OneFlow Server API
The OpenNebula OneFlow API is a RESTful service to create, control, and monitor services composed of interconnected Virtual Machines with deployment dependencies between them. Each group of Virtual Machines is deployed and managed as a single entity, and is completely integrated with the advanced OpenNebula user and group management. There are two kind of resources: services templates and services. All data is sent and received as JSON.
This guide is intended for developers. The OpenNebula distribution includes a cli to interact with OneFlow and it is also fully integrated in the Sunstone GUI.
Authentication & Authorization
User authentication will be HTTP Basic access authentication. The credentials passed should be the username and password.
$ curl -u "username:password" https://oneflow.server
Return Codes
The OneFlow API uses the following subset of HTTP Status codes:
- 200 OK : the request has succeeded.
- 201 Created : request was successful and a new resource has been created.
- 202 Accepted : the request has been accepted for processing but the processing has not been completed.
- 204 No Content : the request has been accepted for processing but no info in the response.
- 400 Bad Request : malformed syntax.
- 401 Unauthorized : bad authentication.
- 403 Forbidden : bad authorization.
- 404 Not Found : resource not found.
- 500 Internal Server Error : the server encountered an unexpected condition which prevented it from fulfilling the request.
- 501 Not Implemented : the functionality requested is not supported.
> POST /service_template HTTP/1.1
> User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 NSS/3.14.0.0 zlib/1.2.3 libidn/1.18 libssh2/1.4.2
> Host: onflow.server:2474
< HTTP/1.1 400 Bad Request
< Content-Type: text/html;charset=utf-8
< Content-Type:application/json;charset=utf-8
< Content-Length: 40
"error": {
"message": "Role 'worker' 'cardinality' must be greater than or equal to 'min_vms'"
The methods specified below are described without taking into account 4xx (this can be inferred from the authorization information in the section above) and 5xx errors (which are method independent). HTTP verbs not defined for a particular entity will return a 501 Not Implemented.
Methods
Service
| Method | URL | Meaning / Entity Body | Response |
| GET | /service | List the contents of the SERVICE collection. | 200 OK: A JSON representation of the collection in the HTTP body. |
| GET | /service/<id> | Show the SERVICE resource identified by <id>. | 200 OK: A JSON representation of the collection in the HTTP body. |
| DELETE | /service/<id> | Delete the SERVICE resource identified by <id>. | 204: |
| POST | /service/<id>/action | Perform an action on the SERVICE resource identified by <id>. Available actions: shutdown, recover, chown, chgrp, chmod, release. It can also be used to perform an action in all the Virtual Machines. Available actions: shutdown, shutdown-hard, undeploy, undeploy-hard, hold, release, stop, suspend, resume, boot, delete, delete-recreate, reboot, reboot-hard, poweroff, poweroff-hard, snapshot-create, snapshot-revert, snapshot-delete, disk-snapshot-create, disk-snapshot-revert, disk-snapshot-delete. | 204: |
| PUT | /service/<id> | Update the SERVICE resource identified by <id>. | 204: |
| POST | /service/<id>/scale | Perform an scale operation on the SERVICE resource identified by <id>. | 204: |
| POST | /service/<id>/role/<name>/action | Perform an action on all the Virtual Machines belonging to the ROLE identified by SERVICE resource identified by <id>. Available actions: shutdown, shutdown-hard, undeploy, undeploy-hard, hold, release, stop, suspend, resume, boot, delete, delete-recreate, reboot, reboot-hard, poweroff, poweroff-hard, snapshot-create, snapshot-revert, snapshot-delete, disk-snapshot-create, disk-snapshot-revert, disk-snapshot-delete. | 204: |
| POST | /service/<id>/role_action | Add or remove a role from running service. | 204: |
Service Pool
| POST | /service_pool/purge_done | Remove SERVICES that are in DONE state. |
Service Template
| GET | /service_template | List the contents of the SERVICE_TEMPLATE collection. | 200 OK: A JSON representation of the collection in the HTTP body. |
| GET | /service_template/<id> | Show the SERVICE_TEMPLATE resource identified by <id>. | 200 OK: A JSON representation of the collection in the HTTP body. |
| DELETE | /service_template/<id> | Delete the SERVICE_TEMPLATE resource identified by <id>. | 204: |
| POST | /service_template | Create a new SERVICE_TEMPLATE resource. | 201 Created: A JSON representation of the new SERVICE_TEMPLATE resource in the HTTP body. |
| PUT | /service_template/<id> | Update the SERVICE_TEMPLATE resource identified by <id>. | 200 OK: A JSON representation of the collection in the HTTP body. |
| POST | /service_template/<id>/action | Perform an action on the SERVICE_TEMPLATE resource identified by <id>. Available actions: instantiate, chown, chgrp, chmod. | 201: |
Resource Representation
Service Schema
A Service is defined with JSON syntax templates.
| Attribute | Type | Mandatory | Description |
name | string | NO | Name of the service. |
deployment | string | NO | Deployment strategy: none: All Roles are deployed at the same time. straight: Each Role is deployed when all its parent Roles are running. Defaults to none. |
shutdown_action | string | NO | VM shutdown action: ‘shutdown’ or ‘shutdown-hard’. If it is not set, the default set in oneflow-server.conf will be used. |
ready_status_gate | boolean | NO | If ready_status_gate is set to true, a VM will only be considered to be in running state if the following points are true: VM is in running state for OpenNebula. This specifically means that LCM_STATE==3 and STATE>=3; The VM has READY=YES in the user template, this can be reported by the VM using OneGate. |
on_hold | boolean | NO | If on_hold is set to true, all VMs of the service will be created in HOLD state. |
user_inputs | hash | NO | Hash of custom attributes to use in the service. |
networks | hash | NO | Hash of Virtual Networks to use in the service. |
roles | array of Roles | YES | Array of Roles, see below. |
Each Role is defined as:
name | string | YES | Role name, only word characters (letter, number, underscore) are allowed. |
cardinality | integer | NO | Number of VMs to deploy. Defaults to 1. |
template_id | integer | YES | OpenNebula VM Template ID. See the OpenNebula documentation for VM Templates. |
type | string | YES | Defines the Role type, vm for VM Role and vr for VR Roles. |
parents | array of string | NO | Names of the Roles that must be deployed before this one. |
shutdown_action | string | NO | VM shutdown action: ‘shutdown’ or ‘shutdown-hard’. If it is not set, the one set for the Service will be used. |
on_hold | boolean | NO | If on_hold is set to true, all VMs of the Role (and their child Roles) will be created in HOLD state. If on_hold is already defined at the service level, it is not necessary to specify it at the Role level. |
min_vms | integer | NO (YES for elasticity) | Minimum number of VMs for elasticity adjustments. |
max_vms | integer | NO (YES for elasticity) | Maximum number of VMs for elasticity adjustments. |
cooldown | integer | NO | Cooldown period duration after a scale operation, in seconds. If it is not set, the default set in oneflow-server.conf will be used. |
elasticity_policies | array of Policies | NO | Array of Elasticity Policies, see below. |
scheduled_policies | array of Policies | NO | Array of Scheduled Policies, see below. |
To define a elasticity policy:
type | string | YES | Type of adjustment. Values: CHANGE, CARDINALITY, PERCENTAGE_CHANGE. |
adjust | integer | YES | Positive or negative adjustment. Its meaning depends on ‘type’. |
min_adjust_step | integer | NO | Optional parameter for PERCENTAGE_CHAGE adjustment type. If present, the policy will change the cardinality by at least the number of VMs set in this attribute. |
expression | string | YES | Expression to trigger the elasticity. |
period_number | integer | No | Number of periods that the expression must be true before the elasticity is triggered. |
period | integer | NO | Duration, in seconds, of each period in period_duration. |
cooldown | integer | NO | Cooldown period duration after a scale operation, in seconds. If it is not set, the one set for the Role will be used. |
And each scheduled policy is defined as:
recurrence | string | NO | Time for recurring adjustments. Time is specified with the Unix cron syntax. |
start_time | string | NO | Exact time for the adjustment. |
:type => :object,
:properties => {
'name' => {
:type => :string,
:required => true
'deployment' => {
:type => :string,
:default => 'none'
'description' => {
:type => :string,
:default => ''
'shutdown_action' => {
:type => :string,
:required => false
'roles' => {
:type => :array,
:items => [],
:required => true
'user_inputs' => {
:type => :object,
:properties => {},
:required => false
'user_inputs_values' => {
:type => :object,
:properties => {},
:required => false
'ready_status_gate' => {
:type => :boolean,
:required => false
'automatic_deletion' => {
:type => :boolean,
:required => false
'networks' => {
:type => :object,
:properties => {},
:required => false
'networks_values' => {
:type => :array,
:items => {
:type => :object,
:properties => {}
:required => false
'on_hold' => {
:type => :boolean,
:required => false
VM Role Schema
:type => :object,
:properties => {
'name' => {
:type => :string,
:required => true,
:regex => /^\w+$/
'type' => {
:type => :string,
:required => true
'cardinality' => {
:type => :integer,
:default => 0,
:minimum => 0
'template_id' => {
:type => :integer,
:required => true
'template_contents' => {
:type => :object,
:properties => {},
:required => false
'user_inputs' => {
:type => :object,
:properties => {},
:required => false
:type => :object,
:properties => {},
:required => false
'parents' => {
:type => :array,
:items => {
:type => :string
:type => :string,
:required => false
'min_vms' => {
:type => :integer,
:required => false,
:minimum => 0
'max_vms' => {
:type => :integer,
:required => false,
:minimum => 0
'cooldown' => {
:type => :integer,
:required => false,
:minimum => 0
'on_hold' => {
:type => :boolean,
:required => false
'elasticity_policies' => {
:type => :array,
:items => {
:type => :object,
:properties => {
'type' => {
:type => :string,
:required => true
'adjust' => {
:type => :integer,
:required => true
'min_adjust_step' => {
:type => :integer,
:required => false,
:minimum => 1
'period_number' => {
:type => :integer,
:required => false,
:minimum => 0
'period' => {
:type => :integer,
:required => false,
:minimum => 0
'expression' => {
:type => :string,
:required => true
'cooldown' => {
:type => :integer,
:required => false,
:minimum => 0
'scheduled_policies' => {
:type => :array,
:items => {
:type => :object,
:properties => {
'type' => {
:type => :string,
:required => true
'adjust' => {
:type => :integer,
:required => true
:type => :integer,
:required => false,
:minimum => 1
'start_time' => {
:type => :string,
:required => false
'recurrence' => {
:type => :string,
:required => false
VR Role Schema
:type => :object,
:properties => {
'name' => {
:type => :string,
:required => true,
:regex => /^\w+$/
'type' => {
:type => :string,
:required => true
'template_id' => {
:type => :integer,
:required => true
'cardinality' => {
:type => :integer,
:default => 0,
:minimum => 0
:type => :object,
:properties => {},
:required => false
'user_inputs' => {
:type => :object,
:properties => {},
:required => false
:type => :object,
:properties => {},
:required => false
'on_hold' => {
:type => :boolean,
:required => false
'parents' => {
:type => :array,
:items => {
:type => :string
Action Schema
:type => :object,
:properties => {
'action' => {
:type => :object,
:properties => {
'perform' => {
:type => :string,
:required => true
'params' => {
:type => :object,
:required => false,
:propierties => {
'merge_template' => {
:type => object,
:required => false
Examples
Create a New Service Template
curl http://127.0.0.1:2474/service_template -u 'oneadmin:password' -v --data '{
"name":"web-application",
"deployment":"straight",
"roles":[
"name":"frontend",
"cardinality":"1",
"template_id":"0",
"type": "vm",
"shutdown_action":"shutdown",
"min_vms":"1",
"max_vms":"4",
"cooldown":"30",
"elasticity_policies":[
"type":"PERCENTAGE_CHANGE",
"adjust":"20",
"min_adjust_step":"1",
"expression":"CUSTOM_ATT>40",
"period":"3",
"period_number":"30",
"cooldown":"30"
"scheduled_policies":[
"type":"CHANGE",
"adjust":"4",
"recurrence":"0 2 1-10 * * "
"name":"worker",
"cardinality":"2",
"template_id":"0",
"type": "vm",
"parents":[
"frontend"
"min_vms":"2",
"max_vms":"10",
"cooldown":"240",
"type":"CHANGE",
"adjust":"5",
"expression":"ATT=3",
"period":"5",
"period_number":"60",
"cooldown":"240"
> Authorization: Basic b25lYWRtaW46b23lbm5lYnVsYQ==
> Host: oneflow.server:2474
> Accept: */*
> Content-Length: 771
> Content-Type: application/x-www-form-urlencoded
< HTTP/1.1 201 Created
< X-XSS-Protection: 1; mode=block
< Content-Length: 1990
< X-Frame-Options: sameorigin
< Connection: keep-alive
< Server: thin 1.2.8 codename Black Keys
"DOCUMENT": {
"TEMPLATE": {
"BODY": {
"deployment": "straight",
"name": "web-application",
"roles": [
"scheduled_policies": [
"adjust": 4,
"type": "CHANGE",
"recurrence": "0 2 1-10 * * "
"template_id": 0,
"type": "vm",
"name": "frontend",
"min_vms": 1,
"max_vms": 4,
"cardinality": 1,
"cooldown": 30,
"shutdown_action": "shutdown",
"elasticity_policies": [
"expression": "CUSTOM_ATT>40",
"adjust": 20,
"min_adjust_step": 1,
"cooldown": 30,
"period": 3,
"period_number": 30,
"type": "PERCENTAGE_CHANGE"
"template_id": 0,
"type": "vm",
"name": "worker",
"min_vms": 2,
"max_vms": 10,
"cardinality": 2,
"parents": [
"frontend"
"cooldown": 240,
"expression": "ATT=3",
"adjust": 5,
"cooldown": 240,
"period": 5,
"period_number": 60,
"type": "CHANGE"
"TYPE": "101",
"GNAME": "oneadmin",
"NAME": "web-application",
"GID": "0",
"ID": "4",
"UNAME": "oneadmin",
"PERMISSIONS": {
"OWNER_A": "0",
"OWNER_M": "1",
"OWNER_U": "1",
"OTHER_A": "0",
"OTHER_M": "0",
"OTHER_U": "0",
"GROUP_A": "0",
"GROUP_M": "0",
"GROUP_U": "0"
"UID": "0"
Get Detailed Information of a Given Service Template
| GET | /service_template/<id> | Show the SERVICE_TEMPLATE resource identified by <id> | 200 OK: A JSON representation of the collection in the HTTP body. |
curl -u 'oneadmin:password' http://127.0.0.1:2474/service_template/4 -v
> GET /service_template/4 HTTP/1.1
> Authorization: Basic b25lYWRtaW46b3Blbm5lYnVsYQ==
> Host: 127.0.0.1:2474
> Accept: */*
< HTTP/1.1 200 OK
"DOCUMENT": {
"TEMPLATE": {
"BODY": {
"roles": [
"adjust": 4,
"type": "CHANGE",
"template_id": 0,
"type": "vm",
List the Available Service Templates
curl -u 'oneadmin:password' http://127.0.0.1:2474/service_template -v
> GET /service_template HTTP/1.1
> Accept: */*
< HTTP/1.1 200 OK
< Content-Length: 6929
"DOCUMENT_POOL": {
"DOCUMENT": [
"TEMPLATE": {
"BODY": {
"name": "web-server",
"roles": [
"adjust": 4,
"type": "CHANGE",
"template_id": 0,
"type": "vm",
"name": "frontend",
"min_vms": 1,
"max_vms": 4,
"cardinality": 1,
"cooldown": 30,
Update a Given Template
| PUT | /service_template/<id> | Update the SERVICE_TEMPLATE resource identified by <id>. | 200 OK: |
curl http://127.0.0.1:2474/service_template/4 -u 'oneadmin:password' -v -X PUT --data '{
"roles":[
"name":"frontend",
"cardinality":"1",
"template_id":"0",
"shutdown_action":"shutdown-hard",
"min_vms":"1",
"max_vms":"4",
"cooldown":"30",
"adjust":"20",
"period":"3",
"cooldown":"30"
"type":"CHANGE",
"adjust":"4",
"name":"worker",
"cardinality":"2",
"template_id":"0",
"type": "vm",
"parents":[
"frontend"
"min_vms":"2",
"max_vms":"10",
"cooldown":"240",
"type":"CHANGE",
"adjust":"5",
"period":"5",
"cooldown":"240"
> PUT /service_template/4 HTTP/1.1
> Accept: */*
> Content-Length: 1219
> Expect: 100-continue
* Done waiting for 100-continue
< HTTP/1.1 200 OK
< Content-Length: 1995
"DOCUMENT": {
"TEMPLATE": {
"BODY": {
"roles": [
"adjust": 4,
"type": "CHANGE",
"template_id": 0,
"type": "vm",
"name": "frontend",
"min_vms": 1,
"max_vms": 4,
"cardinality": 1,
"cooldown": 30,
"shutdown_action": "shutdown-hard",
Instantiate a Given Template
curl http://127.0.0.1:2474/service_template/4/action -u 'oneadmin:password' -v -X POST --data '{
"action": {
"perform":"instantiate"
> POST /service_template/4/action HTTP/1.1
> Accept: */*
> Content-Length: 49
< Content-Length: 2015
"DOCUMENT": {
"TEMPLATE": {
"BODY": {
"roles": [
"adjust": 4,
"type": "CHANGE",
"template_id": 0,
"type": "vm",
Additional parameters can be passed using the merge_template inside the params. For example, if we want to change the name when instantiating:
"action": {
"perform":"instantiate",
"params": {"merge_template":{"name":"new_name"}}
The following attributes can be also passed using the merge_template:
network_valuesuser_inputs_valuestemplate_contents
For example, to instantiate a service template with custom VM capacity:
"action": {
"params":{
"merge_template": {
"template_contents": {
"HOT_RESIZE": {
"CPU_HOT_ADD_ENABLED": "YES",
"MEMORY_HOT_ADD_ENABLED": "YES"
"MEMORY_RESIZE_MODE": "BALLOONING",
"VCPU_MAX": "2",
"MEMORY_MAX": "128"
Delete a Given Template
curl http://127.0.0.1:2474/service_template/4 -u 'oneadmin:password' -v -X DELETE
> DELETE /service_template/3 HTTP/1.1
> Accept: */*
< HTTP/1.1 204 No Content
< Content-Length: 0
curl http://127.0.0.1:2474/service/5 -u 'oneadmin:password' -v
> GET /service/5 HTTP/1.1
> Accept: */*
< HTTP/1.1 200 OK
< Content-Length: 11092
"DOCUMENT": {
"TEMPLATE": {
"BODY": {
"roles": [
"adjust": 4,
"last_eval": 1374676803,
"type": "CHANGE",
"template_id": 0,
"type": "vm",
"disposed_nodes": [
"name": "frontend",
"min_vms": 1,
"nodes": [
"deploy_id": 12,
"vm_info": {
"VM": {
"NAME": "frontend_0_(service_5)",
"GID": "0",
"ID": "12",
"UID": "0",
"last_vmname": 1,
"max_vms": 4,
"cardinality": 1,
"cooldown": 30,
"state": "2",
"true_evals": 0,
"adjust": 20,
"cooldown": 30,
"expression_evaluated": "CUSTOM_ATT[--] > 40",
"period": 3,
"template_id": 0,
"type": "vm",
"disposed_nodes": [
"name": "worker",
"min_vms": 2,
"nodes": [
"deploy_id": 13,
"vm_info": {
"VM": {
"NAME": "worker_0_(service_5)",
"GID": "0",
"ID": "13",
"UID": "0",
"deploy_id": 14,
"vm_info": {
"VM": {
"GID": "0",
"ID": "14",
"UID": "0",
"last_vmname": 2,
"max_vms": 10,
"cardinality": 2,
"parents": [
"frontend"
"cooldown": 240,
"state": "2",
"true_evals": 0,
"adjust": 5,
"cooldown": 240,
"expression_evaluated": "ATT[--] = 3",
"period": 5,
"type": "CHANGE"
"log": [
"message": "New state: DEPLOYING",
"severity": "I",
"timestamp": 1374676345
"message": "New state: RUNNING",
"severity": "I",
"timestamp": 1374676406
"state": 2
"TYPE": "100",
"GID": "0",
"ID": "5",
"PERMISSIONS": {
"OWNER_A": "0",
"OWNER_M": "1",
"OWNER_U": "1",
"OTHER_A": "0",
"OTHER_M": "0",
"OTHER_U": "0",
"GROUP_A": "0",
"GROUP_M": "0",
"GROUP_U": "0"
"UID": "0"
List the Available Services
curl http://127.0.0.1:2474/service -u 'oneadmin:password' -v
> GET /service HTTP/1.1
> Accept: */*
< HTTP/1.1 200 OK
< Content-Length: 12456
"DOCUMENT_POOL": {
"DOCUMENT": [
"TEMPLATE": {
"BODY": {
"roles": [
"adjust": 4,
"last_eval": 1374676986,
"type": "CHANGE",
Perform an Action on a Given Service
| POST | /service/<id>/action | Perform an action on the SERVICE resource identified by <id>. | 201: |
Available actions:
- recover: Recover a failed service by cleaning the failed VMs.
- From
FAILED_DEPLOYINGcontinues deploying the Service. - From
FAILED_SCALINGcontinues scaling the Service. - From
FAILED_UNDEPLOYINGcontinues shutting down the Service. - From
COOLDOWNthe Service is set to running, ignoring the cooldown duration. "delete" : trueinparamswill delete the service and its VMs no matter what state the service is in.
- From
- chown
- chmod
- chgrp
curl http://127.0.0.1:2474/service/5/action -u 'oneadmin:password' -v -X POST --data '{
"action": {
"perform":"chgrp",
"params" : {
"group_id" : 2
Perform an Action on All the VMs of a Given Role
| POST | /service/<id>/role/<name>/action | Perform an action on all the Virtual Machines belonging to the ROLE identified by <name> of the SERVICE resource identified by <id>. | 201: |
You can use this call to perform a VM action on all the Virtual Machines belonging to a Role. For example, if you want to suspend the Virtual Machines of the worker Role, these are the commands that can be performed:
shutdownshutdown-hardundeployundeploy-hardholdreleasestopsuspendresumebootdeletedelete-recreaterebootreboot-hardpoweroffpoweroff-hardsnapshot-createsnapshot-revertsnapshot-deletedisk-snapshot-createdisk-snapshot-revertdisk-snapshot-delete
Instead of performing the action immediately on all the VMs, you can perform it on small groups of VMs with these options:
period: seconds between each group of actions.number: number of VMs to apply the action to each period.
curl http://127.0.0.1:2474/service/5/role/frontend/action -u 'oneadmin:password' -v -X POST --data '{
"action": {
"perform":"stop",
"params" : {
"period" : 60,
"number" : 2
Add a Role to a Running Service
| POST | /service/<id>/role_action | Add or remove a Role from running service. | 204: |
curl http://127.0.0.1:2474/service/5/role_action -u 'oneadmin:password' -v -X POST --data '{
"action": {
"perform":"add_role",
"params" : {
"role" : '{
"name": "NEW_ROLE",
"cardinality": 1,
"template_id": 0,
"type": "vm",
"min_vms": 1,
"max_vms": 2,
"elasticity_policies": [],
"scheduled_policies": []
Remove a Role from a Running Service
"action": {
"perform":"remove_role",
"params" : {
"role" : 'NEW_ROLE'
Update a Service
| PUT | /service/<id> | Update the SERVICE resource identified by <id>. | 200 OK: |
Append can be used to append information to the service, in this case the request body must include the following information:
append: set totrue.template: JSON representation of the template to append.
curl http://127.0.0.1:2474/service/4 -u 'oneadmin:password' -v -X PUT --data '{
"roles":[
"name":"frontend",
"cardinality":"1",
"template_id":"0",
"type": "vm",
"min_vms":"1",
"max_vms":"4",
"cooldown":"30",
"adjust":"20",
"period":"3",
"cooldown":"30"
"type":"CHANGE",
"adjust":"4",
"name":"worker",
"cardinality":"2",
"template_id":"0",
"type": "vm",
"parents":[
"frontend"
"min_vms":"2",
"max_vms":"10",
"cooldown":"240",
"type":"CHANGE",
"adjust":"5",
"period":"5",
"cooldown":"240"
> PUT /service/4 HTTP/1.1
> Accept: */*
< HTTP/1.1 200 OK
"DOCUMENT": {
"TEMPLATE": {
"BODY": {
"roles": [
"adjust": 4,
"type": "CHANGE",
"template_id": 0,
"type": "vm",
"name": "frontend",
"min_vms": 1,
"max_vms": 4,
"cardinality": 1,
"cooldown": 30,
