the cardinality of a specific role of the Service.
$ curl -X "PUT" "${ONEGATE_ENDPOINT}/service/0/scale" \
-d "{'role_name': 'worker', 'cardinality' : 10, 'force': false}"
POST ${ONEGATE_ENDPOINT}/vms/${VM_ID}/action: to perform an action on a specific VM of the Service. Supported actions (resume, stop, suspend, terminate, reboot, poweroff, resched, unresched, hold, release)
$ curl -X "POST" "${ONEGATE_ENDPOINT}/vms/18/action" \
-d "{'action' : {'perform': 'resched'}}"
Sample Application Monitoring Script
#!/bin/bash
# Copyright 2002-2022, OpenNebula Project, OpenNebula Systems #
# Licensed under the Apache License, Version 2.0 (the "License"); you may #
# not use this file except in compliance with the License. You may obtain #
# a copy of the License at #
# http://www.apache.org/licenses/LICENSE-2.0 #
# Unless required by applicable law or agreed to in writing, software #
# distributed under the License is distributed on an "AS IS" BASIS, #
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. #
# See the License for the specific language governing permissions and #
# limitations under the License. #
# Initialization
ERROR=0
if [ -z $ONEGATE_TOKEN ]; then
echo "ONEGATE_TOKEN env variable must point to the token.txt file"
ERROR=1
fi
if [ -z $ONEGATE_ENDPOINT ]; then
echo "ONEGATE_ENDPOINT env variable must be set"
ERROR=1
fi
if [ $ERROR = 1 ]; then
exit -1
fi
TMP_DIR=`mktemp -d`
echo "" > $TMP_DIR/metrics
# Memory metrics
MEM_TOTAL=`grep MemTotal: /proc/meminfo | awk '{print $2}'`
MEM_FREE=`grep MemFree: /proc/meminfo | awk '{print $2}'`
MEM_USED=$(($MEM_TOTAL-$MEM_FREE))
MEM_USED_PERC="0"
if ! [ -z $MEM_TOTAL ] && [ $MEM_TOTAL -gt 0 ]; then
MEM_USED_PERC=`echo "$MEM_USED $MEM_TOTAL" | \
awk '{ printf "%.2f", 100 * $1 / $2 }'`
fi
SWAP_TOTAL=`grep SwapTotal: /proc/meminfo | awk '{print $2}'`
SWAP_FREE=`grep SwapFree: /proc/meminfo | awk '{print $2}'`
SWAP_USED=$(($SWAP_TOTAL - $SWAP_FREE))
SWAP_USED_PERC="0"
if ! [ -z $SWAP_TOTAL ] && [ $SWAP_TOTAL -gt 0 ]; then
SWAP_USED_PERC=`echo "$SWAP_USED $SWAP_TOTAL" | \
fi
#echo "MEM_TOTAL = $MEM_TOTAL" >> $TMP_DIR/metrics
#echo "MEM_FREE = $MEM_FREE" >> $TMP_DIR/metrics
#echo "MEM_USED = $MEM_USED" >> $TMP_DIR/metrics
echo "MEM_USED_PERC = $MEM_USED_PERC" >> $TMP_DIR/metrics
#echo "SWAP_TOTAL = $SWAP_TOTAL" >> $TMP_DIR/metrics
#echo "SWAP_FREE = $SWAP_FREE" >> $TMP_DIR/metrics
#echo "SWAP_USED = $SWAP_USED" >> $TMP_DIR/metrics
echo "SWAP_USED_PERC = $SWAP_USED_PERC" >> $TMP_DIR/metrics
# Disk metrics
/bin/df -k -P | grep '^/dev' > $TMP_DIR/df
cat $TMP_DIR/df | while read line; do
NAME=`echo $line | awk '{print $1}' | awk -F '/' '{print $NF}'`
DISK_TOTAL=`echo $line | awk '{print $2}'`
DISK_USED=`echo $line | awk '{print $3}'`
DISK_FREE=`echo $line | awk '{print $4}'`
DISK_USED_PERC="0"
if ! [ -z $DISK_TOTAL ] && [ $DISK_TOTAL -gt 0 ]; then
DISK_USED_PERC=`echo "$DISK_USED $DISK_TOTAL" | \
fi
#echo "DISK_TOTAL_$NAME = $DISK_TOTAL" >> $TMP_DIR/metrics
#echo "DISK_FREE_$NAME = $DISK_FREE" >> $TMP_DIR/metrics
#echo "DISK_USED_$NAME = $DISK_USED" >> $TMP_DIR/metrics
echo "DISK_USED_PERC_$NAME = $DISK_USED_PERC" >> $TMP_DIR/metrics
done
# PUT command
VMID=$(source /mnt/context.sh; echo $VMID)
curl -X "PUT" $ONEGATE_ENDPOINT/vm \
--header "X-ONEGATE-TOKEN: `cat $ONEGATE_TOKEN`" \
--data-binary @$TMP_DIR/metrics
