FireEdge for Large Deployments
Low-to-medium sized enterprise clouds will typically deploy FireEdge on a single machine with the other OpenNebula Daemons as part. However, this simple deployment can be extended by
- Improving scalability of the server for large user pools, usually by deploying FireEdge as a separate application on one or more Hosts.
This guide introduces various deployment options to achieve this. Check also the API Scalability guide for tips on how to improve FireEdge and OpenNebula Daemon performance.
Deploy in Webserver
Self-contained deployment of FireEdge (using opennebula-fireedge system service) is sufficient for small-to-medium installations. This is no longer enough when the service has lots of concurrent users and the number of objects in the system is high (for example, more than 2000 simultaneous Virtual Machines).
The FireEdge server is implemented as a nodejs server. This makes it suitable to run on any server. Also, the service is embedded inside Apache HTTP Server or NGINX. Another advantage is the ability to run FireEdge on multiple servers and balance the load between them.
Guacamole
If you want to use Guacamole you need to have it running. You can start this service with the command:
# systemctl enable opennebula-guacd
# systemctl start opennebula-guacd
Filesystem Permissions
Another thing you have to take into account is the user under which the server will run. The installation sets the permissions for the oneadmin user and group, and files like the FireEdge configuration and credentials cannot be read by other users.
# chmod a+x /var
# chmod a+x /var/lib
# chmod a+x /var/lib/one
# chmod a+x /var/lib/one/.one
Non-TLS Configuration
If FireEdge is installed and you want to place an apache to forward traffic to FireEdge, you can inside VirtualHost. Simply insert the following snippet and adjust it to your current configuration.
Apache
<VirtualHost *:80>
ProxyRequests off
ProxyPreserveHost on
# no proxy for /error/ (Apache HTTPd errors messages)
ProxyPass /error/ !
ProxyPass /fireedge http://localhost:2616/fireedge
ProxyPassReverse /fireedge http://localhost:2616/fireedge
RewriteEngine on
RewriteCond %{HTTP:Upgrade} websocket [NC]
RewriteCond %{HTTP:Connection} upgrade [NC]
RewriteRule ^/fireedge/?(.*) "ws://localhost:2616/fireedge/$1" [P,L]
<Location /fireedge>
Order deny,allow
Allow from all
</Location>
</VirtualHost>
As you can see in the configuration the location is in /fireedge, that means that it is a path of your domain <YOUR_DOMAIN>/fireedge. If you want the FireEdge to be in the root you must change it to /NGINX
You will need to configure a new virtual Host in NGINX. Depending on the operating system and the method of installation, NGINX loads virtual Host configurations from either /etc/nginx/conf.d or /etc/nginx/sites-enabled.
- A sample
cloudserver.orgvirtual Host is shown below:
# No squealing.
server_tokens off;
#### OpenNebula FireEdge upstream
upstream fire-edge {
server 127.0.0.1:2616;
#### cloudserver.org HTTPS virtual host
server {
listen 80;
server_name cloudserver.org;
### Proxy requests to upstream
location /fireedge {
proxy_pass http://fire-edge/fireedge;
proxy_redirect off;
log_not_found off;
proxy_buffering off;
proxy_cache_bypass $http_upgrade;
proxy_http_version 1.1;
proxy_set_header Host $http_host;
proxy_set_header X-Forwarded-FOR $proxy_add_x_forwarded_for;
access_log off;
As you can see in the configuration the location is in /fireedge, that means that it is a path of your domain <YOUR_DOMAIN>/fireedge. If you want the FireEdge to be in the root you must change it to /TLS-secured Configuration
We must create the virtual Host that will run our FireEdge. Here is an example:
Apache
<VirtualHost *:443>
ServerName one.example.com
SSLEngine on
SSLCertificateKeyFile /etc/ssl/private/opennebula-key.pem
SSLCertificateFile /etc/ssl/certs/opennebula-certchain.pem
SSLProtocol All -SSLv2 -SSLv3 -TLSv1 -TLSv1.1
SSLHonorCipherOrder On
SSLCompression off
Header always set Strict-Transport-Security "max-age=15768000"
SSLCipherSuite 'ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256'
RequestHeader set X-Forwarded-Proto "https"
ProxyRequests off
ProxyPass /error/ !
RewriteEngine on
Order deny,allow
Allow from all
</Location>
</VirtualHost>
Now the configuration should be ready. Restart or reload the Apache configuration to start the application and point to the virtual Host to check that everything is running.
As you can see in the configuration inside the location, ProxyPass and ProxyPassReverse is in /fireedge that means it is a path of your domain <YOUR_DOMAIN>/fireedge. If you want the FireEdge to be in the root you must change it to /.NGINX
# No squealing.
server_tokens off;
#### cloudserver.org HTTP virtual host
server {
listen 80;
### Permanent redirect to HTTPS (optional)
return 301 https://$server_name:8443;
server {
listen 8443;
### SSL Parameters
ssl on;
ssl_certificate /etc/ssl/certs/ssl-cert-snakeoil.pem;
ssl_certificate_key /etc/ssl/private/ssl-cert-snakeoil.key;
proxy_redirect off;
log_not_found off;
access_log off;
As you can see in the configuration the location is in /fireedge, that means that it is a path of your domain <YOUR_DOMAIN>/fireedge. If you want the FireEdge to be in the root you must change it to /We value your feedback
