Backup operations may incur in a high I/O or CPU demands. This will add noise to the VMs running in the hypervisor. You can control resource usage of the backup operations by:
- Lower the priority of the associated processes. Backup commands are run under a given ionice priority (best-effort, class 2 scheduler); and a given nice.
- Confine the associated processes in a cgroup. OpenNebula will create a systemd slice for each backup datastore so the backup commands run with a limited number or read/write IOPS and CPU Quota.
Note that for the later, you need to delegate the cpu
and io
cgroup controllers to the oneadmin
user. This way OpenNebula can set CPUQuota
, IOReadIOPSMax
and IOWriteIOPSMax
To delegate the controllers you need to add the following file for oneadmin
account (id 9869) in all the hosts (note that you’d probably need to create the user service folder):
$ cat /etc/systemd/system/user@9869.service.d/delegate.conf
[Service]
Delegate=cpu cpuset io
After that, reboot the hypervisor and double check that the setting is correct (you need to login as oneadmin
$ cat /sys/fs/cgroup/user.slice/user-9869.slice/cgroup.controllers
cpuset cpu io memory pids
Temporary Backup Path
Disk images backups are generated within a local folder in the host where the VM is running. These images are later uploaded to the selected backup datastore. By default, this temporary path is set to the VM folder, in /var/lib/one/datastores/<DATASTORE_ID>/<VM_ID>/backup
However, it’s possible to modify this path to utilize alternative locations, such as different local volumes, or to opt out of using the shared VM folder entirely.
To change the base folder to store disk backups for all hosts edit /var/lib/one/remotes/etc/datastore/datastore.conf
and set the BACKUP_BASE_PATH
variable. Please note this file uses shell syntax.
